Here's a screenshot of the results of the Deeper search:
Higher res version: http://i.imgur.com/oUZuZ.jpg
Basically, a laptop harddrive stopped booting. I took it out of the laptop out and hooked it up via a SATA to USB cable to my laptop and ran testdisk on it. I did a quick scan and wasn't sure if it found everything that I needed to recover, so I went ahead and did a Deeper scan on it.
From what I've read, it sounds like I need to mark the deleted partitions either Primary Bootable or just Primary. I notice there's already another partition marked as primary bootable, but I'm pretty sure that the partition listed underneath that one is the one that is usually booted from. Is it ok to mark that one as primary bootable even though a primary bootable partition is already listed?
What should I do about the other two deleted partitions? Would it hurt to mark those as Primary while I'm already here? I think I remember reading somewhere though that a drive can only support up to 4 primary partitions, so I'm not sure what to do. I understand that it's probably difficult to make a judgement based on the little bit of information I've given, but this isn't my harddrive and I don't have very much information to go off of.
As always, any insight or help would be greatly appreciated.
Thank you very much
