how to recover after dd if=/dev/zero of=/dev/sdb
mail4me9999
#1 Post by mail4me9999 »
I have done a stupid thing
dd bs=2048 if=/dev/zero of=/dev/sdb count=1024
Now, the drive had only one partition for the whole drive and it was formated as ext4
While the system was still running I did this:
hdparm -g /dev/sdb
/dev/sdb:
geometry = 243200/255/63, sectors = 3907012784, start = 0
hdparm -g /dev/sdb1
/dev/sdb1:
geometry = 243199/255/63, sectors = 3907007937, start = 63
when I run testdisk the regular search does not find anything, but the deep search shows the partition almost instantaneouly .
I did not wait till the end of the deep search and stopped it. (it will be several hours before it will finish)
I am asking if there is hope to recover the partition with data on it.
Since some of the information is available about the partition maybe something can be done to recover it
Thank you very much for your help
Lazar
a477932
Re: how to recover after dd if=/dev/zero of=/dev/sdb
#2 Post by a477932 »
I did the same mistake as you...
Did you manage to recover your data?
Thanks,
#3 Post by cgrenier »
The dd command hasn't overwritten the whole disk "only" the beginning. It's why TestDisk can locate NTFS backup boot sector or ext2/3/4 backup superblock after the zone that have been overwritten.
As written previously, use TestDisk, Analyse, Quick Search, Deeper Search to locate your partitions.
