SEFT ending jpg file
I recover all deleted pictures from my server ext3 hdd with photorec , thank you , thank you , thank you again for this program
Only a very small problem , photorec recovered jpg ending with FF D9 ( as usual ) but all my picture was taken with Samsung Galaxy Phone , this phone add about 98 bytes atfter FF D9 so now ending with 53 45 46 54 ( SEFT in ascii ) . Pictures are not afected at all by this 96 bytes short but could lead to strange behaviour inside phone .
I'd like if possible te recover original jpg file ( unshorted ) , now the question , can you release a modified version of photorec with changed jpg ending 53 45 46 54 instead of FF D9 ?
Or just add another category , samsung galaxy jpg ?
I will post example of ending for 1 picture in left recovered , in right original :
Left file: D:\Desktop\1\20240101_124858.jpg Right file: D:\Desktop\2\20240101_124858.jpg
003FA040 84 6B 70 FF D3 FF D9 „kpÿÓÿÙ <> 003FA040 84 6B 70 FF D3 FF D9 00 00 01 0A 0E 00 00 00 49 „kpÿÓÿÙ........I
003FA050 6D 61 67 65 5F 55 54 43 5F 44 61 74 61 31 37 30 mage_UTC_Data170
003FA060 34 31 30 36 31 33 38 37 36 33 00 00 A1 0A 08 00 4106138763..¡...
003FA070 00 00 4D 43 43 5F 44 61 74 61 32 38 34 53 45 46 ..MCC_Data284SEF
003FA080 48 6B 00 00 00 02 00 00 00 00 00 01 0A 36 00 00 Hk...........6..
003FA090 00 23 00 00 00 00 00 A1 0A 13 00 00 00 13 00 00 .#.....¡........
003FA0A0 00 24 00 00 00 53 45 46 54 .$...SEFT
Thank you again
Later edit : I found some info about SEFT record
https://www.hackerfactor.com/blog/index ... adata.html
Thank you again
Re: SEFT ending jpg file
"could lead to strange behaviour inside phone" does not sound convincing. Just copy the pictures to a standard computer. Phone storage is not a reliable location anyway.valliro wrote: 27 Aug 2026, 16:55 I recover all deleted pictures from my server ext3 hdd with photorec , thank you , thank you , thank you again for this program
Look at your sample. There is no "instead". There is a lengthy trailer beyond the "FF D9".
I don't have access to your picture location. You provided a location on your computer, inaccessible from the internet.
Original :
deleted
Recovered :
deleted
deleted
Recovered :
deleted
I can't see any difference.
Sorry but both picture was uploaded from my phone , i cant acces now via computer until next week , i dont have recovered picture in my phone
please wait until next week until i am back
https://drive.google.com/drive/folders/ ... sp=sharing
sorry for late reply , now i come back
you have original picture , recovered picture and ending comparation
i can update more pictures if you want , i still have about 200 original pictures and their recovered version
it is normal for 8tb hdd ( new hdd cloned from deleted hdd ) to recover in more than 200 hours and still not finnish ?
after a lot of searching i think samsung use this trailer for storing extra info about picture , like burst number , moving jpg , focus , iso and so , most of them only needed when refocus or alter picture with original samsung editor after taken
It is a complete waste of time discussing proprietary extensions of Samsung in jpeg files.valliro wrote: 06 Sep 2026, 09:10 https://drive.google.com/drive/folders/ ... sp=sharing
Which software? Which version?
No. Read about EXIF data.
I am not trying to open a discution about samsung jpg coding , main question , still unanswered , was can you add another category like samsung galaxy jpg , or can i modify myself your program to recover full samsung jpg file ?
I like if possible to restore original file
Thank you for your time
I don't see an interest for Christophe Grenier to create a new version of PhotoRec for your individual needs as the existing version recovers jpeg pictures correctly with the only difference that the proprietary trailer of the Samsung company is left out.
There is no documentation for what this trailer is for. Therefore the world outside your Samsung phone cannot process that information if it is necessary for anything.
All the information (date, time, location, camera parameters when the pictures was taken) that you pretended to be in that trailer is already embedded in the EXIF data of your picture but you ignored my hint.
A proprietary extension (that nobody can interpret) is not necessary.
Here are three possible solutions for your problem:
1. Use another carver.
2. PhotoRec is free and open source. You can modify the code yourself for your particular needs.
3. Try out PhotoRec. Disable jpeg support and use a custom signature that matches the beginning of jpeg files.
If somebody is interested , i managa to recover all my picture with original seft ending with dmde
You have raw search function and can set header and end of file
Maybe i make some mistake when select options because it found around 450000 pictures and not all of them ending with seft
With a lot of gemini help , i create an automated rules in power shell to remove extension from files not ending in seft
After deleted files without extension it remain my 40000 original , uncut picture
Because dmde not recover original create and modify date i use exiftool to restore both dates and files name from exif metadata
I keep all my pictures names in format yyyymmdd_hhmmss.jpg so i t was easy to compare recover files with few original files not lost and was identical
If somebody it interested to try i can post power shell script for removing wrong ending file
Also i thinck it is posible to do similar with photorec which have option to set header and max size , but need a different script to cut files when find seft ending
Good luck !
Good luck !
