Deleted files using rm -rf /
ragnazorg
#1 Post by ragnazorg »
What happened was my server got compromised.
The hacker did rm -rf /
which resulted to my files being deleted.
I want to restore the files from a user.
Im running in debian squeeze in Xen Server. I have a Vritual drive which it is installed. Now im wondering how can I restore or check the certain files I need. Some files I need are mostly 300mb++ in size.
is it possible to restore them?
Re: Deleted files using rm -rf /
Try TestDisk, Advanced, Undelete but usually it only works for ext2.
If it doesn't work, run PhotoRec 6.14-WIP
wget -N http://www.cgsecurity.org/testdisk-6.14-WIP.linux26.tar.bz2
tar xjf testdisk-6.14-WIP.linux26.tar.bz2
cd testdisk-6.14-WIP
sudo ./photorec_static
Good luck
