Can't recover files bigger than 4 GB
That's it. The worst thing is that TestDisk gets cycled on such files and starts recovering from the beginning when reaching 4 GB limit.
Re: Can't recover files bigger than 4 GB
This is bad news for me.
I am trying to recover ~4 GB files from a linux partition... Are you the same? or from a windows partition?
I was trying to recover a group of files and folders from a NTFS partition under Windows. If I remember correctly I have used single file recovery as a workaround. Or I used DMDE for such files? I don't remember. Anyway, it isn't really bad news, rather annoying.
The issue is still present in current WIP. Tested by copying the following directory:
Volume in drive K is RYA-10
Volume Serial Number is B293-B37D
Directory of K:\Video\Будучи там _ Being There (Хэл Эшби _ Hal Ashby) [1080p] [1979 г., Трагикомедия, BDRip] Dub + AVO + Eng
09.12.2010 04:09 <DIR> .
09.12.2010 04:09 <DIR> ..
27.11.2010 06:15 9 091 757 785 Buduchi.tam.1979.x264.BDRip.1080p.2Rus.Eng.+.rus-eng.subs.HDClub.mkv
09.12.2010 04:09 50 URL.txt
2 File(s) 9 091 757 835 bytes
2 Dir(s) 10 693 292 032 bytes free
