I run it (under Win7 from cmd.exe with admin privileges) and it does nothing... waits for 20 seconds and then exits. /log /debug produces an empty log file.
Any ideas?
photorec fails to run Topic is solved
Re: photorec fails to run
Do you have the same problem in safe mode or if you disable your antivirus ?
moshepupkin
Antivirus is not an issue, safe mode I did not try - looks like 6.13 is working
