Recovery of Truecrypt Partition
Noah
#1 Post by Noah »
Like most of the people who find themselves on this wonderful forum, I accidently did something I was not supposed to do. While installing Ubuntu, I assumed the drive it attempted to install itself on was the one I intended it to install on. The drive in question (/dev/sdb) was a 750 GB truecrypt drive in NTFS format.
I've tried just about everything I could up to this point, searching the forums and other sites high and low to figure it out on my own. My attempts were futile (although I did learn quite a bit in the process).
I could try and explain more, but I think posting the log should do more justice. This log is the appended version.
It would mean so much to me if I could recover the files on this drive; years of my research and inventions are stored on it. Either way, I'd like to thank the people of these forums in advance for the diligent work I've seen in so many previous posts. An excellent community for an excellent program.
Mon Oct 15 06:45:28 2012
OS: Linux, kernel 3.2.0-29-generic-pae (#46-Ubuntu SMP Fri Jul 27 17:25:43 UTC 2012) i686
Compiler: GCC 4.6
Compilation date: 2012-02-05T07:16:54
ext2fs lib: 1.42, ntfs lib: 10:0:0, reiserfs lib: none, ewf lib: none
/dev/sda: LBA, LBA48, DCO support
/dev/sda: size       1250263728 sectors
/dev/sda: user_max   1250263728 sectors
/dev/sda: dco        1250263728 sectors
/dev/sdb: size       1465149168 sectors
/dev/sdb: user_max   1465149168 sectors
/dev/sdb: native_max 1465149168 sectors
/dev/sdb: dco        1465149168 sectors
Disk /dev/sda - 640 GB / 596 GiB - CHS 77825 255 63, sector size=512 - WDC WD6400AAKS-65A7B0, S/N:WD-WMASY2669025, FW:01.03B01
Disk /dev/sdb - 750 GB / 698 GiB - CHS 91201 255 63, sector size=512 - ST3750640AS, S/N:5QD01ZFL, FW:3.AAK
Disk /dev/sdc - 1031 MB / 984 MiB - CHS 1015 32 62, sector size=512 - PNY USB 2.0 FD, FW:PMAP
Disk /dev/sdb - 750 GB / 698 GiB - ST3750640AS
Analyse Disk /dev/sdb - 750 GB / 698 GiB - CHS 91201 255 63
 1 P Linux                    0  32 33 90157  32 51 1448372224
 2 E extended             90157  65 19 91201  52 51   16771074
 5 L Linux Swap           90157  65 21 91201  52 51   16771072
Computes LBA from CHS for Disk /dev/sdb - 750 GB / 698 GiB - CHS 91202 255 63
search_vista_part: 1
recover_EXT2: s_block_group_nr=0/5525, s_mnt_count=3/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 181046528
recover_EXT2: part_size 1448372224
     EXT4 Large file Sparse superblock, 741 GB / 690 GiB
     Linux Swap           90157  65 21 91201  52 35   16771056
     SWAP2 version 1, 8586 MB / 8188 MiB
   * Linux                    0  32 33 90157  32 51 1448372224
   P Linux Swap           90157  65 21 91201  52 35   16771056
 1 * Linux                    0  32 33 90157  32 51 1448372224
 2 P Linux Swap           90157  65 21 91201  52 35   16771056
BAD_RS LBA=887256156 135029
     HPFS - NTFS          55229  36  4 169397 160 36 1834116765
This partition ends after the disk limits. (start=887256156, size=1834116765, end=2721372920, disk end=1465160130)
The harddisk (750 GB / 698 GiB) seems too small! (< 1393 GB / 1297 GiB)
Analyse Disk /dev/sdb - 750 GB / 698 GiB - CHS 91202 255 63
dir_partition inode=2
       2 drwxr-xr-x     0      0      4096 14-Oct-2012 17:51 .
       2 drwxr-xr-x     0      0      4096 14-Oct-2012 17:51 ..
      11 drwx------     0      0     16384 14-Oct-2012 17:45 lost+found
 21233665 drwxr-xr-x     0      0      4096 14-Oct-2012 17:51 etc
 23855105 drwxr-xr-x     0      0      4096 17-Aug-2012 22:05 media
 1572865 drwxr-xr-x     0      0      4096 17-Aug-2012 22:11 bin
 7077889 drwxr-xr-x     0      0      4096 14-Oct-2012 17:47 boot
 24641537 drwxr-xr-x     0      0      4096 17-Aug-2012 22:06 dev
 39583745 drwxr-xr-x     0      0      4096 19-Apr-2012 09:32 home
 6291457 drwxr-xr-x     0      0      4096 17-Aug-2012 22:09 lib
 14417921 drwxr-xr-x     0      0      4096 19-Apr-2012 09:32 mnt
 17301505 drwxr-xr-x     0      0      4096 17-Aug-2012 22:05 opt
 15204353 drwxr-xr-x     0      0      4096 19-Apr-2012 09:32 proc
 15335425 drwx------     0      0      4096 17-Aug-2012 22:10 root
 38273025 drwxr-xr-x     0      0      4096 17-Aug-2012 22:08 run
 2097153 drwxr-xr-x     0      0      4096 14-Oct-2012 17:51 sbin
 5505025 drwxr-xr-x     0      0      4096  5-Mar-2012 13:48 selinux
 13893633 drwxr-xr-x     0      0      4096 17-Aug-2012 22:05 srv
 19660801 drwxr-xr-x     0      0      4096 14-Apr-2012 09:26 sys
 17432577 drwxrwxrwt     0      0      4096 14-Oct-2012 17:51 tmp
 24117249 drwxr-xr-x     0      0      4096 17-Aug-2012 22:05 usr
 25952257 drwxr-xr-x     0      0      4096 17-Aug-2012 22:08 var
      12 lrwxrwxrwx     0      0        37 14-Oct-2012 17:46 initrd.img
      13 lrwxrwxrwx     0      0        33 14-Oct-2012 17:46 vmlinuz
 1835009 drwxr-xr-x     0      0      4096 14-Oct-2012 17:51 cdrom
Mon Oct 15 11:02:46 2012
Compiler: GCC 4.6
     SWAP2 version 1, 8586 MB / 8189 MiB
New options :
 Dump : No
 Cylinder boundary : Yes
 Expert mode : No
Mon Oct 15 11:13:30 2012
Compiler: GCC 4.6
search_superblock
Ext2 superblock found at sector 2 (block=0, blocksize=4096)
block_group_nr 1
recover_EXT2: s_block_group_nr=1/5525, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
Ext2 superblock found at sector 262144 (block=32768, blocksize=4096)
block_group_nr 3
recover_EXT2: s_block_group_nr=3/5525, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
Ext2 superblock found at sector 786432 (block=98304, blocksize=4096)
block_group_nr 5
recover_EXT2: "e2fsck -b 163840 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=5/5525, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
Ext2 superblock found at sector 1310720 (block=163840, blocksize=4096)
block_group_nr 7
recover_EXT2: "e2fsck -b 229376 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=7/5525, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
Ext2 superblock found at sector 1835008 (block=229376, blocksize=4096)
block_group_nr 9
recover_EXT2: "e2fsck -b 294912 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=9/5525, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
Ext2 superblock found at sector 2359296 (block=294912, blocksize=4096)
block_group_nr 25
recover_EXT2: s_block_group_nr=25/5525, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
Ext2 superblock found at sector 6553600 (block=819200, blocksize=4096)
block_group_nr 27
recover_EXT2: "e2fsck -b 884736 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=27/5525, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
Ext2 superblock found at sector 7077888 (block=884736, blocksize=4096)
block_group_nr 49
recover_EXT2: "e2fsck -b 1605632 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=49/5525, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
Ext2 superblock found at sector 12845056 (block=1605632, blocksize=4096)
block_group_nr 81
recover_EXT2: "e2fsck -b 2654208 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=81/5525, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
Ext2 superblock found at sector 21233664 (block=2654208, blocksize=4096)
superblock 0, blocksize=4096 []
superblock 32768, blocksize=4096 []
superblock 98304, blocksize=4096 []
superblock 163840, blocksize=4096 []
superblock 229376, blocksize=4096 []
superblock 294912, blocksize=4096 []
superblock 819200, blocksize=4096 []
superblock 884736, blocksize=4096 []
superblock 1605632, blocksize=4096 []
superblock 2654208, blocksize=4096 []
To repair the filesystem using alternate superblock, run
fsck.ext4 -p -b superblock -B blocksize device
Change partition type:
 1 P HPFS - NTFS              0  32 33 90157  32 51 1448372224
ntfs_boot_sector
filesystem size           1
sectors_per_cluster       0
mft_lcn                   0
mftmirr_lcn               0
clusters_per_mft_record   0
clusters_per_index_record 0
Status: Bad
Status: Bad
Sectors are identical.
rebuild_NTFS_BS
ntfs_boot_sector
filesystem size           1
mft_lcn                   0
mftmirr_lcn               0
Status: Bad
Status: Bad
Not an exFAT boot sector.
     HPFS - NTFS          55229   0  1 91201 254 63  577906245
test_structure_i386: severe error
ntfs_boot_sector
filesystem size           6077398527727424578 1
sectors_per_cluster       218 0
mft_lcn                   1803066754 0
mftmirr_lcn               3695336872 0
clusters_per_mft_record   -97 0
clusters_per_index_record 79 0
Status: Bad
ntfs_boot_sector: Can't read backup boot sector.
Status: Bad
Sectors are not identical.
rebuild_NTFS_BS
ntfs_boot_sector
Status: Bad
Status: Bad
ntfs_boot_sector
Status: Bad
Status: Bad
rebuild_NTFS_BS
Search mft stopped:     327680/577906245
ntfs_boot_sector
Status: Bad
Status: Bad
Fiecluxulpick
Thx
#2 Post by Fiecluxulpick »
Thank you !!
Noah
Re: Recovery of Truecrypt Partition
#3 Post by Noah »
I'm going insane at this point (mostly because I continue to do the same thing expecting different results). This is what I see when I conduct a deeper search. I apologize in advance for the terrible cropping. At this point, it doesn't allow me to another but continue, at which point its like being back at the beginning. I've tried using photorec, doesn't give me a single original file. Please help!
Terminal 1.jpg (39.69 KiB) Viewed 3028 times
