I have searched through previous forum posts but have not been able to find a solution for my problem. I recently received an external HD with 1.82 TB of data loaded onto it. I am attempting to access the data, however I get the following error on Mac when attempting to connect the external: "The disk you inserted was not readable by this computer."
I have run test disk, and it seems as though the 2 partitions (EFI System and MS Data) are overlapping:
Disk /dev/rdisk1 - 2000 GB / 1863 GiB - CHS 7630917 16 32
>D EFI System 40 409639 409600 [EFI]
D MS Data 2046 3907028989 3907026944
After a few seconds of a Deeper Search, I get the following:
D EFI System 46 409645 409600 [EFI]
>D MS Data 2048 3907028991 3907026944
If I press P on the final partition, I am able to see all of the files. I am also able to copy files from the partition onto my local HD. However, I am unable to set both an EFI and MS Data as Primary because of the overlap (EFI ends around 409,640 and MS Data starts at 2046 or 2048).
Attached is the log. As it is a 2 TB drive, I have not completed a Deeper Scan.
Thu Mar 14 18:23:20 2013
TestDisk 6.14-WIP, Data Recovery Utility, March 2013
OS: Darwin, kernel 12.2.0 (Darwin Kernel Version 12.2.0: Sat Aug 25 00:48:52 PDT 2012; root:xnu-2050.1
Compiler: GCC 4.0
Compilation date: 2013-03-10T16:31:24
ext2fs lib: 1.41.8, ntfs lib: libntfs-3g, reiserfs lib: 0.3.1-rc8, ewf lib: 20120504
Disk /dev/disk0 - 512 GB / 476 GiB - 1000215216 sectors (RO), sector size=512
Disk /dev/disk1 - 2000 GB / 1863 GiB - 3907029152 sectors, sector size=512
Disk /dev/rdisk0 - 512 GB / 476 GiB - 1000215216 sectors (RO), sector size=512
Disk /dev/rdisk1 - 2000 GB / 1863 GiB - 3907029152 sectors, sector size=512
Partition table type: EFI GPT
New geometry
Disk /dev/rdisk1 - 2000 GB / 1863 GiB - CHS 7630917 16 32 sector_size=512
Analyse Disk /dev/rdisk1 - 2000 GB / 1863 GiB - CHS 7630917 16 32
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=3907029503 (expected 3907029503)
hdr_lba_start=34
hdr_lba_end=3907029470
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
1 P MS Data 2048 3907028991 3907026944
FAT32 at 0/1/9
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
FAT differs, FAT sectors=0-16/3151
FAT32 at 0/1/9
block_group_nr 3
recover_EXT2: s_block_group_nr=3/14904, s_mnt_count=1/22, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 488378368
recover_EXT2: part_size 3907026944
ext3 blocksize=4096 Large file Sparse superblock Backup superblock, 2000 GB / 1863 GiB
FAT32 at 0/1/9
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
FAT32 at 0/1/9
FAT32 at 0/1/15
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
FAT32 at 0/1/15
recover_EXT2: s_block_group_nr=0/14904, s_mnt_count=3/22, s_blocks_per_group=32768, s_inodes_per_group=8192
ext3 blocksize=4096 Large file Sparse superblock, 2000 GB / 1863 GiB
block_group_nr 1
recover_EXT2: s_block_group_nr=1/14904, s_mnt_count=1/22, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 1
dir_partition inode=2
2 drwxr-xr-x 2060 0 4096 5-Feb-2013 13:54 .
2 drwxr-xr-x 2060 0 4096 5-Feb-2013 13:54 ..
11 drwx------ 0 0 16384 5-Feb-2013 13:47 lost+found
114966529 drwxr-xr-x 2060 99 4096 6-Feb-2013 06:13 BCON
51355649 drwxr-xr-x 2060 99 4096 6-Feb-2013 07:14 OTHER
19996673 drwxr-xr-x 2060 99 102400 6-Feb-2013 05:53 MCIP
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
FAT32 at 0/1/9
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
FAT32 at 0/1/9
block_group_nr 3
FAT32 at 0/1/9
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
FAT32 at 0/1/9
FAT32 at 0/1/15
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
FAT32 at 0/1/15
block_group_nr 1
block_group_nr 1
block_group_nr 3
block_group_nr 3
block_group_nr 5
recover_EXT2: "e2fsck -b 163840 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=5/14904, s_mnt_count=1/22, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 5
block_group_nr 7
recover_EXT2: "e2fsck -b 229376 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=7/14904, s_mnt_count=1/22, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 7
block_group_nr 9
recover_EXT2: "e2fsck -b 294912 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=9/14904, s_mnt_count=1/22, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 9
block_group_nr 25
recover_EXT2: s_block_group_nr=25/14904, s_mnt_count=1/22, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 25
block_group_nr 27
recover_EXT2: "e2fsck -b 884736 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=27/14904, s_mnt_count=1/22, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 27
block_group_nr 49
recover_EXT2: "e2fsck -b 1605632 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=49/14904, s_mnt_count=1/22, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 49
block_group_nr 81
recover_EXT2: "e2fsck -b 2654208 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=81/14904, s_mnt_count=1/22, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 81
Any suggestions on how I might be able to resolve this problem?
Thanks
