deep search from specific point
brendan
#1 Post by brendan »
Hello everybody
TestDisk is great software. Thank you very much Christophe for working on it.
I have a question about searching or scanning for partitions through the "Analyse" menu, particularly in deep search.
Is it possible, with command line arguments, or any method, to start the search / scan from a specific point on the hard disk?
It would be useful on large drives if you could skip the first 1/4 or 1/2 or 3/4 of the disk.
Thank you very much
Brendan
zonk
Re: deep search from specific point
#2 Post by zonk »
Yep, I also want such a feature.
TestDisk just finished a deep search that took ages and then I accidently closed the program. Luckily - or so I thought! - I had the partition's location etc. that TeskDisk found saved. But that seems of no use since the program can't limit the search to a certain range of cylinders. I think as a workaround it is possible to make some sort of virtual disk that gets shown to TestDisk that only shows a part of the whole disk to it, so that TestDisk would only work on that smaller part.
#3 Post by Fiona »
TestDisk doesn't start searching from a specific point.
There is a trick, if testdisk found a partition and you can recognize it by the label so that you want to recover it, you can jump to the end of the partition by pressing F (upper case) for forward.
If you're looking for more partitions, testdisk will keep searching for.
Maybe it helps to save you time?
