Repairing MFT on single 2TB drive
rlively
#1 Post by rlively »
I have a Western Digital Caviar Green 2TB drive WDC WD20EARS-00J2GB0 (WD-WCAYY0004653) that has been corrupted in a machine I have that continuously BSODs. Chkdsk says it cannot check this drive because of a corrupt MFT.
I ran TestDisk on a different machine and the quick search found nothing, but the deep search found the partition. It was formatted as a single 2TB NTFS partition, but the output references FAT16 as well as HPFS - NTFS.
What is the next step? Do I Repair An NTFS MFT as outlined under http://www.cgsecurity.org/wiki/Advanced ... n_NTFS_MFT?
The output in the command window is:
Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 3876021 16 63
Analyse cylinder 2354442/3876020: 60%
  HPFS - NTFS              0   1  1 3876017  15 63 3907026081
Invalid FAT boot sector
 0 D FAT16 <32M           3404673   4  2 7272090   0 23 3898356106
Warning: Incorrect number of heads/cylinder 2 (FAT) != 16 (HD)
Warning: Incorrect number of sectors per track 18 (FAT) != 63 (HD)
  FAT12                1918471   1  1 1918473  14 45       2880 [W2PSEB4_EN]
Re: Repairing MFT on single 2TB drive
If you run TestDisk, Advanced, Boot, List, can you list your files ? If it doesn't work, try RepairMFT.
rlively
#3 Post by rlively »
After the deep search finished, this is the output:
The harddisk (2000 GB / 1863 GiB) seems too small! (< 3753 GB / 3495 GiB)
   FAT12                5614350  11 44 6784725   4 17 1179737533
   FAT12                5931253   3 62 5931314   7 30      61709
If I try to list files," I get:
Repair MFT gives:
rlively
#4 Post by rlively »
Should I try changing the geometry as suggested by this output, or is that not necessary since the deep search did find the partition?
Warning: the current number of heads per cylinder is 16
but the correct value may be 32.
You can use the Geometry menu to change this value.
It's something to try if
- some partitions are not found by TestDisk
- or the partition table can not be written because partitions overlaps.
rlively
#5 Post by rlively »
Here's the output from the systemrescuecd commands - I don't know if this helps to shed any more light on the problem:
% archiver probe simple
[======DISK======] [=============NAME==============] [====SIZE====] [MAJ] [MIN]
[sdb             ] [WDC WD20EARS-00J               ] [     1.82 TB] [  8] [ 16]
[=====DEVICE=====] [==FILESYS==] [======LABEL======] [====SIZE====] [MAJ] [MIN]
[sdb1            ] [<unknown>  ] [<unknown>        ] [     1.82 TB] [  8] [ 17]
% mount -t ntfs /dev/sdb1 /mnt/2TB
mount: wrong fs type, bad option, bad superblock on /dev/sdb1,
       missing codepage or helper program, or other error
       In some cases useful info is found in syslog - try
       dmesg | tail  or so
% fdisk -l /dev/sdb
Disk /dev/sdb: 2000.4 GB, 2000398934016 bytes
16 heads, 63 sectors/track, 3876021 cylinders, total 3907029168 sectors
Disk identifier: 0xe66d33e1
   Device Boot      Start         End      Blocks   Id  System
/dev/sdb1   *          63  3907026143  1953513040+   7  HPFS/NTFS/exFAT
#6 Post by Fiona »
Looks like youre geometry doesn't match?
Currently your disk has 16 heads per cylinder;
Mostly, it would be 255 heads.
Can you repeat your diagnose and using 255 heads?
It's only a diagnose.
Nothing will be changed.
Start Testdisk.
Confirm to create a log, select your harddrive and proceed until you see the menu Analyse.
Don't confirm at Analyse but Geometry.
Highlight Heads and hit Enter.
Change the value from 16 to 255.
Don't change anything else.
Check OK and press enter to oleave the menu.
Go to Analyse.
Repeat your diagnose.
rlively
#7 Post by rlively »
Hi Fiona, thanks for the reply. I made the changes you suggested - the output from the log is below. Attempting to list the files still gives the "Can't open filesystem. Filesystem seems damaged" error.
The message for the Geometry that says that current heads per sector is 16 "but the correct value may be 32" - where did the suggestion for 32 come from, how did you come up with the suggestion for 255, and how can I determine for a fact what it should be?
Wed Mar 21 23:04:53 2012
OS: Windows XP SP3
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=1948254208
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=1948254208
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=214745577984
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=627341312
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=2000397353472
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=1948182016
filewin32_getfilesize(\\.\I:) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\I:) SetFilePointer err Incorrect function.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\S:)=285359639040
file_pread(4,1,buffer,976784129(60801/254/63)) lseek err Invalid argument
file_pread(5,1,buffer,3907030175(3876021/15/63)) lseek err Invalid argument
file_pread(6,1,buffer,3807404(236/254/63)) lseek err Invalid argument
Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 3876021 16 63, sector size=512 - WDC WD20EARS-00J2GB0, FW:80.00A80
Disk /dev/sdb - 2000 GB / 1863 GiB - WDC WD20EARS-00J2GB0
New geometry
Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 243202 255 63 sector_size=512
Analyse Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 243202 255 63
Geometry from i386 MBR: head=16 sector=63
NTFS at 0/1/1
Warning: Incorrect number of heads/cylinder 16 (NTFS) != 255 (HD)
 1 * HPFS - NTFS              0   1  1 243201  32 63 3907026081
Ask the user for vista mode
search_vista_part: 0
NTFS at 0/1/1
filesystem size           3907026081
sectors_per_cluster       8
mftmirr_lcn               244189130
clusters_per_mft_record   -10
     NTFS, 2000 GB / 1863 GiB
file_pread(5,8,buffer,3907029183(243201/81/16)) lseek err Invalid argument
file_pread(5,1,buffer,3907029183(243201/81/16)) lseek err Invalid argument
file_pread(5,8,buffer,3907029311(243201/83/18)) lseek err Invalid argument
file_pread(5,8,buffer,3907029439(243201/85/20)) lseek err Invalid argument
file_pread(5,8,buffer,3907029567(243201/87/22)) lseek err Invalid argument
file_pread(5,8,buffer,3907029695(243201/89/24)) lseek err Invalid argument
file_pread(5,8,buffer,3907029823(243201/91/26)) lseek err Invalid argument
file_pread(5,8,buffer,3907029951(243201/93/28)) lseek err Invalid argument
file_pread(5,8,buffer,3907030079(243201/95/30)) lseek err Invalid argument
file_pread(5,8,buffer,3907030207(243201/97/32)) lseek err Invalid argument
file_pread(5,8,buffer,3907030335(243201/99/34)) lseek err Invalid argument
file_pread(5,8,buffer,3907030463(243201/101/36)) lseek err Invalid argument
file_pread(5,8,buffer,3907030591(243201/103/38)) lseek err Invalid argument
file_pread(5,8,buffer,3907030719(243201/105/40)) lseek err Invalid argument
file_pread(5,8,buffer,3907030847(243201/107/42)) lseek err Invalid argument
file_pread(5,8,buffer,3907030975(243201/109/44)) lseek err Invalid argument
file_pread(5,8,buffer,3907031103(243201/111/46)) lseek err Invalid argument
file_pread(5,8,buffer,3907031231(243201/113/48)) lseek err Invalid argument
file_pread(5,8,buffer,3907031359(243201/115/50)) lseek err Invalid argument
file_pread(5,8,buffer,3907031487(243201/117/52)) lseek err Invalid argument
file_pread(5,8,buffer,3907031615(243201/119/54)) lseek err Invalid argument
file_pread(5,8,buffer,3907031743(243201/121/56)) lseek err Invalid argument
file_pread(5,8,buffer,3907031871(243201/123/58)) lseek err Invalid argument
file_pread(5,8,buffer,3907031999(243201/125/60)) lseek err Invalid argument
file_pread(5,8,buffer,3907032127(243201/127/62)) lseek err Invalid argument
file_pread(5,8,buffer,3907032255(243201/130/1)) lseek err Invalid argument
file_pread(5,8,buffer,3907032383(243201/132/3)) lseek err Invalid argument
file_pread(5,8,buffer,3907032511(243201/134/5)) lseek err Invalid argument
file_pread(5,8,buffer,3907032639(243201/136/7)) lseek err Invalid argument
file_pread(5,8,buffer,3907032767(243201/138/9)) lseek err Invalid argument
file_pread(5,8,buffer,3907032895(243201/140/11)) lseek err Invalid argument
file_pread(5,8,buffer,3907033023(243201/142/13)) lseek err Invalid argument
file_pread(5,8,buffer,3907033151(243201/144/15)) lseek err Invalid argument
file_pread(5,8,buffer,3907033279(243201/146/17)) lseek err Invalid argument
file_pread(5,8,buffer,3907033407(243201/148/19)) lseek err Invalid argument
file_pread(5,8,buffer,3907033535(243201/150/21)) lseek err Invalid argument
file_pread(5,8,buffer,3907033663(243201/152/23)) lseek err Invalid argument
file_pread(5,8,buffer,3907033791(243201/154/25)) lseek err Invalid argument
file_pread(5,8,buffer,3907033919(243201/156/27)) lseek err Invalid argument
file_pread(5,8,buffer,3907034047(243201/158/29)) lseek err Invalid argument
file_pread(5,8,buffer,3907034175(243201/160/31)) lseek err Invalid argument
file_pread(5,8,buffer,3907034303(243201/162/33)) lseek err Invalid argument
file_pread(5,8,buffer,3907034431(243201/164/35)) lseek err Invalid argument
file_pread(5,8,buffer,3907034559(243201/166/37)) lseek err Invalid argument
file_pread(5,8,buffer,3907040130(243202/0/1)) lseek err Invalid argument
file_pread(5,8,buffer,3907040138(243202/0/9)) lseek err Invalid argument
file_pread(5,3,buffer,3907040146(243202/0/17)) lseek err Invalid argument
file_pread(5,3,buffer,3907040193(243202/1/1)) lseek err Invalid argument
file_pread(5,8,buffer,3907040209(243202/1/17)) lseek err Invalid argument
file_pread(5,11,buffer,3907040256(243202/2/1)) lseek err Invalid argument
file_pread(5,2,buffer,3907042178(243202/32/33)) lseek err Invalid argument
Warning: the current number of heads per cylinder is 255 but the correct value may be 32.
   * HPFS - NTFS              0   1  1 243201 254 63 3907040067
 1 * HPFS - NTFS              0   1  1 243201 254 63 3907040067
Incomplete multi sector transfer detected in $MFT.
ntfs_mft_load(): Failed.
NTFS at 0/1/1
recover_EXT2: s_block_group_nr=0/60, s_mnt_count=4/37, s_blocks_per_group=32768, s_inodes_per_group=8176
recover_EXT2: s_blocks_count 1994060
recover_EXT2: part_size 15952480
     Linux                171823   1  1 172815 254 61   15952480
     EXT3 Large file Sparse superblock Recover, 8167 MB / 7789 MiB
file_pread(5,2,buffer,3907039377(243201/243/4)) lseek err Invalid argument
file_pread(5,2,buffer,3907039440(243201/244/4)) lseek err Invalid argument
file_pread(5,2,buffer,3907039503(243201/245/4)) lseek err Invalid argument
file_pread(5,1,buffer,3907040129(243201/254/63)) lseek err Invalid argument
file_pread(5,1,buffer,3907040130(243202/0/1)) lseek err Invalid argument
get_geometry_from_list_part_aux head=255 nbr=3
     Linux                171823   1  1 172815 254 63   15952482
Not an exFAT boot sector.
#8 Post by Fiona »
The TestDisk algorithm reports the value of 32.
But my experience is, normally 3.5 inches hdd's using 255 heads per cylinder.
Infos;
http://www.cgsecurity.org/wiki/Menu_Geo ... f_heads.3F
Your geometry fits now.
But it looks like your file system is damaged.
If file system is damaged, datarevovery software would be appropriate.
You can test PhotoRec and if you're not satisfy with, have a look at commercial software.
