Cannot find FLA in file list
eastty12
#1 Post by eastty12 »
On the photorec wiki it says supports .fla files also, but when I run it, I can't find .fla in the file type list! The vresion i using is PhotoRec 6.14-WIP.
Re: Cannot find FLA in file list
Flash .fla are using the same basic structure than .doc files, you need to enable this file family.
