Testdisk sees the partitions before the quick search but not after quick search or deeper search
Before Quick Search:
Disk /dev/sdb - 160 GB / 149 GiB - CHS 19457 255 63
1 P Dell Utility 0 1 1 3 254 63 64197
Invalid NTFS or EXFAT boot
2 * HPFS - NTFS 4 0 1 19456 253 63 312512382
After Quick Search or Deeper Search:
* FAT16 >32M 0 1 1 3 254 63 64197 [DellUtility]
Does this seem odd? Is there something that I am doing wrong?
Scott
Partitions disappear after Quick Search Topic is solved
Re: Partitions disappear after Quick Search
If you already made a quick and deeper search with no results, indicates that you have problems with your boot sector, its backup or damaged file system.
You can see your NTFS-partition two times on your display.
But it doesn't mean that it will be two times in your partition table but once and the second listing refers to an Invalid NTFS or EXFAT boot.
It means your boot sector.
See your message;
Start TestDisk.
Confirm through until you see the menu Analyse.
Confirm at Boot with enter also.
Please let us know, do you see your data or an error message.
Infos will follow.
Also;
Your partition is not Intel-Standard.
Normally should be;
2 * HPFS - NTFS 4 0 1 19456 254 63
Changing the value of your heads per cylinder in menu geometry, might be worth another try.
Before Quick Search displayes only your current partition structur or partition table.Testdisk sees the partitions before the quick search
See your message;
I would suggest to have try to rebuild your boot sector.Invalid NTFS or EXFAT boot
Start TestDisk.
Infos will follow.
Also;
Normally should be;
Absolutely amazing! It worked perfectly. Thanks so much. I can't believe how quickly you responded. I made a donation and hope I don't need your help again, but it is nice to know you are there!
