disparition d'une partition écrasée par une autre partition Topic is solved
paldevan
#1 Post by paldevan »
Bonjour
Comme vous allez le voir,débutant que je suis,l'informatique s'amuse avec moi.
Comme recommandé par le wiki cgsecurity.org je vous mets d'abord le fichier testdisk.log:
  • Fri Sep 28 21:34:21 2012
    OS: Windows XP SP2
    Compilation date: 2012-09-22T12:26:25
    disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=30750031872
    disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=160041885696
    disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=30750031872
    disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=160041885696
    disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=30737839104
    disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=30737839104
    disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=1000202043392
    Disk /dev/sda - 30 GB / 28 GiB - CHS 3738 255 63, sector size=512 - Maxtor 6E030L0, S/N:31454b3044564552202020202020202020202020, FW:NAR61590
    Disk /dev/sdb - 160 GB / 149 GiB - CHS 19457 255 63, sector size=512 - MD01600-BJBW-RO, FW:00.02C01
    Disk /dev/sdc - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC WD10 EADS-00L5B1, S/N:W -DCWUA64144667, FW:01.0
    Drive E: - 1000 GB / 931 GiB - CHS 121600 255 63, sector size=512
    Disk /dev/sdb - 160 GB / 149 GiB - MD01600-BJBW-RO
    Analyse Disk /dev/sdb - 160 GB / 149 GiB - CHS 19457 255 63
    NTFS at 0/1/1
    1 * HPFS - NTFS 0 1 1 3736 254 63 60034842 [111111]
    NTFS at 0/1/1
    filesystem size 60034842
    mftmirr_lcn 3752177
    NTFS, blocksize=4096, 30 GB / 28 GiB
    file_pread(5,2,buffer,312582144(19457/86/22)) lseek err Invalid argument
    file_pread(5,1,buffer,312582144(19457/86/22)) lseek err Invalid argument
    file_pread(5,15,buffer,312582145(19457/86/23)) lseek err Invalid argument
    file_pread(5,3,buffer,312582160(19457/86/38)) lseek err Invalid argument
    file_pread(5,3,buffer,312582207(19457/87/22)) lseek err Invalid argument
    file_pread(5,8,buffer,312582223(19457/87/38)) lseek err Invalid argument
    file_pread(5,11,buffer,312582270(19457/88/22)) lseek err Invalid argument
    file_pread(5,2,buffer,312584192(19457/118/54)) lseek err Invalid argument
    $MFTMirr location mismatch or first 4 records are fragmented. Run chkdsk.
    Failed to load $MFTMirr: Input/Output error.
Ensuite :
Je suis sous windows xp sp2 et le problème concerne 2 disques durs internes.
Le premier est le disque qui contient windows (et uniquement windows,il s'appelle 111111(C:) ,c'est un maxtor et il fait 30 Go) et le second contenait (j'en pleure encore) divers fichiers (exécutables,images,textes,ect...);il s'appelle 222222 (D:) ,c'est un MDT et il fait 160 Go.
Avec CLONE GENIUS j'ai voulu faire une copie du disque dur qui contient windows sur l'autre (la copie s'est faite en redémarrant l'ordinateur,avec CLONE GENIUS sur cd et dans le lecteur cd).
A la fin de la copie à l'emplacement du disque 222222 (D:) je me suis retrouvé avec la copie du disque 111111(C:),le nom du 2nd disque a disparu (à la place j'ai 111111(C:)) et la taille est identique à celle du 1er (dans le BIOS par contre la taille est toujours de 160 Go).
Mes disques:
http://hpics.li/51f70a9
Mon but bien sûr est de refaire apparaître mon disque 222222 (D:) avec tout ce qu'il y a dedans,ma copie du disque 111111 (C:) peut être effacée car je ne boote pas dessus.
Je précise,au cas où,que mon disque C: à entre 1 et 4 secteurs défectueux (d'où ma copie de win pour un futur changement de disque dur).
Voici maintenant les captures d'écran de TESTDISK (sous windows):
-les disques durs:
http://hpics.li/760ea7e
-l'analyse:
http://hpics.li/982e474
-la quick searck n'ayant rien donnée j'ai enchaîné sur la deeper search:
http://hpics.li/93bcce8
-le résultat de la commande P (list files) sur le 2nd disque (le disque 111111 est lu sans problème):
http://hpics.li/7aa196c
Voilà en espérant avoir été clair et pas trop long (et ne pas mettre trompé de section)
Merci d'avance de votre expertise.
Bien à vous.
PS:inutile de vous dire que je suis au bord de prendre mon pc et de faire du basket avec,si.
Re: disparition d'une partition écrasée par une autre partit
Choisissez de passer la seconde partition, celle qui occupe la totalité du disque, en P(rimary).
Sur l'écran suivant, choisissez Write, confirmer, BackupBS, confirmer, Quit et redémarrer
Utilisez ensuite PhotoRec, vous devriez retrouver vos données mais sans les noms d'origine.
Bonne chance
paldevan
#3 Post by paldevan »
Bonsoir.
Un grand merci pour la réponse rapide,je vais tâcher de m'en occuper soit dimanche si je suis motivé (parce que cela fait quelques jours que je suis dessus et c'est lassant) sinon les jours d'après.
Juste deux questions :
1) - PhotoRec n'est-il pas seulement pour les documents audio,vidéo,musicaux et les images parce que dans ce disque 222222 (D:) qui n'apparait plus il y avait aussi tous mes exécutables et les programmes qui en découlent installés .
Voilà comment ça apparait dans le gestionnaire de disque:
http://hpics.li/9ebd208
2) - Puis-je également me contenter de réallouer (de partionner) la partie du disque invisble pour que mes données réapparaissent ou est-ce que je risque de les effacer ?
Très très cordialement.
paldevan wrote: 1) - PhotoRec n'est-il pas seulement pour les documents audio,vidéo,musicaux et les images parce que dans ce disque 222222 (D:) qui n'apparait plus il y avait aussi tous mes exécutables et les programmes qui en découlent installés .
PhotoRec récupère plus de 400 formats de fichier, cependant vu que les exécutables récupérés n'auront pas leur nom d'origine, il faudra refaire les installations.
paldevan wrote: 2) - Puis-je également me contenter de réallouer (de partionner) la partie du disque invisble pour que mes données réapparaissent ou est-ce que je risque de les effacer ?
La première étape avec TestDisk va rétablir la table des partitions telle qu'elle était auparavant.
paldevan
#5 Post by paldevan »
Bonjour
J'ai enfin pu prendre le temps pour récupérer mes données et voici un petit-petit compte-rendu:
-Un passage de récupération sur mon disque dur de 160 Go a pris entre 7 et 10 heures environ (j'en ai fais 3 au cas où les récupérations auraient pu varier d'un passage à l'autre).
-Je pense avoir récupéré une grosse totalité de ce que j'avais (je n'ai pas pu retrouver ni un fichier texte bien précis ni les fichiers de sauvegardes de l'application FEBE,qui sert à sauvegarder les favoris et les réglages de firefox avec des fichiers .xpi, .json,.fbu,.html et .js;j'en ai trouvé d'autre mais pas les recherchés)
Pour les fichiers non retrouvés j'ai vraiment bien cherché:est-ce que l'outil de récupération pourrait modifier les extensions ?
Mais je le reprécise pour ceux qui s'inquièteraient : ces fichiers que je n'ai pas retrouvés (en dehors du fait que malgré mes recherches studieuses j'ai quand même pu les rater) ne représentent qu'une infime partie des fichiers à retrouver.
-Et dans l'opération j'ai perdu (hélas) 11 Go mon disque n'ayant plus que 149 Go d'espace utilisable sur les 160 de départ (testdisk me lit 160 Go et le gestionnaire de disque 149 Go).
Est-ce qu'il y aurait une manipulation que vous pourriez me conseiller pour récupérer ces 11 Go ?
Pour finir je vous remercie encore de votre réponse rapide et de votre logiciel qui m'a sorti d'un gouffre sans fond.
Salutation.
