My 500gb external hard disk isn't working anymore, so I ran testdisk on it.
Drive F: - 500 GB / 465 GiB
CHS 60797 255 63 - sector size=512
According to the TestDisk Step by Step guide, I chose the 'Analyse' option.
It says Partition: Read error
I chose the only option available 'Quick Search'. After it is done, the 'partition', 'start', 'end', 'size in sectors' sections are still blank.
The options are:
Keys A: add partition, L: load backup, Enter: to continue
I pressed enter.
It says 'No partition found or selected for recovery'
The options are:
'Quit', 'Deeper Search'
I chose deeper search.
The options are:
What should I do now to recover my data?
Thanks
Testdisk read error
Re: Testdisk read error
If possible, select the physical drive instead of the drive letter.
