After the scan disk can not access the files
osappg
#1 Post by osappg »
I made the scandisk Computer \ HD F: \ INSTRUMENTS \ Run scandisk \ a Fat32 HD
After scandisk it renaming some files marked with a ~. I can sees them with the correct size apparently
but if I try to move or rename copy tells me
Can not find the item
Is no longer available in F: \ xxx \ xxx \ filename ~. Xxx Check the location of the item and try again
How can I fix :?:
Wath Test Disk opyion has or other utility? :?:
thanks for anwers :D
Osap
Re: After the scan disk can not access the files
Try to copy your files using TestDisk, Advanced, List
