My data partition now is an unreadable "Raw" format
prady
#1 Post by prady »
Hi, my data partition (J:) suddenly lost all the file system information, and now is listed as a "Raw" partition.
Gestione disco.jpg (124.14 KiB) Viewed 5067 times
TestDisk sees this mess:
Test disk struttura partizioni.png (40.62 KiB) Viewed 5067 times
I performed a quick search and a deeper one.
Please help me! :roll:
Mon Mar 4 15:56:24 2013
TestDisk 6.14-WIP, Data Recovery Utility, March 2013
Compilation date: 2013-03-02T11:22:18
filewin32_getfilesize(\\.\PhysicalDrive1) GetFileSize err Funzione non corretta.
filewin32_setfilepointer(\\.\PhysicalDrive1) SetFilePointer err Funzione non corretta.
filewin32_getfilesize(\\.\PhysicalDrive2) GetFileSize err Funzione non corretta.
filewin32_setfilepointer(\\.\PhysicalDrive2) SetFilePointer err Funzione non corretta.
filewin32_getfilesize(\\.\PhysicalDrive3) GetFileSize err Funzione non corretta.
filewin32_setfilepointer(\\.\PhysicalDrive3) SetFilePointer err Funzione non corretta.
filewin32_getfilesize(\\.\PhysicalDrive4) GetFileSize err Funzione non corretta.
filewin32_setfilepointer(\\.\PhysicalDrive4) SetFilePointer err Funzione non corretta.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=76348042752
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=16106127360
filewin32_getfilesize(\\.\E:) GetFileSize err Funzione non corretta.
filewin32_setfilepointer(\\.\E:) SetFilePointer err Funzione non corretta.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\J:)=907664162816
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST31000528AS, S/N:2020202020202020202020205639325054315850, FW:CC44
Disk /dev/sda - 1000 GB / 931 GiB - ST31000528AS
Analyse Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63
FAT16 at 0/1/1
Info: size boot_sector 160587, partition 160587
FAT1 : 1-157
FAT2 : 158-314
start_rootdir : 315
Data : 347-160586
sectors : 160587
cluster_size : 4
no_of_cluster : 40060 (2 - 40061)
fat_length 157 calculated 157
NTFS at 10/18/9
NTFS at 1968/50/3
Info: size boot_sector 149117265, partition 149117271
test_FAT()
5 L FAT16 >32M 11250 107 58 121600 247 55 1772781568
sector_size 0
cluster_size 0
reserved 0
fats 0
dir_entries 0
sectors 0
media 00
fat_length 0
secs_track 0
heads 0
hidden 0
total_sect 0
1 P hid. FAT16 LBA 0 1 1 9 254 63 160587 [DellUtility]
2 P HPFS - NTFS 10 18 9 1968 50 2 31457280 [RECOVERY]
3 * HPFS - NTFS 1968 50 3 11250 80 53 149117271 [OS]
4 E extended LBA 11250 79 63 121601 0 1 1772783777
Invalid FAT boot sector
FAT16 at 0/1/1
FAT1 : 1-157
FAT2 : 158-314
start_rootdir : 315
Data : 347-160586
sectors : 160587
cluster_size : 4
FAT16 at 0/1/1
FAT16 >32M 0 1 1 9 254 63 160587 [DellUtility]
FAT16, blocksize=2048, 82 MB / 78 MiB
FAT32 at 10/0/1
FAT1 : 32-8229
FAT2 : 8230-16427
start_rootdir : 16428 root cluster : 2
Data : 16428-67119531
sectors : 67119570
cluster_size : 64
no_of_cluster : 1048486 (2 - 1048487)
fat_length 8198 calculated 8192
FAT differs, FAT sectors=0-16/8198
FAT32 at 10/0/1
FAT32 LBA 10 0 1 4187 254 63 67119570 [ Unlabeled]
FAT32, blocksize=32768, 34 GB / 32 GiB
NTFS at 6724/238/43
filesystem size 6174
sectors_per_cluster 1
mft_lcn 2058
mftmirr_lcn 5162
clusters_per_mft_record 2
clusters_per_index_record 8
HPFS - NTFS 6724 238 43 6725 81 42 6174 [Boot]
file_pread(4,2,buffer,1953525760(121601/90/26)) lseek err Invalid argument
file_pread(4,1,buffer,1953525760(121601/90/26)) lseek err Invalid argument
file_pread(4,8,buffer,1953525248(121601/82/18)) lseek err Invalid argument
file_pread(4,1,buffer,1953525248(121601/82/18)) lseek err Invalid argument
file_pread(4,8,buffer,1953525376(121601/84/20)) lseek err Invalid argument
file_pread(4,8,buffer,1953525504(121601/86/22)) lseek err Invalid argument
file_pread(4,8,buffer,1953525632(121601/88/24)) lseek err Invalid argument
file_pread(4,7,buffer,1953525761(121601/90/27)) lseek err Invalid argument
file_pread(4,16,buffer,1953525760(121601/90/26)) lseek err Invalid argument
file_pread(4,3,buffer,1953525776(121601/90/42)) lseek err Invalid argument
file_pread(4,3,buffer,1953525823(121601/91/26)) lseek err Invalid argument
file_pread(4,8,buffer,1953525839(121601/91/42)) lseek err Invalid argument
file_pread(4,11,buffer,1953525886(121601/92/26)) lseek err Invalid argument
file_pread(4,2,buffer,1953527808(121601/122/58)) lseek err Invalid argument
* FAT16 >32M 0 1 1 9 254 63 160587 [DellUtility]
P FAT32 LBA 10 0 1 4187 254 63 67119570 [ Unlabeled]
P HPFS - NTFS 6724 238 43 6725 113 44 8192 [Boot]
NTFS, blocksize=512, 4194 KB / 4096 KiB
Change partition type:
add_ext_part_i386: max
1 * FAT16 >32M 0 1 1 9 254 63 160587 [DellUtility]
2 P FAT32 LBA 10 0 1 4187 254 63 67119570 [ Unlabeled]
3 P HPFS - NTFS 6724 238 43 6725 113 44 8192 [Boot]
4 E extended LBA 6725 113 45 121601 57 56 1845479424
prady
Re: My data partition now is an unreadable "Raw" format
#2 Post by prady »
Anyone? :cry:
#3 Post by Fiona »
There ist a FAT16-partition and it probably, that's wrong?
Did you create a new partition?
If not, a boot sector diagnose on your FAT16-partition would be recommended.
You can change the partition type under the menu Advanced and Type.
Do you know your previous file system, has it been FAT32LBA or NTFS?
Pleaswe let me know.
Instructions will follow.
prady
#4 Post by prady »
Thank you Fiona!
As far as I remember, the structure was that one shown in the first image, and the J: partition was formatted in NTFS.
When I bought my Dell PC, the hard Drive was already partitioned in C: and D:, plus that hidden partition I believe. Then I created J:.
A couple of weeks ago I squeezed J: and stretched C: with partition wizard, but I got an error at the end of the process and my PC crashed, but everything seemed fine after a restart.
And now there is this mess...
P.s. I've just created an exact copy of the Hard Drive with acronis true image, so I can perform all the tests without any worry.
prady
#5 Post by prady »
I'm trying to recover my files using a data recovery SW, and it seems that it detects a NTFS partition.
Data recovery.png (22.59 KiB) Viewed 5022 times
