Fat32/Logical Volume Management
I deleted a large directory (Thousands of files totaling about 10GB) on my HP touchpad's "USB Drive" (/media/internal on a flash drive). This 'drive' is Fat32 formatted, but then LVM takes over, and zeros-out the Fat32 partition tables. So testdisk starts out by saying there are no partitions, and eventually suggests C:H:S of 3593:255:63, but this fails. How do I proceed?  On one trial I actually saw some deleted files being copied out, but I don't know how I got there.
						Re: Fat32/Logical Volume Management
To elaborate, there is probably nothing wrong with my partitioning or filesystems, and testdisk apparently understands LVM2, but I'm baffled at how to proceed. I've tried "testdisk /dev/mmcblk0p14" and "testdisk /dev/mapper/store-media", but it can't find those (on a Windows machine). I can get information on my LVM2 using 'lv-commands' and from LVM logs, but what specific info do I need, and how do I pass it to testdisk? (Again, I apparently had files being recovered at one time, but unfortunately I didn't keep track of  how I got there).
Here are the logs from two attempts (the second much deleted):
Intel  Analyze Quicksearch  No partitions found
and
None  Analyze  Quicksearch  Structure OK
The deleted directory was named “/.tfj” (note the dot); I think when it does show, it’s something like “~FJ”, but (usually) no files display within it.
Intel  Analyze Quicksearch  No partitions found:
Tue Jan 29 14:16:27 2013
TestDisk 6.14-WIP, Data Recovery Utility, December 2012
OS: Windows XP SP3
Compiler: GCC 4.6, Cygwin 1007.17
Compilation date: 2013-01-06T21:07:12
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=80000000000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=1004535808
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=29553065984
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=80000000000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=1004535808
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=29553065984
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=47862872064
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=1004472320
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=29553065984
Disk /dev/sda - 80 GB / 74 GiB - CHS 9726 255 63, sector size=512 - WDC WD800JD-75MSA3, FW:10.01E04
Disk /dev/sdb - 1004 MB / 958 MiB - CHS 122 255 63, sector size=512 - Multi Flash Reader, FW:1.00
Disk /dev/sdc - 29 GB / 27 GiB - CHS 3592 255 63, sector size=512 - HP webOS-device, FW:0327
Disk /dev/sdc - 29 GB / 27 GiB - HP webOS-device
Analyse Disk /dev/sdc - 29 GB / 27 GiB - CHS 3592 255 63
file_pread(6,2,buffer,57720832(3592/243/44)) ReadFile The drive cannot find the sector requested.
file_pread(6,1,buffer,57720832(3592/243/44)) ReadFile The drive cannot find the sector requested.
file_pread(6,15,buffer,57720833(3592/243/45)) lseek err Invalid argument
file_pread(6,3,buffer,57720848(3592/243/60)) lseek err Invalid argument
file_pread(6,3,buffer,57720895(3592/244/44)) lseek err Invalid argument
file_pread(6,8,buffer,57720911(3592/244/60)) lseek err Invalid argument
file_pread(6,11,buffer,57720958(3592/245/44)) lseek err Invalid argument
file_pread(6,2,buffer,57722880(3593/21/13)) lseek err Invalid argument
None  Analyze  Quicksearch  Structure OK:
Tue Jan 29 14:32:15 2013
OS: Windows XP SP3
Partition table type: None
FAT32 at 0/0/1
FAT1 : 66-6465
FAT2 : 6466-12865
start_rootdir : 18690 root cluster : 93
Data : 12866-52428737
sectors : 52428800
cluster_size : 64
no_of_cluster : 818998 (2 - 818999)
fat_length 6400 calculated 6399
heads/cylinder 0 (FAT) != 255 (HD)
sect/track 0 (FAT) != 63 (HD)
FAT32 at 0/0/1
FAT32 at 0/0/1
Info: size boot_sector 52428800, partition 57720832
FAT1 : 66-6465
FAT2 : 6466-12865
sectors : 52428800
cluster_size : 64
Warning: number of heads/cylinder mismatches 0 (FAT) != 255 (HD)
Warning: number of sectors per track mismatches 0 (FAT) != 63 (HD)
P FAT32 0 0 1 3592 243 43 57720832 [HP TOUCHPAD]
FAT32 at 0/0/1
FAT1 : 66-6465
FAT2 : 6466-12865
sectors : 52428800
cluster_size : 64
FAT32 at 0/0/1
FAT32 0 0 1 3263 138 11 52428800 [HP TOUCHPAD]
FAT32, blocksize=32768, 26 GB / 25 GiB
file_pread(6,1,buffer,57720833(3592/243/45)) lseek err Invalid argument
file_pread(6,1,buffer,57720834(3592/243/46)) lseek err Invalid argument
filefile_pread(6,1,buffer,57722518(3593/15/29)) lseek err Invalid argument
file_pread(6,1,buffer,57722519(3593/15/30)) lseek err Invalid argument
file_pread(6,1,buffer,57722520(3593/15/31)) lseek err Invalid argument
file_pread(6,1,buffer,57722521(3593/15/32)) lseek err Invalid argument
file_pread(6,1,buffer,57722522(3593/15/33)) lseek err Invalid argument
file_pread(6,1,buffer,57722523(3593/15/34)) lseek err Invalid argument
file_pread(6,1,buffer,57722524(3593/15/35)) lseek err Invalid argument
file_pread(6,1,buffer,57722525(3593/15/36)) lseek err Invalid argument
file_pread(6,1,buffer,57722526(3593/15/37)) lseek err Invalid argument
file_pread(6,1,buffer,57722527(3593/15/38)) lseek err Invalid argument
file_pread(6,1,buffer,57722528(3593/15/39)) lseek err Invalid argument
file_pread(6,1,buffer,57722529(3593/15/40)) lseek err Invalid argument
file_pread(6,1,buffer,57722530(3593/15/41)) lseek err Invalid argument
file_pread(6,1,buffer,57722531(3593/15/42)) lseek err Invalid argument
file_pread(6,1,buffer,57722532(3593/15/43)) lseek err Invalid argument
file_pread(6,1,buffer,57722533(3593/15/44)) lseek err Invalid argument
file_pread(6,1,buffer,57722534(3593/15/45)) lseek err Invalid argument
file_pread(6,1,buffer,57722535(3593/15/46)) lseek err Invalid argument
file_pread(6,1,buffer,57722536(3593/15/47)) lseek err Invalid argument
file_pread(6,1,buffer,57722537(3593/15/48)) lseek err Invalid argument
file_pread(6,1,buffer,57722538(3593/15/49)) lseek err Invalid argument
file_pread(6,1,buffer,57722539(3593/15/50)) lseek err Invalid argument
file_pread(6,1,buffer,57722540(3593/15/51)) lseek err Invalid argument
file_pread(6,1,buffer,57722541(3593/15/52)) lseek err Invalid argument
file_pread(6,1,buffer,57722542(3593/15/53)) lseek err Invalid argument
file_pread(6,1,buffer,57722543(3593/15/54)) lseek err Invalid argument
file_pread(6,1,buffer,57722544(3593/15/55)) lseek err Invalid argument
file_pread(6,1,buffer,57722545(3593/15/56)) lseek err Invalid argument
file_pread(6,1,buffer,57722546(3593/15/57)) lseek err Invalid argument
file_pread(6,1,buffer,57722547(3593/15/58)) lseek err Invalid argument
file_pread(6,1,buffer,57722548(3593/15/59)) lseek err Invalid argument
file_pread(6,1,buffer,57722549(3593/15/60)) lseek err Invalid argument
file_pread(6,1,buffer,57722550(3593/15/61)) lseek err Invalid argument
file_pread(6,1,buffer,57722551(3593/15/62)) lseek err Invalid argument
file_pread(6,1,buffer,57722552(3593/15/63)) lseek err Invalid argument
file_pread(6,1,buffer,57722553(3593/16/1)) lseek err Invalid argument
file_pread(6,1,buffer,57722554(3593/16/2)) lseek err Invalid argument
file_pread(6,1,buffer,57722555(3593/16/3)) lseek err Invalid argument
file_pread(6,1,buffer,57722556(3593/16/4)) lseek err Invalid argument
file_pread(6,1,buffer,57722557(3593/16/5)) lseek err Invalid argument
file_pread(6,1,buffer,57722558(3593/16/6)) lseek err Invalid argument
file_pread(6,1,buffer,57722559(3593/16/7)) lseek err Invalid argument
file_pread(6,1,buffer,57722560(3593/16/8)) lseek err Invalid argument
file_pread(6,1,buffer,57722561(3593/16/9)) lseek err Invalid argument
file_pread(6,1,buffer,57722562(3593/16/10)) lseek err Invalid argument
file_pread(6,1,buffer,57722563(3593/16/11)) lseek err Invalid argument
file_pread(6,1,buffer,57722564(3593/16/12)) lseek err Invalid argument
file_pread(6,1,buffer,57722565(3593/16/13)) lseek err Invalid argument
file_pread(6,1,buffer,57722566(3593/16/14)) lseek err Invalid argument
file_pread(6,1,buffer,57722567(3593/16/15)) lseek err Invalid argument
file_pread(6,1,buffer,57722568(3593/16/16)) lseek err Invalid argument
file_pread(6,1,buffer,57722569(3593/16/17)) lseek err Invalid argument
file_pread(6,1,buffer,57722570(3593/16/18)) lseek err Invalid argument
file_pread(6,1,buffer,57722571(3593/16/19)) lseek err Invalid argument
file_pread(6,1,buffer,57722572(3593/16/20)) lseek err Invalid argument
file_pread(6,1,buffer,57722573(3593/16/21)) lseek err Invalid argument
file_pread(6,1,buffer,57722574(3593/16/22)) lseek err Invalid argument
file_pread(6,1,buffer,57722575(3593/16/23)) lseek err Invalid argument
file_pread(6,1,buffer,57722576(3593/16/24)) lseek err Invalid argument
file_pread(6,1,buffer,57722577(3593/16/25)) lseek err Invalid argument
file_pread(6,1,buffer,57722578(3593/16/26)) lseek err Invalid argument
file_pread(6,1,buffer,57722579(3593/16/27)) lseek err Invalid argument
file_pread(6,1,buffer,57722580(3593/16/28)) lseek err Invalid argument
file_pread(6,1,buffer,57722581(3593/16/29)) lseek err Invalid argument
file_pread(6,1,buffer,57722582(3593/16/30)) lseek err Invalid argument
file_pread(6,1,buffer,57722583(3593/16/31)) lseek err Invalid argument
file_pread(6,1,buffer,57722584(3593/16/32)) lseek err Invalid argument
file_pread(6,1,buffer,57722585(3593/16/33)) lseek err Invalid argument
file_pread(6,1,buffer,57722586(3593/16/34)) lseek err Invalid argument
file_pread(6,1,buffer,57722587(3593/16/35)) lseek err Invalid argument
file_pread(6,1,buffer,57722588(3593/16/36)) lseek err Invalid argument
file_pread(6,1,buffer,57722589(3593/16/37)) lseek err Invalid argument
file_pread(6,1,buffer,57722590(3593/16/38)) lseek err Invalid argument
file_pread(6,1,buffer,57722591(3593/16/39)) lseek err Invalid argument
file_pread(6,1,buffer,57722592(3593/16/40)) lseek err Invalid argument
file_pread(6,1,buffer,57722593(3593/16/41)) lseek err Invalid argument
file_pread(6,1,buffer,57722594(3593/16/42)) lseek err Invalid argument
file_pread(6,1,buffer,57722595(3593/16/43)) lseek err Invalid argument
file_pread(6,1,buffer,57722596(3593/16/44)) lseek err Invalid argument
file_pread(6,1,buffer,57722597(3593/16/45)) lseek err Invalid argument
file_pread(6,1,buffer,57722598(3593/16/46)) lseek err Invalid argument
file_pread(6,1,buffer,57722599(3593/16/47)) lseek err Invalid argument
file_pread(6,1,buffer,57722600(3593/16/48)) lseek err Invalid argument
file_pread(6,1,buffer,57722601(3593/16/49)) lseek err Invalid argument
file_pread(6,1,buffer,57722602(3593/16/50)) lseek err Invalid argument
file_pread(6,1,buffer,57722603(3593/16/51)) lseek err Invalid argument
file_pread(6,1,buffer,57722604(3593/16/52)) lseek err Invalid argument
file_pread(6,1,buffer,57722605(3593/16/53)) lseek err Invalid argument
file_pread(6,1,buffer,57722606(3593/16/54)) lseek err Invalid argument
file_pread(6,1,buffer,57722607(3593/16/55)) lseek err Invalid argument
file_pread(6,1,buffer,57722608(3593/16/56)) lseek err Invalid argument
file_pread(6,1,buffer,57722609(3593/16/57)) lseek err Invalid argument
file_pread(6,1,buffer,57722610(3593/16/58)) lseek err Invalid argument
file_pread(6,1,buffer,57722611(3593/16/59)) lseek err Invalid argument
file_pread(6,1,buffer,57722612(3593/16/60)) lseek err Invalid argument
file_pread(6,1,buffer,57722613(3593/16/61)) lseek err Invalid argument
file_pread(6,1,buffer,57722614(3593/16/62)) lseek err Invalid argument
file_pread(6,1,buffer,57722615(3593/16/63)) lseek err Invalid argument
file_pread(6,1,buffer,57722616(3593/17/1)) lseek err Invalid argument
file_pread(6,1,buffer,57722617(3593/17/2)) lseek err Invalid argument
file_pread(6,1,buffer,57722618(3593/17/3)) lseek err Invalid argument
file_pread(6,1,buffer,57722619(3593/17/4)) lseek err Invalid argument
fi
file_pread(
file_pread(6,1,buffer,57722728(3593/18/50)) lseek err Invalid argument
file_pread(6,1,buffer,57722729(3593/18/51)) lseek err Invalid argument
file_pread(6,1,buffer,57722730(3593/18/52)) lseek err Invalid argument
file_pread(6,1,buffer,57722731(3593/18/53)) lseek err Invalid argument
file_pread(6,1,buffer,57722732(3593/18/54)) lseek err Invalid argument
file_pread(6,1,buffer,57722733(3593/18/55)) lseek err Invalid argument
file_pread(6,1,buffer,57722734(3593/18/56)) lseek err Invalid argument
fiek err Invalid argument
file_pread(6,1,buffer,57720917(3592/245/3)) lseek err Invalid argument
file_pread(6,1,buffer,57722830(3593/20/26)) lseek err Invalid argument
file_pread(6,1,buffer,57720847(3592/243/59)) lseek err Invalid argument
file_pread(6,1,buffer,57720868(3592/244/17)) lseek err Invalid argument
file_pread(6,1,buffer,57720918(3592/245/4)) lseek err Invalid argument
file_pread(6,1,buffer,57722831(3593/20/27)) lseek err Invalid argument
file_pread(6,1,buffer,57720848(3592/243/60)) lseek err Invalid argument
file_pread(6,8,buffer,57720862(3592/244/11)) lseek err Invalid argument
file_pread(6,1,buffer,57720919(3592/245/5)) lseek err Invalid argument
file_pread(6,1,buffer,57722832(3593/20/28)) lseek err Invalid argument
file_pread(6,1,buffer,57720849(3592/243/61)) lseek err Invalid argument
file_pread(6,1,buffer,57720870(3592/244/19)) lseek err Invalid argument
file_pread(6,11,buffer,57720910(3592/244/59)) lseek err Invalid argument
file_pread(6,1,buffer,57722833(3593/20/29)) lseek err Invalid argument
file_pread(6,1,buffer,57720850(3592/243/62)) lseek err Invalid argument
file_pread(6,1,buffer,57720871(3592/244/20)) lseek err Invalid argument
file_pread(6,1,buffer,57720921(3592/245/7)) lseek err Invalid argument
file_pread(6,1,buffer,57722834(3593/20/30)) lseek err Invalid argument
file_pread(6,1,buffer,57720851(3592/243/63)) lseek err Invalid argument
file_pread(6,1,buffer,57720872(3592/244/21)) lseek err Invalid argument
file_pread(6,1,buffer,57720922(3592/245/8)) lseek err Invalid argument
file_pread(6,1,buffer,57722835(3593/20/31)) lseek err Invalid argument
file_pread(6,1,buffer,57720852(3592/244/1)) lseek err Invalid argument
file_pread(6,8,buffer,57720866(3592/244/15)) lseek err Invalid argument
file_pread(6,1,buffer,57720923(3592/245/9)) lseek err Invalid argument
file_pread(6,1,buffer,57720916(3592/245/2)) lseek err Invalid argument
file_pread(6,1,buffer,57720897(3592/244/46)) lseek err Invalid argument
file_pread(6,1,buffer,57722881(3593/21/14)) lseek err Invalid argument
P FAT32 0 0 1 3263 138 11 52428800 [HP TOUCHPAD]
dir_partition inode=0
FAT: cluster=93(0x5d), pos=18690
29225 drwxr-xr-x 0 0 0 18-Dec-2012 01:29 .palm
94 drwxr-xr-x 0 0 0 3-Jul-2012 19:30 DCIM
5888 -rwxr-xr-x 0 0 292092 17-Dec-2012 21:29 Open Source Information.pdf
96 drwxr-xr-x 0 0 0 3-Jul-2012 12:31 ringtones
99 drwxr-xr-x 0 0 0 16-Jan-2013 14:44 .wallpapers
182 drwxr-xr-x 0 0 0 3-Jul-2012 12:30 .sysservice
254 drwxr-xr-x 0 0 0 3-Jul-2012 19:30 .temp
0 -rwxr-xr-x 0 0 0 18-Dec-2012 01:30 .VolumeIcon.icns
255 drwxr-xr-x 0 0 0 29-Jan-2013 12:49 downloads
256 drwxr-xr-x 0 0 0 3-Jul-2012 12:31 wallpapers
647003 drwxr-xr-x 0 0 0 14-Dec-2012 03:27 justdraw
357513 drwxr-xr-x 0 0 0 17-Dec-2012 23:23 tfj
23094 -rwxr-xr-x 0 0 13 8-Sep-2001 22:46 .hidden
764 drwxr-xr-x 0 0 0 15-Dec-2012 00:06 .developer
34308 -rwxr-xr-x 0 0 110478 1-Dec-2012 00:29 webos-ausmt.log
496610 -rwxr-xr-x 0 0 1505 1-Dec-2012 00:29 .webosinternals.patches.packages
765 drwxr-xr-x 0 0 0 1-Dec-2012 00:29 .patches
938 drwxr-xr-x 0 0 0 14-Dec-2012 03:16 appdata
989 drwxr-xr-x 0 0 0 14-Oct-2012 16:18 logs
29222 drwxr-xr-x 0 0 0 1-Jan-2000 00:00 save_log
X 1093 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0000.REC
957 drwxr-xr-x 0 0 0 16-Dec-2012 03:02 .app-storage
66132 drwxr-xr-x 0 0 0 25-Jul-2012 13:22 music
79531 drwxr-xr-x 0 0 0 28-Aug-2012 07:46 files
1287 drwxr-xr-x 0 0 0 21-Dec-2011 13:21 .photosApp
327553 drwxr-xr-x 0 0 0 5-Dec-2012 14:22 screencaptures
X 1095 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0001.REC
X 1096 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0002.REC
25539 drwxr-xr-x 0 0 0 7-Aug-2012 13:28 info
X 1099 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0003.REC
X 1100 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0004.REC
X 1101 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0005.REC
1393 drwxr-xr-x 0 0 0 19-Jul-2012 19:02 www
X 1102 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0006.REC
358349 -rwxr-xr-x 0 0 900965 19-Nov-2012 14:08 tfj-unknown-prob-toss
X 1103 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0007.REC
X 1104 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0008.REC
X 1105 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0009.REC
X 1106 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0010.REC
X 1107 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0011.REC
X 1108 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0012.REC
X 1109 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0013.REC
X 1110 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0014.REC
X 1111 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0015.REC
X 1112 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0016.REC
X 1113 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0017.REC
X 1114 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0018.REC
X 1115 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0019.REC
X 1116 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0020.REC
X 1117 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0021.REC
X 1118 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0022.REC
X 1119 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0023.REC
X 1120 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0024.REC
X 1121 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0025.REC
X 1122 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0026.REC
X 1123 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0027.REC
X 1124 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0028.REC
X 1125 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0029.REC
X 1126 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0030.REC
X 1127 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0031.REC
X 1128 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0032.REC
X 1129 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0033.REC
X 1130 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0034.REC
X 1131 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0035.REC
X 1132 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0036.REC
X 1133 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0037.REC
X 1134 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0038.REC
X 1135 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0039.REC
X 1136 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0040.REC
X 1137 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0041.REC
X 1138 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0042.REC
X 1139 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0043.REC
X 1140 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0044.REC
X 1141 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0045.REC
X 1142 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0046.REC
X 1143 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0047.REC
X 1144 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0048.REC
X 1145 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0049.REC
X 1146 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0050.REC
X 1147 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0051.REC
X 1148 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0052.REC
X 1149 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0053.REC
X 1150 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0054.REC
X 1151 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0055.REC
X 1152 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0056.REC
X 1153 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0057.REC
X 1154 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0058.REC
X 1155 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0059.REC
X 1156 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0060.REC
X 1157 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0061.REC
X 1158 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0062.REC
X 1159 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0063.REC
X 1160 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0064.REC
X 1161 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0065.REC
X 1162 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0066.REC
X 1163 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0067.REC
X 1164 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0068.REC
X 1165 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0069.REC
X 1166 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0070.REC
X 1167 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0071.REC
X 1168 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0072.REC
X 1169 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0073.REC
X 1170 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0074.REC
X 1171 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0075.REC
X 1172 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0076.REC
X 1173 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0077.REC
X 1174 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0078.REC
X 1175 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0079.REC
X 1176 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0080.REC
X 1177 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0081.REC
X 1178 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0082.REC
X 1179 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0083.REC
X 1180 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0084.REC
X 1181 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0085.REC
X 1182 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0086.REC
X 1183 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0087.REC
X 1184 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0088.REC
X 1185 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0089.REC
X 1186 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0090.REC
X 1187 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0091.REC
X 1188 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0092.REC
X 1189 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0093.REC
X 1190 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0094.REC
X 1191 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0095.REC
X 1192 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0096.REC
X 1193 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0097.REC
X 1194 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0098.REC
X 1195 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0099.REC
X 1196 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0100.REC
X 1197 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0101.REC
X 1198 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0102.REC
X 1199 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0103.REC
X 1200 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0104.REC
X 1201 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0105.REC
X 1202 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0106.REC
X 1203 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0107.REC
X 1204 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0108.REC
X 1205 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0109.REC
X 1206 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0110.REC
X 1207 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0111.REC
X 1208 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0112.REC
X 1209 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0113.REC
X 1210 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0114.REC
X 1211 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0115.REC
X 1212 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0116.REC
X 1213 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0117.REC
X 1214 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0118.REC
X 1215 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0119.REC
X 1216 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0120.REC
X 1217 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0121.REC
X 1218 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0122.REC
X 1219 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0123.REC
X 1220 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0124.REC
X 1221 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0125.REC
X 1222 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0126.REC
X 1223 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0127.REC
X 1224 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0128.REC
X 1225 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0129.REC
X 1226 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0130.REC
X 1227 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0131.REC
X 1228 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0132.REC
X 1229 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0133.REC
X 1230 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0134.REC
X 1231 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0135.REC
X 1232 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0136.REC
X 1233 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0137.REC
X 1234 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0138.REC
X 1235 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0139.REC
X 1236 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0140.REC
X 1237 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0141.REC
X 1238 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0142.REC
X 1239 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0143.REC
X 1240 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0144.REC
X 1241 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0145.REC
X 1242 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0146.REC
X 1243 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0147.REC
X 1244 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0148.REC
X 1245 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0149.REC
X 1246 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0150.REC
X 1247 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0151.REC
X 1248 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0152.REC
X 1249 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0153.REC
X 1250 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0154.REC
X 1251 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0155.REC
X 1252 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0156.REC
X 1253 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0157.REC
X 1254 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0158.REC
X 1255 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0159.REC
X 1256 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0160.REC
X 1257 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0161.REC
X 1258 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0162.REC
X 1259 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0163.REC
X 1260 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0164.REC
X 1261 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0165.REC
X 1262 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0166.REC
X 1263 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0167.REC
X 1264 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0168.REC
X 1265 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0169.REC
X 1266 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0170.REC
X 1267 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0171.REC
X 1268 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0172.REC
X 1269 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0173.REC
X 1270 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0174.REC
X 1271 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0175.REC
X 1272 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0176.REC
X 1273 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0177.REC
X 1274 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0178.REC
X 1275 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0179.REC
X 1276 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0180.REC
X 1277 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0181.REC
X 1278 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0182.REC
X 1279 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0183.REC
X 1280 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0184.REC
X 1281 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0185.REC
X 1282 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0186.REC
X 1283 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0187.REC
X 1284 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0188.REC
X 1285 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0189.REC
X 1286 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0190.REC
X 443775 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0189.REC
X 443776 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0190.REC
X 443777 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0191.REC
X 443778 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0192.REC
X 443779 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0193.REC
X 443780 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0194.REC
X 443781 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0195.REC
X 443782 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0196.REC
X 443783 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0197.REC
X 443784 -rwxr-xr-x 0 0 98304 1-Jan-1980 00:00 _SCK0198.REC
X 443787 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0199.REC
X 443788 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0200.REC
X 443789 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0201.REC
X 443790 -rwxr-xr-x 0 0 786432 1-Jan-1980 00:00 _SCK0202.REC
X 443814 -rwxr-xr-x 0 0 163840 1-Jan-1980 00:00 _SCK0203.REC
X 443819 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0204.REC
X 443820 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0205.REC
X 443821 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0206.REC
X 443822 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0207.REC
X 443823 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0208.REC
X 443824 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0209.REC
X 443825 -rwxr-xr-x 0 0 131072 1-Jan-1980 00:00 _SCK0210.REC
X 443829 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0211.REC
X 443830 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0212.REC
X 443831 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0213.REC
X 443832 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0214.REC
X 443833 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0215.REC
X 443834 -rwxr-xr-x 0 0 65536 1-Jan-1980 00:00 _SCK0216.REC
X 443836 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0217.REC
X 443837 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0218.REC
X 443838 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0219.REC
X 443839 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0220.REC
X 443840 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0221.REC
X 443841 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0222.REC
X 443842 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0223.REC
X 443843 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0224.REC
X 443844 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0225.REC
X 443845 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0226.REC
X 443846 -rwxr-xr-x 0 0 65536 1-Jan-1980 00:00 _SCK0227.REC
X 443848 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0228.REC
X 443849 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0229.REC
X 443850 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0230.REC
X 443851 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0231.REC
X 443852 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0232.REC
X 443853 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0233.REC
X 443854 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0234.REC
X 443855 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0235.REC
X 443856 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0236.REC
X 443857 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0237.REC
X 443858 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0238.REC
X 443859 -rwxr-xr-x 0 0 65536 1-Jan-1980 00:00 _SCK0239.REC
X 443861 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0240.REC
X 443862 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0241.REC
X 443863 -rwxr-xr-x 0 0 98304 1-Jan-1980 00:00 _SCK0242.REC
X 443866 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0243.REC
X 443867 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0244.REC
X 443868 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0245.REC
X 443869 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0246.REC
X 443870 -rwxr-xr-x 0 0 98304 1-Jan-1980 00:00 _SCK0247.REC
X 443873 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0248.REC
X 443874 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0249.REC
X 443875 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0250.REC
X 443876 -rwxr-xr-x 0 0 131072 1-Jan-1980 00:00 _SCK0251.REC
X 443880 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0252.REC
X 443881 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0253.REC
X 443882 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0254.REC
X 443883 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0255.REC
X 443884 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0256.REC
X 443885 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0257.REC
X 443886 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0258.REC
X 443887 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0259.REC
X 443888 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0260.REC
X 443889 -rwxr-xr-x 0 0 65536 1-Jan-1980 00:00 _SCK0261.REC
X 443891 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0262.REC
X 443892 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0263.REC
X 443893 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0264.REC
X 443894 -rwxr-xr-x 0 0 98304 1-Jan-1980 00:00 _SCK0265.REC
X 443897 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0266.REC
X 443898 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0267.REC
X 443899 -rwxr-xr-x 0 0 196608 1-Jan-1980 00:00 _SCK0268.REC
X 443905 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0269.REC
X 443906 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0270.REC
X 443907 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0271.REC
X 443908 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0272.REC
X 443909 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0273.REC
X 443910 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0274.REC
X 443911 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0275.REC
X 443912 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0276.REC
X 443913 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0277.REC
X 443914 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0278.REC
X 443915 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0279.REC
X 443916 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0280.REC
X 443917 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0281.REC
X 443918 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0282.REC
X 443919 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0283.REC
X 443920 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0284.REC
X 443921 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0285.REC
X 443922 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0286.REC
X 443923 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0287.REC
X 443924 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0288.REC
X 443925 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0289.REC
X 443926 -rwxr-xr-x 0 0 131072 1-Jan-1980 00:00 _SCK0290.REC
X 443930 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0291.REC
X 443931 -rwxr-xr-x 0 0 262144 1-Jan-1980 00:00 _SCK0292.REC
X 443939 -rwxr-xr-x 0 0 950272 1-Jan-1980 00:00 _SCK0293.REC
X 421569 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0299.REC
X 421570 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0300.REC
X 421571 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0301.REC
X 421572 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0302.REC
X 421573 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0303.REC
X 421574 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0304.REC
X 421575 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0305.REC
X 421576 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0306.REC
X 421577 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0307.REC
X 421578 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0308.REC
X 421579 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0309.REC
X 421580 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0310.REC
X 421581 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0311.REC
X 421582 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0312.REC
X 421583 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0313.REC
X 421584 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0314.REC
X 421585 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0315.REC
X 421586 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0316.REC
X 421587 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0317.REC
X 421588 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0318.REC
X 421589 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0319.REC
X 421590 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0320.REC
X 421591 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0321.REC
X 421592 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0322.REC
X 421593 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0323.REC
X 421594 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0324.REC
X 421595 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0325.REC
X 421596 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0326.REC
X 421597 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0327.REC
X 421598 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0328.REC
X 421599 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0329.REC
X 421600 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0330.REC
X 421601 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0331.REC
X 421602 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0332.REC
X 421603 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0333.REC
X 421604 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0334.REC
X 421605 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0335.REC
X 421606 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0336.REC
X 421607 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0337.REC
X 421608 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0338.REC
X 421609 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0339.REC
X 421610 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0340.REC
X 421611 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0341.REC
X 421612 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0342.REC
X 421613 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0343.REC
X 421614 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0344.REC
X 421615 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0345.REC
X 421617 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0346.REC
X 421618 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0347.REC
X 421619 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0348.REC
X 421620 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0349.REC
X 421621 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0350.REC
X 421622 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0351.REC
X 421623 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0352.REC
X 421624 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0353.REC
X 421625 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0354.REC
X 421626 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0355.REC
X 421627 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0356.REC
X 421628 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0357.REC
X 421629 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0358.REC
X 421630 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0359.REC
X 421631 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0360.REC
X 421632 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0361.REC
X 421633 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0362.REC
X 421634 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0363.REC
X 421635 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0364.REC
X 421636 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0365.REC
X 421637 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0366.REC
X 421638 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0367.REC
X 421639 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0368.REC
X 421640 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0369.REC
X 421641 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0370.REC
X 421642 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0371.REC
X 421643 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0372.REC
X 421644 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0373.REC
X 421645 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0374.REC
X 421646 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0375.REC
X 421647 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0376.REC
X 421648 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0377.REC
X 421649 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0378.REC
X 421650 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0379.REC
X 421651 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0380.REC
X 421652 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0381.REC
X 421653 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0382.REC
X 421654 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0383.REC
X 421655 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0384.REC
X 421656 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0385.REC
X 421657 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0386.REC
X 421658 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0387.REC
X 421659 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0388.REC
X 421660 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0389.REC
X 421661 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0390.REC
X 421662 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0391.REC
X 421663 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0392.REC
X 421664 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0393.REC
X 421665 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0394.REC
X 421666 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0395.REC
X 421667 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0396.REC
X 421668 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0397.REC
X 421669 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0398.REC
X 421670 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0399.REC
X 421671 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0400.REC
X 421672 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0401.REC
X 421673 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0402.REC
X 421674 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0403.REC
X 421675 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0404.REC
X 421676 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0405.REC
X 421677 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0406.REC
X 421678 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0407.REC
X 421679 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0408.REC
X 421680 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0409.REC
X 421681 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0410.REC
X 421682 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0411.REC
X 421683 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0412.REC
X 421684 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0413.REC
X 421685 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0414.REC
X 421686 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0415.REC
X 421687 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0416.REC
X 421688 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0417.REC
X 421689 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0418.REC
X 421690 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0419.REC
X 421691 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0420.REC
X 421692 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0421.REC
X 421693 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0422.REC
X 421694 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0423.REC
X 421695 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0424.REC
X 421696 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0425.REC
X 421697 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0426.REC
X 421698 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0427.REC
X 421699 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0428.REC
X 421700 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0429.REC
X 421701 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0430.REC
X 421702 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0431.REC
X 421703 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0432.REC
X 421704 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0433.REC
X 421705 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0434.REC
X 421706 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0435.REC
X 421707 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0436.REC
X 421708 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0437.REC
X 421709 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0438.REC
X 421710 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0439.REC
X 421711 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0440.REC
X 421712 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0441.REC
X 421713 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0442.REC
X 421714 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0443.REC
X 421715 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0444.REC
X 421716 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0445.REC
X 421717 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0446.REC
X 421718 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0447.REC
X 421719 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0448.REC
X 421720 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0449.REC
X 421721 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0450.REC
X 421722 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0451.REC
X 421723 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0452.REC
X 421724 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0453.REC
X 421725 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0454.REC
X 421726 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0455.REC
X 421727 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0456.REC
X 421728 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0457.REC
X 421729 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0458.REC
X 421730 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0459.REC
X 421731 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0460.REC
X 421732 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0461.REC
X 421733 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0462.REC
X 421734 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0463.REC
X 421735 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0464.REC
X 421736 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0465.REC
X 421737 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0466.REC
X 421738 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0467.REC
X 421739 -rwxr-xr-x 0 0 425984 1-Jan-1980 00:00 _SCK0468.REC
X 421752 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0469.REC
X 421753 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0470.REC
X 421754 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0471.REC
X 421755 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0472.REC
X 421756 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0473.REC
X 421757 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0474.REC
X 421758 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0475.REC
X 421759 -rwxr-xr-x 0 0 32768 1-Jan-1980 00:00 _SCK0476.REC
X 166679 -rwxr-xr-x 0 0 116415643 1-Nov-2012 19:29 TimeTravelers.mp4
X 2 drwxr-xr-x 0 0 32768 31-Dec-2012 12:11 _879312_
Write isn't available because the partition table type "None" has been selected.
and
OS: Windows XP SP3
OS: Windows XP SP3
FAT32 at 0/0/1
FAT1 : 66-6465
FAT2 : 6466-12865
sectors : 52428800
cluster_size : 64
FAT32 at 0/0/1
FAT32 at 0/0/1
FAT1 : 66-6465
FAT2 : 6466-12865
sectors : 52428800
cluster_size : 64
FAT32 at 0/0/1
FAT1 : 66-6465
FAT2 : 6466-12865
sectors : 52428800
cluster_size : 64
FAT32 at 0/0/1
fi
file_pread(
