Here is a brief description of what i was trying to do when my disk failed:
I was installing a server version of opensuse 12.2 and it crashed,i had to reboot.
Then i left pc to boot into windows, and then i saw that my Drive "D:" was in raw filesystem and prompted to format.
My configuration of partitions in windows was this:
System reserved: 100MB
C: (about) 870GB Win7x64
D: (about) 840GB
L: 100GB (ubuntu 12.10 was in this partition, i had dual boot mode)
When i was setting partitions in opensuse, i created a /srv partition(/swap;/root;/home; where there too),
so suse propose that my /srv partition was created in partition D:, and i resized it to the minimum which was 327GB.
I went throught with the instalation process and when it was at 6%, it crashed.
Actually, i think this was the best thing that happened to me because i now realise that i could loose all data in that drive, since 327GB was more or less what i had in that drive.
Now windows see's 100GB (former ubuntu) plus +-500GB of unassigned space and the 327GB (D:) as raw.
After digging a lot, i came too you and ask for help in trying to recover data from the drive and put it good again.
Here is the output when running live kde, with terminal: fdisk -l
linux@linux:~> su -l
linux:~ # fdisk -l
Disk /dev/sda: 2000.4 GB, 2000398934016 bytes
255 heads, 63 sectors/track, 243201 cylinders, total 3907029168 sectors
Disk identifier: 0x216ae978
Device Boot Start End Blocks Id System
/dev/sda1 * 2048 206847 102400 7 HPFS/NTFS/exFAT
/dev/sda2 206848 1838284799 919038976 7 HPFS/NTFS/exFAT
/dev/sda3 2048000000 2734618099 343309050 7 HPFS/NTFS/exFAT
Disk /dev/sdb: 1010 MB, 1010826752 bytes
255 heads, 63 sectors/track, 122 cylinders, total 1974271 sectors
Disk identifier: 0x91f72d24
/dev/sdb1 * 63 1974270 987104 c W95 FAT32 (LBA)I started the Step by Step tutorial of TestDisk, and i am running Analyse right now.
I will post result in a few minutes cause it's at 98%.
Thank's to all in advance, i sincerely hope that you can help me
Niolp
