chkdsk F: /iI tried to mount the HDD on my Ubuntu 10.04 system in case it works. However I got the following message
http://i.imgur.com/GNzA9.png
I then tried to fix this issue using testdisk.
The log from my first attempt is the following
Fri Oct 26 14:10:57 2012
TestDisk 6.11, Data Recovery Utility, April 2009
OS: Linux, kernel 2.6.32-43-generic (#97-Ubuntu SMP Wed Sep 5 16:42:26 UTC 2012)
Compiler: GCC 4.4 - Jun 23 2009 17:48:38
ext2fs lib: 1.41.11, ntfs lib: 10:0:0, reiserfs lib: none, ewf lib: none
/dev/sda: size 488281250 sectors
/dev/sda: user_max 488281250 sectors
/dev/sda: native_max 488281250 sectors
/dev/sda: dco 488281250 sectors
/dev/sdb: size 488281250 sectors
/dev/sdb: user_max 488281250 sectors
/dev/sdb: native_max 488281250 sectors
/dev/sdb: dco 488281250 sectors
Disk /dev/sda - 250 GB / 232 GiB - CHS 30394 255 63, sector size=512 - ATA WDC WD2500AAJS-7
Disk /dev/sdb - 250 GB / 232 GiB - CHS 30394 255 63, sector size=512 - ATA WDC WD2500AAJS-7
TestDisk exited normally.I pressed enter and then selected "Intel" in the "Partition Table Type". Next I pressed "Advanced" but there was a statement "No partition available". So I got back and selected "Analyse". A message was there stating that "Partition Read Error". Despite that I selected "Quick search". So something started to happening.
I should mention that my HDD is 2000Gb while the total cylinders that testdisk could access were ~250Gb...
When this ended there was a message saying "Strucrure OK" so I selected for a "Deeper search". When this came to an end another message was stating that "No partition found or selected for recovery".
The log from this procedure is bery big ~3GB and I cannot copy it because while loading it kills itself.
I tried another time with "Advanced". At that point I saw one partition. I entered using "list" and I saw only one folder of all. The log from the previous procedure is
Sat Oct 27 10:51:01 2012
OS: Linux, kernel 2.6.32-42-generic (#95-Ubuntu SMP Wed Jul 25 15:56:09 UTC 2012)
/dev/sda: size 488397168 sectors
/dev/sda: user_max 488397168 sectors
/dev/sda: native_max 488397168 sectors
/dev/sda: dco 488397168 sectors
Disk /dev/sda - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - ATA WDC WD2500BEVS-2
Disk /dev/sdd - 4009 MB / 3824 MiB - CHS 1018 124 62, sector size=512 - FLASH Drive SM_USB20
Disk /dev/sde - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - Seagate Desktop
Disk /dev/sde - 2000 GB / 1863 GiB - Seagate Desktop
NTFS at 0/1/1
1 P HPFS - NTFS 0 1 1 243200 254 63 3907024002 [Expansion Drive]
NTFS, 2000 GB / 1863 GiB
ntfs_boot_sector
NTFS at 0/1/1
file_pread(6,16,buffer,3907024064(243200/254/63)) read err: Input/output error
filesystem size 3907024002 1
sectors_per_cluster 8 0
mft_lcn 786432 0
mftmirr_lcn 244189000 0
clusters_per_mft_record -10 0
clusters_per_index_record 1 0
Status: OK
ntfs_boot_sector: Can't read backup boot sector.
Status: Bad
Sectors are not identical.
Failed to read $MFTMirr: Input/output error.
Failed to read index block: Input/output error.
file_pread(6,8,buffer,1953512063(121600/127/63)) read err: Input/output error
file_pread(6,8,buffer,1953512143(121600/129/17)) read err: Input/output error
ntfs_readdir failed
5 dr-xr-xr-x 0 0 0 25-May-2011 23:32 .
5 dr-xr-xr-x 0 0 0 25-May-2011 23:32 ..
62 dr-xr-xr-x 0 0 0 5-Aug-2011 22:16 ElectroMagnetism
file_pread(6,8,buffer,660335(41/26/33)) read err: Input/output error
ntfs_readdir failed
Directory /ElectroMagnetism
62 dr-xr-xr-x 0 0 0 5-Aug-2011 22:16 .
ntfs_readdir failed
ntfs_readdir failed
ntfs_readdir failed
ntfs_readdir failed
ntfs_readdir failed
ntfs_readdir failed
ntfs_readdir failed
ntfs_readdir failed
ntfs_readdir failed
ntfs_readdir failed
ntfs_readdir failed
ntfs_boot_sector
NTFS at 0/1/1
mft_lcn 786432 0
Status: OK
Status: Bad
Failed to read $MFTMirr: Input/output error.Thank you in advance!
