No Partition Found on External Drive
solitaryxsoul
#1 Post by solitaryxsoul »
I have the WD Smartware Passport Essentials USB 2.0
After I unlocked the external drive, it shows "No writable WD Smartware partition found," and I could not access my data.
Note: I tried using Testdisk on the drive on my laptop, and then on my desktop computer. Would this have been a problem?
I used the Testdisk, and it showed me:
-Disk/dev/sda-250GB/232GiB-WDC WD2500JB-00REA0
-Disk/dev/sdf-499GB/ 465 GiB- WD My Passport 07A
-Drive F: -700MB/ 668MiB- WD Virtual CD 070A
The first choice is my desktop computer, and I did not know which one was the problem so I analyzed both the DIsk/dev/sdf and the Drive F.
It showed me Partition Read Error, and Deeper Search would have taken around 500hours to finish, so I only analyzed a little.
How should I fix my external drive and get all my data back?
Please do help, and thank you for reading.
Below are the two logs, one for the disk, and one for the drive.
Disk:
Mon Dec 17 09:21:48 2012
OS: Windows XP SP3
Compilation date: 2012-11-19T10:50:14
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdf)=499405291520
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive5)=499405291520
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=250048479744
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=700448768
filewin32_getfilesize(\\.\H:) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\H:) SetFilePointer err Incorrect function.
filewin32_getfilesize(\\.\I:) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\I:) SetFilePointer err Incorrect function.
filewin32_getfilesize(\\.\K:) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\K:) SetFilePointer err Incorrect function.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\L:)=499404242944
Disk /dev/sda - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - WDC WD2500JB-00REA0, FW:20.00K20
Disk /dev/sdf - 499 GB / 465 GiB - CHS 60715 255 63, sector size=512 - WD My Passport 070A, FW:2018
Drive F: - 700 MB / 668 MiB - CHS 167 64 32, sector size=2048 - WD Virtual CD 070A, FW:2018
Disk /dev/sdf - 499 GB / 465 GiB - WD My Passport 070A
Analyse Disk /dev/sdf - 499 GB / 465 GiB - CHS 60715 255 63
Partition: Read error
file_pread(5,16,buffer,32(0/0/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,48(0/0/49)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,95(0/1/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,111(0/1/49)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,158(0/2/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,2080(0/33/2)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,51(0/0/52)) ReadFile The request could not be performed because of an I/O device error.
(continues on...)
file_pread(5,1,buffer,0(0/0/1)) ReadFile The request could not be performed because of an I/O device error.
Store new MBR code
Drive:
Mon Dec 17 10:34:06 2012
OS: Windows XP SP3
Drive F: - 700 MB / 668 MiB - WD Virtual CD 070A
Analyse Drive F: - 700 MB / 668 MiB - CHS 167 64 32
