Speed of recovery by limiting file types?
pokee
#1 Post by pokee »
Will the recovery process be sped up if I were to limit the files I wanted to recover to only a few types rather than all of the default files being left in?
Re: Speed of recovery by limiting file types?
Might be depend on the size of your space from your disk.
You can use PhotRec and File Opt.
Pressing s (select) will deselect all file types.
So you can only mark your appreciated ones for recovery.
