Photorec doesn't find one of partitions (partition is OK!)
Wojciech
#1 Post by Wojciech »
(sorry for my bad english)
I'm trying to recover some photos I deleted by mistake. My configuration: 2 x 1TB HD in RAID, divided to 4 partitions: 1x200GB (system - C:) , 3x600GB (D:, E:, G:). Photorec works great on C:, D:, G:, but it doesn't see E: partition. The E: drive is completely OK, I can see it in windows, files are OK, so why doesn't Photorec see it? I even tried to run the program from the missing partition, and it works, but still doesn's see it (although I can choose E: as a save folder for recovered files).
As You see, program is running on the drive E:
(K: is an external USB drive)
Re: Photorec doesn't find one of partitions (partition is OK
If the drive letter isn't displayed, select the physicaldrive0 and next the partition.
