Stuck in Testdisk UI Maze! - Trying To Recover USB Stick
SteveL
#1 Post by SteveL »
I have a Sandisk Cruzer Titanium 512Mb flash drive that suddenly Windows can't read and wants to format.
Windows sees the partition and calls it "Healthy" and the size is correct but unformatted. Running CHKDSK indicates that the drive is formatted RAW.
I have run Testdisk and get to a point and start going around in circles hence the title of this post. Test disk shows the drive and the size appears to be correct. I select Intel/PC partition type and run "analyze" which produces:
"Partition sector doesn't have the endmark 0xAA55"
"Quick Search" or "Deeper Search" yields the following:
> FAT16 >32M 0 0 33 63 42 42 1014751 [NO NAME]
At this point things go downhill with no partition shown and proceeds to "Deeper Search" and similar results. Based on this it would appear that the partition does, in fact, exist but is somehow damaged.
Is there a way out of this maze that leads to a repaired partition table and recovered files?
BTW, I already tried PhotoRec and it made a mess of things. Several thousand TXT files with no meaningful names.
Thanks,
Steve
Since it is late and the BB doesn't like to attach *.LOG files or *.TXT files I am attaching the log file below..... Sorry for the clutter.
Thu Oct 11 20:27:44 2012
OS: Windows 2000 SP4
filewin32_getfilesize(/dev/sda) GetFileSize err Incorrect function.
filewin32_setfilepointer(/dev/sda) SetFilePointer err Incorrect function.
Fix disk size using CHS
filewin32_getfilesize(/dev/sdb) GetFileSize err Incorrect function.
filewin32_setfilepointer(/dev/sdb) SetFilePointer err Incorrect function.
filewin32_getfilesize(/dev/sdg) GetFileSize err Incorrect function.
filewin32_setfilepointer(/dev/sdg) SetFilePointer err Incorrect function.
filewin32_getfilesize(\\.\PhysicalDrive0) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\PhysicalDrive0) SetFilePointer err Incorrect function.
filewin32_getfilesize(\\.\C:) GetFileSize err The parameter is incorrect.
filewin32_getfilesize(\\.\F:) GetFileSize err The parameter is incorrect.
filewin32_getfilesize(\\.\G:) GetFileSize err The parameter is incorrect.
filewin32_getfilesize(\\.\H:) GetFileSize err The parameter is incorrect.
filewin32_getfilesize(\\.\I:) GetFileSize err The parameter is incorrect.
filewin32_getfilesize(\\.\J:) GetFileSize err The parameter is incorrect.
filewin32_getfilesize(\\.\K:) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\K:) SetFilePointer err Incorrect function.
filewin32_getfilesize(\\.\L:) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\L:) SetFilePointer err Incorrect function.
filewin32_getfilesize(\\.\M:) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\M:) SetFilePointer err Incorrect function.
Warning: can't get size for \\.\M:
filewin32_getfilesize(\\.\N:) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\N:) SetFilePointer err Incorrect function.
filewin32_getfilesize(\\.\P:) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\P:) SetFilePointer err Incorrect function.
file_pread(4,1,buffer,234452609(14593/254/63)) lseek err Invalid argument
file_pread(5,1,buffer,234452609(14593/254/63)) lseek err Invalid argument
file_pread(6,1,buffer,1028159(63/254/63)) lseek err Invalid argument
Disk /dev/sda - 120 GB / 111 GiB - CHS 14593 255 63, sector size=512 - WDC WD1200JD-00FYB0, S/N:4457572d414d4845333135373934 037 0 0 0 0, FW:02.05D02
Disk /dev/sdb - 120 GB / 111 GiB - CHS 14593 255 63, sector size=512 - WDC WD1200JD-00FYB0, S/N:4457572d414d4845333139373832 038 0 0 0 0, FW:02.05D02
Disk /dev/sdg - 518 MB / 494 MiB - CHS 63 255 63, sector size=512 - SanDisk Cruzer Titanium, FW:2000
Disk /dev/sdg - 518 MB / 494 MiB - SanDisk Cruzer Titanium
Analyse Disk /dev/sdg - 518 MB / 494 MiB - CHS 63 255 63
Ask the user for vista mode
search_vista_part: 0
FAT16 at 0/0/33
FAT1 : 1-248
FAT2 : 249-496
start_rootdir : 497
Data : 529-1014736
sectors : 1014751
cluster_size : 16
no_of_cluster : 63388 (2 - 63389)
fat_length 248 calculated 248
heads/cylinder 129 (FAT) != 255 (HD)
FAT16 at 0/0/33
FAT16, 519 MB / 495 MiB
This partition ends after the disk limits. (start=32, size=1014751, end=1014782, disk end=1012095)
file_pread(6,8,buffer,1014816(63/43/13)) lseek err Invalid argument
file_pread(6,1,buffer,1014816(63/43/13)) lseek err Invalid argument
file_pread(6,8,buffer,1014944(63/45/15)) lseek err Invalid argument
file_pread(6,8,buffer,1015072(63/47/17)) lseek err Invalid argument
file_pread(6,8,buffer,1015200(63/49/19)) lseek err Invalid argument
file_pread(6,8,buffer,1015328(63/51/21)) lseek err Invalid argument
file_pread(6,8,buffer,1015456(63/53/23)) lseek err Invalid argument
file_pread(6,8,buffer,1015584(63/55/25)) lseek err Invalid argument
file_pread(6,8,buffer,1015712(63/57/27)) lseek err Invalid argument
file_pread(6,8,buffer,1015840(63/59/29)) lseek err Invalid argument
file_pread(6,8,buffer,1015968(63/61/31)) lseek err Invalid argument
file_pread(6,8,buffer,1016096(63/63/33)) lseek err Invalid argument
file_pread(6,8,buffer,1016224(63/65/35)) lseek err Invalid argument
file_pread(6,8,buffer,1016352(63/67/37)) lseek err Invalid argument
file_pread(6,8,buffer,1016480(63/69/39)) lseek err Invalid argument
file_pread(6,8,buffer,1016608(63/71/41)) lseek err Invalid argument
file_pread(6,8,buffer,1016736(63/73/43)) lseek err Invalid argument
file_pread(6,8,buffer,1016864(63/75/45)) lseek err Invalid argument
file_pread(6,8,buffer,1016992(63/77/47)) lseek err Invalid argument
file_pread(6,8,buffer,1017120(63/79/49)) lseek err Invalid argument
file_pread(6,8,buffer,1017248(63/81/51)) lseek err Invalid argument
file_pread(6,8,buffer,1017376(63/83/53)) lseek err Invalid argument
file_pread(6,8,buffer,1017504(63/85/55)) lseek err Invalid argument
file_pread(6,8,buffer,1017632(63/87/57)) lseek err Invalid argument
file_pread(6,8,buffer,1017760(63/89/59)) lseek err Invalid argument
file_pread(6,8,buffer,1017888(63/91/61)) lseek err Invalid argument
file_pread(6,8,buffer,1018016(63/93/63)) lseek err Invalid argument
file_pread(6,8,buffer,1018144(63/96/2)) lseek err Invalid argument
file_pread(6,8,buffer,1018272(63/98/4)) lseek err Invalid argument
file_pread(6,8,buffer,1018400(63/100/6)) lseek err Invalid argument
file_pread(6,8,buffer,1018528(63/102/8)) lseek err Invalid argument
file_pread(6,8,buffer,1018656(63/104/10)) lseek err Invalid argument
file_pread(6,8,buffer,1018784(63/106/12)) lseek err Invalid argument
file_pread(6,8,buffer,1018912(63/108/14)) lseek err Invalid argument
file_pread(6,8,buffer,1019040(63/110/16)) lseek err Invalid argument
file_pread(6,8,buffer,1019168(63/112/18)) lseek err Invalid argument
file_pread(6,8,buffer,1019296(63/114/20)) lseek err Invalid argument
file_pread(6,8,buffer,1019424(63/116/22)) lseek err Invalid argument
file_pread(6,8,buffer,1019552(63/118/24)) lseek err Invalid argument
file_pread(6,8,buffer,1019680(63/120/26)) lseek err Invalid argument
file_pread(6,8,buffer,1019808(63/122/28)) lseek err Invalid argument
file_pread(6,8,buffer,1019936(63/124/30)) lseek err Invalid argument
file_pread(6,8,buffer,1020064(63/126/32)) lseek err Invalid argument
file_pread(6,8,buffer,1020192(63/128/34)) lseek err Invalid argument
file_pread(6,8,buffer,1020320(63/130/36)) lseek err Invalid argument
file_pread(6,8,buffer,1020448(63/132/38)) lseek err Invalid argument
file_pread(6,8,buffer,1020576(63/134/40)) lseek err Invalid argument
file_pread(6,8,buffer,1020704(63/136/42)) lseek err Invalid argument
file_pread(6,8,buffer,1020832(63/138/44)) lseek err Invalid argument
file_pread(6,8,buffer,1020960(63/140/46)) lseek err Invalid argument
file_pread(6,8,buffer,1021088(63/142/48)) lseek err Invalid argument
file_pread(6,8,buffer,1021216(63/144/50)) lseek err Invalid argument
file_pread(6,8,buffer,1021344(63/146/52)) lseek err Invalid argument
file_pread(6,8,buffer,1021472(63/148/54)) lseek err Invalid argument
file_pread(6,8,buffer,1021600(63/150/56)) lseek err Invalid argument
file_pread(6,8,buffer,1021728(63/152/58)) lseek err Invalid argument
file_pread(6,8,buffer,1021856(63/154/60)) lseek err Invalid argument
file_pread(6,8,buffer,1021984(63/156/62)) lseek err Invalid argument
file_pread(6,8,buffer,1022112(63/159/1)) lseek err Invalid argument
file_pread(6,8,buffer,1022240(63/161/3)) lseek err Invalid argument
file_pread(6,8,buffer,1022368(63/163/5)) lseek err Invalid argument
file_pread(6,8,buffer,1022496(63/165/7)) lseek err Invalid argument
file_pread(6,8,buffer,1022624(63/167/9)) lseek err Invalid argument
file_pread(6,8,buffer,1022752(63/169/11)) lseek err Invalid argument
file_pread(6,8,buffer,1022880(63/171/13)) lseek err Invalid argument
file_pread(6,8,buffer,1023008(63/173/15)) lseek err Invalid argument
file_pread(6,8,buffer,1023136(63/175/17)) lseek err Invalid argument
The harddisk (518 MB / 494 MiB) seems too small! (< 519 MB / 495 MiB)
FAT16 at 0/0/33
FAT1 : 1-248
FAT2 : 249-496
start_rootdir : 497
Data : 529-1014736
sectors : 1014751
cluster_size : 16
FAT16 at 0/0/33
file_pread(6,2,buffer,1015923(63/60/49)) lseek err Invalid argument
file_pread(6,2,buffer,1015986(63/61/49)) lseek err Invalid argument
file_pread(6,2,buffer,1016049(63/62/49)) lseek err Invalid argument
file_pread(6,2,buffer,1027407(63/243/4)) lseek err Invalid argument
file_pread(6,2,buffer,1027470(63/244/4)) lseek err Invalid argument
file_pread(6,2,buffer,1027533(63/245/4)) lseek err Invalid argument
file_pread(6,1,buffer,1028160(64/0/1)) lseek err Invalid argument
Store new MBR code
Lito
Re: Stuck in Testdisk UI Maze! - Trying To Recover USB Stick
#2 Post by Lito »
There is a lot information about that message in this forum.
Try doing a search for 0xAA55
You could also try IsoBuster:
http://www.isobuster.com/
Best of luck
#3 Post by cgrenier »
Run TestDisk, after selecting the disk,
- in Geometry, set 64 cylinders.
- Analyse, Quick Search, Write, confirm, Quit
Try again to access your data.
