I'm trying change RAW to NTFS without lose data by testdisk, but I can't do it.
I did analise and change to * or D next I wrote it, but it didn't help.
Anyone know how reapir it?
Change RAW to NTFS without lose data Topic is solved
Re: Change RAW to NTFS without lose data
Try TestDisk, Advanced, Boot. Try RebuildBS and List. If you see your files, choose Write, confirm, Quit
I tried this, but it didn't work.
I used program for recovering data and recovered all data, next I formated disc to NTFS and copied all data.
It's all, so my problem is solved.
Thanks for your reply.
I'll set your topic as solved.
