support for carving files from other files
Re: support for carving files from other files
If you mean carving from dd or EWF image, run "photorec file.dd".
If your goal is to carve embedded files, ie jpg from a .doc,officially, you can try but it's not officially supported.
photorec /d recup_dir /cmd file.doc blocksize,1,fileopt,txt,disable,searchRe: support for carving files from other files
yes, i want to carve embedded files. i tried with the xm filetype because the file contains xm files in it, and it doesn't recover anything.
the test file https://www.rapidshare.com/files/581506371/testfile.
also, is support for that planned?
Currently xm files are detected only if they begins by the signature "Extended Module: ". It's not the case here.
i uploaded by accident a different file containing mod tracker files (which by the way aren't supported. is support for the mod file type planned?). this is the file containing the xm files. https://www.rapidshare.com/files/3055337305/testfile2.
i checked it with a hex editor and it doesn't contain that string. it has protection.
