Lost Access To WD Elements External Drive
ennyoueffsea
#1 Post by ennyoueffsea »
Hi all,
I'm posting for the first time in here in the hope that someone might be able to help.
My daughter has been using a 320GB Western Digital Elements external hard drive to hold music etc for backing up her iPhone.
A few weeks ago, iTunes did an update which then closed down the laptop. When she restarted the laptop she then found that she could no longer access the external drive and therefore her music, apps etc.
The drive is not recognised by both her latop running XP and my laptop and desktop, both running XP. When the drive is plugged in the green 'Remove Hardware Safely' icon shows in the notification area so it is being recognised to a degree, but does not show up in either 'My Computer' or in 'Disk Management'.
I tried running PhotoRec to see if anything could be retrieved and managed to copy in the region of 10,000 files or part files. This figure looks to contain many many duplicates of complete and cropped files, all titled with a letter 'F' followed by several numbers, so song titles etc have all gone. I say duplicates as she had nowhere near this number of files on the disk.
I'd be really grateful if anyone can advise how this drive could again be made accessible, but if push comes to shove, whether the disk could be reformatted using TestDisk seeing as Windows is unable to see it.
Would really appreciate any help.
Many thanks,
Terry ;)
Lito
Re: Lost Access To WD Elements External Drive
#2 Post by Lito »
The Western Digital Elements disk drive, have a special driver running under XP. It does also install something called
a virtual CD. You can activate or desactivate this virtual drive. You could try reinstalling the driver, to see if your disk
gets recognised. Whatever you do, do not format the disk. If this does not work, run TestDisk booting from a any Live
Linux distribution CD/DVD. If you have a look a the documentation pages, there is plenty of advise on how to proceed.
Once you run TestDisk, you can post logs, pictures or any other information you manage to dig, so you can get
help from the experts in TestDisk.
Best of luck
ennyoueffsea
#3 Post by ennyoueffsea »
Hi again,
Thanks Lito for your reply.
I didn't know how to update the drivers as it was just a plug in and use external drive. In Device Manager thee was a yellow question mark against USB Device but message said Windows was unable to update the drivers.
I've run TestDisk and I hope people don't mind that I've posted screenshots of each stage. Hopefully someone can advise what option to take next. I'va also added the log at the end of this post.
Thanks you again for any help.
Terry ;)
Wed Oct 31 20:06:42 2012
OS: Windows XP SP3
Compilation date: 2012-09-01T21:55:20
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=40000000000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=320070483968
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=40000000000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=320070483968
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=39991279104
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=2048
Disk /dev/sda - 40 GB / 37 GiB - CHS 4863 255 63, sector size=512 - ST340014A, S/N:4a354c585944354d202020202020202020202020, FW:8.16
Disk /dev/sdb - 320 GB / 298 GiB - CHS 38913 255 63, sector size=512 - WD Elements 1042, FW:1007
Drive D: - 2048 B - CHS 1 64 32, sector size=2048 - HL-DT-ST DVD-RAM GH22NP20, FW:1.02
Disk /dev/sdb - 320 GB / 298 GiB - WD Elements 1042
Analyse Disk /dev/sdb - 320 GB / 298 GiB - CHS 38913 255 63
Partition: Read error
NTFS at 0/32/33
filesystem size 625135616
mftmirr_lcn 39070975
HPFS - NTFS 0 32 33 38913 5 4 625135616 [Elements]
NTFS, blocksize=4096, 320 GB / 298 GiB
file_pread(5,8,buffer,625137664(38913/5/5)) ReadFile The drive cannot find the sector requested.
file_pread(5,1,buffer,625137664(38913/5/5)) ReadFile The drive cannot find the sector requested.
file_pread(5,15,buffer,625137665(38913/5/6)) lseek err Invalid argument
file_pread(5,3,buffer,625137680(38913/5/21)) lseek err Invalid argument
file_pread(5,3,buffer,625137727(38913/6/5)) lseek err Invalid argument
file_pread(5,8,buffer,625137743(38913/6/21)) lseek err Invalid argument
file_pread(5,11,buffer,625137790(38913/7/5)) lseek err Invalid argument
file_pread(5,2,buffer,625139712(38913/37/37)) lseek err Invalid argument
* HPFS - NTFS 0 32 33 38913 5 4 625135616 [Elements]
1 * HPFS - NTFS 0 32 33 38913 5 4 625135616 [Elements]
file_pread(5,1,buffer,6(0/0/7)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,2047(0/32/32)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,2047(0/32/32)) ReadFile Data error (cyclic redundancy check).
NTFS at 0/32/33
file_pread(5,16,buffer,206323712(12843/14/36)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,206323712(12843/14/36)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,206322794(12842/254/63)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,206322794(12842/254/63)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,206322795(12843/0/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,15,buffer,206322796(12843/0/2)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,206322811(12843/0/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,206322858(12843/1/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,206322874(12843/1/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,206322921(12843/2/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,206324843(12843/32/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,13,buffer,206322861(12843/1/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,206322937(12843/2/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,206322984(12843/3/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,206324906(12843/33/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,206323711(12843/14/35)) ReadFile Data error (cyclic redundancy check).
file_pread(5,15,buffer,206323713(12843/14/37)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,206323728(12843/14/52)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,206323775(12843/15/36)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,206323791(12843/15/52)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,206323838(12843/16/36)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,206323754(12843/15/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,206323754(12843/15/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,206323817(12843/16/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,206323880(12843/17/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,212289552(13214/105/28)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,212289552(13214/105/28)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,228300800(14211/17/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,228300800(14211/17/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,228301763(14211/32/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,228301763(14211/32/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,228301826(14211/33/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,228301826(14211/33/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,228300674(14211/15/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,228300737(14211/16/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,228300799(14211/17/14)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,228300801(14211/17/16)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,228300802(14211/17/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,228300816(14211/17/31)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,228300863(14211/18/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,228300879(14211/18/31)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,228300926(14211/19/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,228302848(14211/49/47)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,228302847(14211/49/46)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,228302850(14211/49/49)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,228302864(14211/49/63)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,228302911(14211/50/47)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,228302927(14211/50/63)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,228302974(14211/51/47)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,228304896(14211/82/16)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,228303543(14211/60/49)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,228303606(14211/61/49)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,228303669(14211/62/49)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,228304895(14211/82/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,228304898(14211/82/18)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,228304912(14211/82/32)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,228304959(14211/83/16)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,228304975(14211/83/32)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,228305022(14211/84/16)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,229468160(14283/186/48)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,229468160(14283/186/48)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,229468159(14283/186/47)) ReadFile Data error (cyclic redundancy check).
file_pread(5,15,buffer,229468161(14283/186/49)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,229468176(14283/187/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,229468223(14283/187/48)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,229468239(14283/188/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,229468286(14283/188/48)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,229470208(14283/219/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,229470207(14283/219/16)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,229470210(14283/219/19)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,229470224(14283/219/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,229470271(14283/220/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,229470287(14283/220/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,229470334(14283/221/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,229472256(14283/251/49)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,229471707(14283/243/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,229471770(14283/244/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,229471833(14283/245/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,229472255(14283/251/48)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,229472258(14283/251/51)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,229472272(14283/252/2)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,229472319(14283/252/49)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,229472335(14283/253/2)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,229472382(14283/253/49)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,229472459(14283/254/63)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,229472459(14283/254/63)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,229472460(14284/0/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,15,buffer,229472461(14284/0/2)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,229472476(14284/0/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,229472523(14284/1/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,229472539(14284/1/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,229472586(14284/2/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,229472526(14284/1/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,229472526(14284/1/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,229472531(14284/1/9)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,229472602(14284/2/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,229472649(14284/3/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,229472529(14284/1/7)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,229472529(14284/1/7)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,231968894(14439/100/60)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,231968896(14439/100/62)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,231970816(14439/131/29)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,231970815(14439/131/28)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,231970818(14439/131/31)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,231970832(14439/131/45)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,231970879(14439/132/29)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,231970895(14439/132/45)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,231970942(14439/133/29)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,231972864(14439/163/61)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,231972863(14439/163/60)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,231972866(14439/163/63)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,231972880(14439/164/14)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,231972927(14439/164/61)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,231972943(14439/165/14)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,231972990(14439/165/61)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,231974912(14439/196/30)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,231974911(14439/196/29)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,231974914(14439/196/32)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,231974928(14439/196/46)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,231974975(14439/197/30)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,231974991(14439/197/46)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,231975038(14439/198/30)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,231999488(14441/76/36)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,231999488(14441/76/36)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,231999487(14441/76/35)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,231999487(14441/76/35)) ReadFile Data error (cyclic redundancy check).
file_pread(5,15,buffer,231999489(14441/76/37)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,231999504(14441/76/52)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,231999551(14441/77/36)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,231999567(14441/77/52)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,231999614(14441/78/36)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232001536(14441/109/5)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232001535(14441/109/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,232001538(14441/109/7)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232001552(14441/109/21)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232001599(14441/110/5)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,232001615(14441/110/21)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,232001662(14441/111/5)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232003584(14441/141/37)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232003583(14441/141/36)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,232003586(14441/141/39)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232003600(14441/141/53)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232003647(14441/142/37)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,232003663(14441/142/53)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,232003710(14441/143/37)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232005632(14441/174/6)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232005631(14441/174/5)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,232005634(14441/174/8)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232005648(14441/174/22)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232005695(14441/175/6)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,232005711(14441/175/22)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,232005758(14441/176/6)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,232015872(14442/81/40)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232015872(14442/81/40)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,232015871(14442/81/39)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232015871(14442/81/39)) ReadFile Data error (cyclic redundancy check).
file_pread(5,15,buffer,232015873(14442/81/41)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232015888(14442/81/56)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232015935(14442/82/40)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,232015951(14442/82/56)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,232015998(14442/83/40)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232017920(14442/114/9)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232017919(14442/114/8)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,232017922(14442/114/11)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232017936(14442/114/25)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232017983(14442/115/9)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,232017999(14442/115/25)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,232018046(14442/116/9)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232019968(14442/146/41)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232019967(14442/146/40)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,232019970(14442/146/43)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232019984(14442/146/57)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232020031(14442/147/41)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,232020047(14442/147/57)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,232020094(14442/148/41)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232022016(14442/179/10)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232022015(14442/179/9)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,232022018(14442/179/12)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232022032(14442/179/26)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232022079(14442/180/10)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,232022095(14442/180/26)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,232022142(14442/181/10)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232024064(14442/211/42)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232024063(14442/211/41)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,232024066(14442/211/44)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232024080(14442/211/58)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232024127(14442/212/42)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,232024143(14442/212/58)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,232024190(14442/213/42)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,232032256(14443/86/44)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232032256(14443/86/44)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,232032255(14443/86/43)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232032255(14443/86/43)) ReadFile Data error (cyclic redundancy check).
file_pread(5,15,buffer,232032257(14443/86/45)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232032272(14443/86/60)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232032319(14443/87/44)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,232032335(14443/87/60)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,232032382(14443/88/44)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232034304(14443/119/13)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232034303(14443/119/12)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,232034306(14443/119/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232034320(14443/119/29)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232034367(14443/120/13)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,232034383(14443/120/29)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,232034430(14443/121/13)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232036352(14443/151/45)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232036351(14443/151/44)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,232036354(14443/151/47)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232036368(14443/151/61)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232036415(14443/152/45)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,232036431(14443/152/61)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,232036478(14443/153/45)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232038400(14443/184/14)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232038399(14443/184/13)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,232038402(14443/184/16)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232038416(14443/184/30)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232038463(14443/185/14)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,232038479(14443/185/30)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,232038526(14443/186/14)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232040448(14443/216/46)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232040447(14443/216/45)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,232040450(14443/216/48)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232040464(14443/216/62)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232040511(14443/217/46)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,232040527(14443/217/62)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,232040574(14443/218/46)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232042496(14443/249/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232042107(14443/243/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232042170(14443/244/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232042233(14443/245/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232042495(14443/249/14)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,232042498(14443/249/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232042512(14443/249/31)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232042559(14443/250/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,232042575(14443/250/31)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,232042622(14443/251/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,232054784(14444/189/18)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232054784(14444/189/18)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232054783(14444/189/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,15,buffer,232054785(14444/189/19)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232054800(14444/189/34)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232054847(14444/190/18)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,232054863(14444/190/34)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,232054910(14444/191/18)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,232366080(14464/30/31)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232366080(14464/30/31)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,232366208(14464/32/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232366208(14464/32/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,232366271(14464/33/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232366271(14464/33/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,232366079(14464/30/30)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232366079(14464/30/30)) ReadFile Data error (cyclic redundancy check).
file_pread(5,15,buffer,232366081(14464/30/32)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232366096(14464/30/47)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232366143(14464/31/31)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,232366159(14464/31/47)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,232366206(14464/32/31)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232368128(14464/62/63)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232367988(14464/60/49)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232368051(14464/61/49)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232368114(14464/62/49)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232368127(14464/62/62)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,232368130(14464/63/2)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232368144(14464/63/16)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232368191(14464/63/63)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,232368207(14464/64/16)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,232368254(14464/64/63)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232370176(14464/95/32)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232370175(14464/95/31)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,232370178(14464/95/34)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232370192(14464/95/48)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232370239(14464/96/32)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,232370255(14464/96/48)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,232370302(14464/97/32)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,232407040(14466/170/41)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232407040(14466/170/41)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232407039(14466/170/40)) ReadFile Data error (cyclic redundancy check).
file_pread(5,15,buffer,232407041(14466/170/42)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232407056(14466/170/57)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232407103(14466/171/41)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,232407119(14466/171/57)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,232407166(14466/172/41)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232409088(14466/203/10)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232409087(14466/203/9)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,232409090(14466/203/12)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232409104(14466/203/26)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232409151(14466/204/10)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,232409167(14466/204/26)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,232409214(14466/205/10)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232411136(14466/235/42)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232411135(14466/235/41)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,232411138(14466/235/44)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232411152(14466/235/58)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232411199(14466/236/42)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,232411215(14466/236/58)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,232411262(14466/237/42)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232413184(14467/13/11)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232411602(14466/243/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232411665(14466/244/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232411728(14466/245/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232412354(14466/254/63)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232412355(14467/0/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,15,buffer,232412356(14467/0/2)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232412371(14467/0/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232412418(14467/1/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,232412434(14467/1/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,232412481(14467/2/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232414403(14467/32/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,13,buffer,232412421(14467/1/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,232412497(14467/2/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,232412544(14467/3/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232414466(14467/33/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232413183(14467/13/10)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232413184(14467/13/11)) ReadFile Data error (cyclic redundancy check).
file_pread(5,15,buffer,232413185(14467/13/12)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232413200(14467/13/27)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232413247(14467/14/11)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,232413263(14467/14/27)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,232413310(14467/15/11)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232415232(14467/45/43)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232413377(14467/16/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232413440(14467/17/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232415231(14467/45/42)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,232415234(14467/45/45)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232415248(14467/45/59)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232415295(14467/46/43)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,232415311(14467/46/59)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,232415358(14467/47/43)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,232454144(14469/153/21)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232454144(14469/153/21)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232454143(14469/153/20)) ReadFile Data error (cyclic redundancy check).
file_pread(5,15,buffer,232454145(14469/153/22)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232454160(14469/153/37)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232454207(14469/154/21)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,232454223(14469/154/37)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,232454270(14469/155/21)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232456192(14469/185/53)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232456191(14469/185/52)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,232456194(14469/185/55)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232456208(14469/186/6)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232456255(14469/186/53)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,232456271(14469/187/6)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,232456318(14469/187/53)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,232478663(14471/32/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232478663(14471/32/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,232478720(14471/33/27)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232478720(14471/33/27)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,232478726(14471/33/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232478726(14471/33/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,232478719(14471/33/26)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232478719(14471/33/26)) ReadFile Data error (cyclic redundancy check).
file_pread(5,15,buffer,232478721(14471/33/28)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232478736(14471/33/43)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232478783(14471/34/27)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,232478799(14471/34/43)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,232478846(14471/35/27)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232480768(14471/65/59)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232480443(14471/60/49)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232480506(14471/61/49)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232480569(14471/62/49)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232480767(14471/65/58)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,232480770(14471/65/61)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232480784(14471/66/12)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232480831(14471/66/59)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,232480847(14471/67/12)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,232480894(14471/67/59)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232482816(14471/98/28)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232482815(14471/98/27)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,232482818(14471/98/30)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232482832(14471/98/44)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232482879(14471/99/28)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,232482895(14471/99/44)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,232482942(14471/100/28)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232484864(14471/130/60)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232484863(14471/130/59)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,232484866(14471/130/62)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232484880(14471/131/13)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232484927(14471/131/60)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,232484943(14471/132/13)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,232484990(14471/132/60)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,232534079(14474/147/9)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232534079(14474/147/9)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,232534095(14474/147/25)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,232534142(14474/148/9)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232536064(14474/178/41)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232536063(14474/178/40)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,232536066(14474/178/43)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232536080(14474/178/57)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232536127(14474/179/41)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,232536143(14474/179/57)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,232536190(14474/180/41)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232538112(14474/211/10)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232538111(14474/211/9)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,232538114(14474/211/12)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232538128(14474/211/26)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232538175(14474/212/10)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,232538191(14474/212/26)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,232538238(14474/213/10)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232540160(14474/243/42)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232540122(14474/243/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232540159(14474/243/41)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,232540162(14474/243/44)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232540176(14474/243/58)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232540223(14474/244/42)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,232540239(14474/244/58)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,232540286(14474/245/42)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232542208(14475/21/11)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232540185(14474/244/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232540248(14474/245/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232540874(14474/254/63)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232540875(14475/0/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,15,buffer,232540876(14475/0/2)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232540891(14475/0/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232540938(14475/1/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,232540954(14475/1/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,232541001(14475/2/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,232540941(14475/1/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232540941(14475/1/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,232540946(14475/1/9)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,232541017(14475/2/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,232541064(14475/3/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,232540944(14475/1/7)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232540944(14475/1/7)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232541834(14475/15/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232541897(14475/16/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232541960(14475/17/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232542207(14475/21/10)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232542208(14475/21/11)) ReadFile Data error (cyclic redundancy check).
file_pread(5,15,buffer,232542209(14475/21/12)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232542224(14475/21/27)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232542271(14475/22/11)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,232542287(14475/22/27)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,232542334(14475/23/11)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,232871936(14495/154/60)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232871936(14495/154/60)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232871935(14495/154/59)) ReadFile Data error (cyclic redundancy check).
file_pread(5,15,buffer,232871937(14495/154/61)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232871952(14495/155/13)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232871999(14495/155/60)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,232872015(14495/156/13)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,232872062(14495/156/60)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,232873984(14495/187/29)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,232873983(14495/187/28)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,232873986(14495/187/31)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232874000(14495/187/45)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,232874047(14495/188/29)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,232874063(14495/188/45)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,232874110(14495/189/29)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,312569855(19456/146/18)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,312569855(19456/146/18)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,312569919(19456/147/19)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,312569935(19456/147/35)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,312569935(19456/147/35)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,312575952(19456/243/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,312577024(19457/5/5)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,312577024(19457/5/5)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,625137664(38913/5/5)) ReadFile The drive cannot find the sector requested.
file_pread(5,2,buffer,625139393(38913/32/33)) lseek err Invalid argument
file_pread(5,1,buffer,625139393(38913/32/33)) lseek err Invalid argument
file_pread(5,2,buffer,625139456(38913/33/33)) lseek err Invalid argument
file_pread(5,1,buffer,625139456(38913/33/33)) lseek err Invalid argument
file_pread(5,7,buffer,625137665(38913/5/6)) lseek err Invalid argument
file_pread(5,1,buffer,625137665(38913/5/6)) lseek err Invalid argument
file_pread(5,16,buffer,625137664(38913/5/5)) ReadFile The drive cannot find the sector requested.
Lito
#4 Post by Lito »
Hi Terry, the fith picture of your post shows the disk partition in green. I think that is good news.
When you get to that screen you could try listing your files by pressing P with the partition highlited.
If you could see your files, you can the proceed to select all the ones you want and save them to a different
disk.
However you must take into account that your log warns you about some errors in the disk.
It might be safer to clone the disk first.
There is another problem. Something stopped TestDisk before it exited normally.
May be it was your own antivirus. I don't know. It could be something else.
That is why the advise was to run TestDisk from a different Operating System.
The one recommended in the troubleshooting pages is Knoppix:
What you download is a raw image file (.iso) of the CD/DVD.
Then you burn it to a CD/DVD with a program like ImgBurn.
Downloading a DVD image takes a lot longer.
To ascertain if there is something else lurking about in your XP rig (i am assuming that is your desktop)
you could try any of these (one at a time):
Kaspersky Rescue CD 10:
http://support.kaspersky.com/viruses/rescuedisk?level=2
Kaspersky Virus Removal Tool
http://www.kaspersky.com/antivirus-removal-tool?form=1
SpyBot Search and Destroy
http://www.safer-networking.org/personal/free-download/
The drivers for the disk are here:
http://wdc.custhelp.com/app/answers/det ... FPc2JhbA==
All in all you could try one more run, until you see the screen of picture number 5.
If it is not possible to get to your files that way, it will be best to either clone the entire disk
using a similar size or a bit larger disk in a healthy state. Another avenue would be
to get an image of the disk using something like Redo-Backup and Recovery, Acronis or Ghost
that you can save anywhere (CD, DVD, a folder in your desktop, etc).
http://www.san.co.uk is offering Ghost for just under twenty pounds right now.
http://redobackup.org/ is free.
That way you can replicate the data in the WD disk at will.
Make sure that there no virus or malware lurking about, otherwise you could be replicating them.
Best of luck
ennyoueffsea
#5 Post by ennyoueffsea »
Hi Lito,
Thanks again for you reply. Sorry for the delay in getting back onto the forum.
I've tried running TestDisk again this time installed on to a seperate external drive.
I've included the screenshots again and the log shows that TestDisk appears to close correctly.
When I've got to picture 7 I don't see how the directory changes as there's no indication of where it's changed to.
I've tried copying files but again no indication where any files have been copied to.
Wed Nov 7 13:39:32 2012
OS: Windows XP SP3
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=500107859968
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=500107859968
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=500105249280
Disk /dev/sdc - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - Seagate Portable, FW:SF04
Failed to read $MFTMirr: No such file or directory.
Failed to read index block: No such file or directory.
NTFS at 0/32/33
file_pread(5,8,buffer,312569848(19456/146/11)) ReadFile Data error (cyclic redundancy check).
dir_partition inode=5
file_pread(5,8,buffer,312569928(19456/147/28)) ReadFile Data error (cyclic redundancy check).
ntfs_readdir failed
5 dr-xr-xr-x 0 0 0 14-Sep-2012 20:24 .
5 dr-xr-xr-x 0 0 0 14-Sep-2012 20:24 ..
ntfs_readdir failed
ntfs_readdir failed
Failed to read $MFTMirr: Input/Output error.
NTFS at 0/32/33
file_pread(5,16,buffer,312569848(19456/146/11)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,312569848(19456/146/11)) ReadFile Data error (cyclic redundancy check).
ntfs_readdir failed
file_pread(5,1,buffer,0(0/0/1)) ReadFile Data error (cyclic redundancy check).
Store new MBR code
NTFS at 0/32/33
Store new MBR code
My daughter has told me she remembered that she has a lot of the lost music files etc on her mp3 player so if easier, wouldn't mind if this drive is formatted, if it can be.
Thanks again,
Terry ;)
Lito
#6 Post by Lito »
Hi Terry,
I am glad that your daughter had a copy of her files saved somewhere else. It does take the pressure off.
Whether you continue tying to get to the damaged disk data as a learning exercise is your call. You could for instance take notes to remind at what stage you are at, leave the task on hold and come back to it later on with a bit more of research done or with a different approach. You also could take your time until you can afford the time to clone the disk.
In the pictures you posted there are no files to be copied (i can only see the directory entries or placeholders). So i do not know what you did copy. As for the where the copied data went, it would be the folder or disk you chose before pressing C in your keyboard. As you still were running TestDisk under Windows it does not matter where you placed the folder containing TestDisk, as long as it was'nt in the disk you are trying to recover.
To cycle trhrough the different disks, directories and folder you have to use the Left and Right arrow keys.
As for things you could do, i did find a few useful sites with relevant information.
http://en.wikipedia.org/wiki/Cyclic_redundancy_check
Mainly info about the errors you see in the logs you posted.
http://www.wikihow.com/Fix-a-Cyclic-Red ... heck-Error
Advise on how to go about fixing this from a Windows perspective.
There is also a mention to either system corruption and/or impending disk failure.
http://linuxexpresso.wordpress.com/2011 ... in-ubuntu/
How to deal with a ntfs partition from Linux. It does point as well to Parted Magic.
Parted Magic is a very useful tool disk to have. You can run the fix described in the blog directly from the Parted Magic
shell (very easy to access and launch) since ntfsprogs is already installed. All you need is to burn your own copy
of this CD. It also contains PhotoRec and TestDisk. A list of the programmes it carries is in their website.
http://www.minitool-partitionrecovery.com/download.html
MiniTool to recover partitions. I have never tried this myself, but if their MiniTool Partition Wizard is anything to go by i'm sure it will work as advertised. There is a risk of introducing further damage to your disk. But this risk is also present in all the fixes listed in this post.
The best thing you could do is to clone your disk, and then try fixing the clone.
http://www.partitionwizard.com/download.html
This last page is to download a CD image (free) of MiniTool Partition Wizard.
With this tool you could try copying the whole partition to another empty disk therefore cloning it.
It might take a while to do so and there is the chance that it may fail due to errors in your disk.
However is a very useful disk to have. Is system independent and is pleasing to the eye.
It makes Windows users feel at home because everything is visually pleasing.
If in the end you decide to end the project and wipe your problem disk, this is your tool.
Best of luck
ennyoueffsea
#7 Post by ennyoueffsea »
Hi Lito,
Thanks again for your speedy reply.
As you say, it really has taken the pressure off knowing she has found the copies of her files. Just wish she'd found them sooner.:-D
With her having so much of the data I'm inclined to just try to format the drive and hopefully make it useable again.
I've been struggling time wise because of work so haven't been able to spend the time I would have liked to.
Could such a format be carried out using TestDisk seeing as Windows is unable to detect the drive?
Many thanks again.
Terry ;-)
Lito
#8 Post by Lito »
Hi Terry,
the short answer is no.
Look at the opening page for TestDisk:
"TestDisk is powerful free data recovery software! It was primarily designed to help recover lost partitions and/or make non-booting disks bootable again when these symptoms are caused by faulty software, certain types of viruses or human error (such as accidentally deleting a Partition Table). Partition table recovery using TestDisk is really easy."
I think having a format function would defeat the main purposes of this software.
I think it goes as far a having an option to delete the partition information, but you still would have to use Windows to do the formatting or any software that can manage disks.
As far as I remember you mentioned that Windows does show the green icon in the taskbar to remove the device safely.
That means that Windows does recognise the disk when connected. Going by my experience with this type of disk from WD, there is a design flaw in the connection of the cable, it is very flimpsy. Some times it connects properly, some other times it does not. It depends on how you place the disk and the very short cable they provide. For this reason alone you are prone to loose power to the drive, enough to make it go bananas and fail with all sort of problems.
I would not recommend to anybody buying any of this Passport type disk from WD.This is a long standing problem and they do not have implemented any real fix as yet.
If Windows does not see the drive, try another USB port. You can also try placing the disk in a different position so there is a bit of pressure in the loop of the connecting cable over the connector. In any case the drive has got a little light. If you do not see the light in the drive, the operating system would not recognise the disk.
Before you format have a look a this TestDisk page:
http://www.cgsecurity.org/wiki/TestDisk ... filesystem
Under the - How to check and repair a filesystem subheading, there a recommendation to run chkdsk /f yourdrive:
It is worth a try since your logs indicate a problem with your NTFS file system.
Microsoft also has some explanations on how to run chkdsk, here:
http://support.microsoft.com/kb/315265#method2
You could leave chkdsk running overnight. The next day, the process would have hopefully finished. You can switch off and then reboot to see if there is an improvement.
If your heart is still set on reformatting the best thing you can do is to get this tool:
Download and burn to a CD using a programme such as ImgBurn, Nero, Sonic, etc.
At the end you wiil have a bootable CD to work with your problem disk or any others.
With a few clicks you will be able to delete partitions, create partions, wipe clean disks, visualise files in a partition to prove to yourself that they can be recoverable, clone a disk, etc.
All of that for very little effort and the price of a blank CD.
Best of luck
#9 Post by cgrenier »
There are a lot of bad sectors (see the CRC errors). This problem can't be repaired.
To recover a maximum of data, you should clone the disk to a new empty one as described in
http://www.cgsecurity.org/wiki/Damaged_Hard_Disk Once it's done, remove the damaged disk, try to repair the filesystem on the clone and if it doesn't work, run PhotoRec.
Bicgatepc02
#10 Post by Bicgatepc02 »
If you have your files, save it in another place, remove the disk from the WDbox, re-format the disk (eventually do a 1-pass zero before), and copy the file again on it.
__________________________________________________________
Thl ThL W3+ ThL W2+
