TestDisk doesn't find drive
siris
#1 Post by siris »
just downloaded TestDisk because my 1TB WD Elements doesn't show up anymore.
I copied two big folders the other day, and during the copy process it gave i/o errors. Cancelled the copy and unplugged the hard drive, and since then it doesn't read anymore.
It shows in the device manager, but not in 'my computer'.
The first time i plugged it back in, Windows7 told me the disk needed formatting, so i cancelled and unplugged it. Since then it doesn't show up anymore at all (except for in the device manager).
In the Mac the hard drive shows not as a drive, but as an empty folder, when i plug it in. Can't run Disk Utility on it, it's greyed out there (and it was read-only for Mac since it must have been NTFS formatted).
Downloaded TestDisk and ran it with the WD plugged in, but no results - TestDisk just displays 'Please wait...' and nothing is happening or showing. Any ideas?
Re: TestDisk doesn't find drive
I'd need infos about your file system.
RAW means no file system but only a partition.
Don't format it, otherwise you'll overwrite your previous file system.
Can you upload a screen from TestDisk after Analyse?
It's your current partiton structur (partition table).
If your partition is ok, than you'll only need a boot sector diagnose.
Infos will follow.
siris
#3 Post by siris »
Hi Fiona,
Thanks for the reply.
Ran TestDisk again and got the following result page -
https://picasaweb.google.com/1108804152 ... 1446405458
#4 Post by Fiona »
I'd need one screen earlier from your current partition structur (your partition table).
On your current screen, please press p to list your files.
Do you see your files or an error message?
siris
#5 Post by siris »
This is the file list:
https://picasaweb.google.com/1108804152 ... 0342466642
https://picasaweb.google.com/1108804152 ... 9934013634
Not sure which previous screen you refered to - am just running TestDisk again from scratch to take screenshots of all screens that come. Will upload asap.
Thanks Fiona.
#6 Post by Fiona »
Confirm through until you see the menu Analyse.
Press enter to proceed.
I'd need this screen.
This is your partition table.
Also you can see a description called "current partition structur".
It's important to check it for errors.
This screen is the result from Quick Search;
There is nothing wrong.
Files are listed also;
In case, you can copy your files to another partition or disk.
At the bottom of the screen you can see the commands.
Don't write or copy anything to your affected drive.
