Screen garbage when exploring directories
GCRaistlin
#1 Post by GCRaistlin »
Sometimes when exploring directories after just another Down arrow key press screen gets changed from normal
 1 * HPFS - NTFS              0   1  1 30401 254 63  488408067
Directory /Documents and Settings/Raistlin/Desktop
                                                   Previous
>-r--r--r--     0     0         0 20-Jul-2011 23:22 GRTMPOEM_RU_Custom.iso.uibak
 -r--r--r--     0     0    583827 18-Jan-2011 15:19 IDEMA_Long_Data_Block_WhitePaper_6_13_07.pdf
 -r--r--r--     0     0      1237 29-Jan-2012 02:29 IE Tab Plus Rules.txt
 dr-xr-xr-x     0     0         0 18-Oct-2011 23:05 InRock
 -r--r--r--     0     0      9678 28-May-2012 02:30 KeyEvents4.7z
 -r--r--r--     0     0  40580219 26-Jul-2012 11:35 kompromat_na_oppoziciyu.flv
 -r--r--r--     0     0         0 26-Jul-2012 11:35 kompromat_na_oppoziciyu.flv
 -r--r--r--     0     0       768  1-Mar-2012 00:53 ~archpr.axr
 -r--r--r--     0     0    346889 27-Nov-2011 20:42 ~AutoHideFiles.reg
 -r--r--r--     0     0      9748 18-May-2011 01:56 ~MacroConsts.reg
 dr-xr-xr-x     0     0         0 28-Nov-2012 15:53 ~Subtitle Workshop
 -r--r--r--     0     0       556 27-Mar-2010 15:08 Александрович.txt.lnk
 dr-xr-xr-x     0     0         0 27-Jun-2012 13:02 Битов
 -r--r--r--     0     0   3644542 14-Dec-2011 22:55 Галина-Липина-К-берегам-Максимилиан-Волошин(mp
 dr-xr-xr-x     0     0         0 31-May-2012 18:33 Город грехов
 dr-xr-xr-x     0     0         0  5-May-2011 02:08 После репетиции _ Efter Repetitionen (Ингмар Б
 dr-xr-xr-x     0     0         0  9-Jun-2012 23:36 Приходите завтра
 -r--r--r--     0     0        15  1-Feb-2012 22:39 Проверить на дубли.txt
 dr-xr-xr-x     0     0         0 10-Aug-2011 21:00 Протоколы TCP-IP. Практическое руководство [Ри
 dr-xr-xr-x     0     0         0  3-Nov-2012 00:52 Путешествие
 -r--r--r--     0     0    131072 30-Oct-2012 17:47 среднеохтинский.doc
 -r--r--r--     0     0      1505 23-Oct-2012 23:53 topic.cgi.htm
 -r--r--r--     0     0      1482 23-Oct-2012 23:49 topic1.cgi.htm
 -r--r--r--     0     0   2801901 17-Oct-2011 17:57 TT-Dynamic-Range 1.4.rar
 -r--r--r--     0     0       847 28-Jan-2012 23:34 U1.vbs
 -r--r--r--     0     0      1246 29-Jan-2012 00:07 Uninstall.vbs
                                                   Next
Use Left arrow to go back, Right to change directory
    q to quit, : to select the current file, a to select all files
    C to copy the selected files, c to copy the current file
to
Александрович.txt.lnk                          dr-xr-xr-x     0     0         0 27-Jun-2012 13:02
Битов                                          -r--r--r--     0     0   3644542 14-Dec-2011 22:55
Галина-Липина-К-берегам-Максимилиан-Волошин(mp dr-xr-xr-x     0     0         0 31-May-2012 18:33
Город грехов                                   dr-xr-xr-x     0     0         0  5-May-2011 02:08
После репетиции _ Efter Repetitionen (Ингмар Б dr-xr-xr-x     0     0         0  9-Jun-2012 23:36
Приходите завтра                               -r--r--r--     0     0        15  1-Feb-2012 22:39
Проверить на дубли.txt                         dr-xr-xr-x     0     0         0 10-Aug-2011 21:00
Протоколы TCP-IP. Практическое руководство [Ри dr-xr-xr-x     0     0         0  3-Nov-2012 00:52
Путешествие                                    -r--r--r--     0     0    131072 30-Oct-2012 17:47
среднеохтинский.doc                            -r--r--r--     0     0      1505 23-Oct-2012 23:53
topic.cgi.htm                                  -r--r--r--     0     0      1482 23-Oct-2012 23:49
topic1.cgi.htm                                 -r--r--r--     0     0   2801901 17-Oct-2011 17:57
TT-Dynamic-Range 1.4.rar                       -r--r--r--     0     0       847 28-Jan-2012 23:34
U1.vbs                                         -r--r--r--     0     0      1246 29-Jan-2012 00:07
Uninstall.vbs                                  dr-xr-xr-x     0     0         0  3-Dec-2012 12:56
Video                                          -r--r--r--     0     0     23975 19-Dec-2011 15:47
Volumouse.PNG                                 >-r--r--r--     0     0 691922944 28-Sep-2011 02:01
VX2PFPP_RU.iso        N
ext                                           Use Left arrow to go back, Right to change directory
lect all files                                    C to copy the selected files, c to copy the curr
ent file                                       11:35 kompromat_na_oppoziciyu.flv
 dr-xr-xr-x     0     0         0  3-Dec-2012 12:56 Video
 -r--r--r--     0     0     23975 19-Dec-2011 15:47 Volumouse.PNG
>-r--r--r--     0     0 691922944 28-Sep-2011 02:01 VX2PFPP_RU.iso
                                                   Next
Re: Screen garbage when exploring directories
Using latest 6.14-WIP, can you try to reproduce the problem ? When the screen display is corrupted, press Ctrl+L. Does it fix the display ?
GCRaistlin
#3 Post by GCRaistlin »
It seems to be OK with 6.14.
BTW I discovered that it happened only in a non-standard sized console. For example, 98x50.
