Trying to recover lost pictures from PNY SD card
w18918
#1 Post by w18918 »
I've got a PNY PRO-ELITE 16GB SD card that has worked well with my Nikon D5100 camera for about 3 months. Just recently however, my camera is unable to detect the SD card. I've got a couple weeks worth of photos that I didn't get backed up, which I would like to recover. On my Windows 7 PC with built in SD card reader, I can access the card, but I get this error:
You need to format the disk in drive D: before you can use it.
Do you want to format?
I have not reformatted the SD card yet, but I have tried TestDisk and PhotoRec without much success.
TestDisk displays message:
Then I do a Quick Search to Analyse cylinder and Deeper Search, but I just get the message:
I also tried PhotoRec, but it found 0 files.
Any other suggestions to try? I've tried some other different data recovery software applications, but having no luck. Should I reformat the SD card? Would doing this help or make the file recovery process more difficult? Thanks,
Thai
Re: Trying to recover lost pictures from PNY SD card
Please repeat your diagnose.
Don't confirm at "Analyse" but "Advanced" and "Boot".
Run "Rebuild BS"
Check the menu List and let me know, did you see your files or an error message.
If no partition is displayed, repeat the diagnose using partition table type "None".
If your partition appears in the menu Advanced as unknown, use type to change the file system.
Normally SD Cards are FAT32 preformatted,
Using partition type intel, you can enter the code 0c for FAT32.
Using partition table type "None", you can select FAT32 directly within the menu "Type".
Also copy and paste the content of your testdisk.log.
w18918
#3 Post by w18918 »
Fiona,
Thanks for taking the time to help debug this problem. Below is the content of the TestDisk log. Please let me know what else I can try. Thanks,
Thai
Fri Mar 1 09:54:11 2013
TestDisk 6.14-WIP, Data Recovery Utility, December 2012
Compilation date: 2013-02-11T11:20:27
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=16089350144
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=16089350144
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=233699278848
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=16089350144
Disk /dev/sda - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - WDC WD25 00BEKT-60PVM, S/N:W -DXW153AP12326, FW:01.0
Disk /dev/sdb - 16 GB / 14 GiB - CHS 1956 255 63, sector size=512 - RICOH R5C843, S/N:0001, FW:01
Disk /dev/sdb - 16 GB / 14 GiB - RICOH R5C843
Analyse Disk /dev/sdb - 16 GB / 14 GiB - CHS 1956 255 63
file_pread(5,2,buffer,31425188(1956/32/33)) lseek err Invalid argument
file_pread(5,1,buffer,31425188(1956/32/33)) lseek err Invalid argument
file_pread(5,2,buffer,31425251(1956/33/33)) lseek err Invalid argument
file_pread(5,1,buffer,31425251(1956/33/33)) lseek err Invalid argument
file_pread(5,14,buffer,31424514(1956/21/52)) lseek err Invalid argument
file_pread(5,3,buffer,31424528(1956/22/3)) lseek err Invalid argument
file_pread(5,3,buffer,31424575(1956/22/50)) lseek err Invalid argument
file_pread(5,8,buffer,31424591(1956/23/3)) lseek err Invalid argument
file_pread(5,11,buffer,31424638(1956/23/50)) lseek err Invalid argument
file_pread(5,2,buffer,31426560(1956/54/19)) lseek err Invalid argument
Store new MBR code
Store new MBR code
Partition table type: None
P Unknown 0 0 1 1956 21 49 31424512
Change partition type:
P FAT32 0 0 1 1956 21 49 31424512
fat32_boot_sector
Bad
Bad
First sectors (Boot code and partition information) are not identical.
Second sectors (cluster information) are not identical.
rebuild_FAT_BS p_fat12 0, p_fat16 0, p_fat32 1
fat_find_type(max_offset=245568, p_fat12=0, p_fat16=0, p_fat32=1, debug=1, dump_ind=0)
No FAT found, reserved=0, fat_length=0
find_sectors_per_cluster skip_sectors=1438 (skip_offset=736256)
Can't find cluster size
fat32_boot_sector
Bad
Bad
