3 terabyte (3tb) filesystem RAW, boot sectors both "bad"
SkinsFan346
#1 Post by SkinsFan346 »
While attempting to format another drive, my 3 terabyte toshiba canvio external hard drive was "apparently" formatted (never got a format completion pop-up window), so it is possible a full format did not occur.
Either way, both boot sectors (original & backup) are corrupted from the looks of it.
The drive now lists the filesystem in windows (Win 7 pro, 64-bit) as "RAW".
I proceeded to run the testdisk software in hopes of correcting the problem.
I also ran a "Deeper Scan", and the following image is the end result of the search:
testdisk deepscan screen shot
testdisk deepscan screen.png (42.84 KiB) Viewed 4146 times
My original log should be shown below (I am now currently trying to now "RebuildBS" via MFT search).
testdisk MFT search screen shot
testdisk MFT search screen shot.png (12.56 KiB) Viewed 4146 times
Admittedly, I am a bit ignorant on the inner-workings of hard disk recovery, so I appreciate any help that the community can possibly provide.
Thank you for your time, and have a great day.
Brett
Fri Mar 15 20:48:40 2013
TestDisk 6.14-WIP, Data Recovery Utility, March 2013
Compilation date: 2013-03-10T16:32:17
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=320072933376
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=3000592982016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=320072933376
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=3000592982016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=320070483968
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=320070483968
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=2000398901760
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\T:)=3000592723968
Disk /dev/sda - 320 GB / 298 GiB - CHS 38913 255 63, sector size=512 - WDC WD3200BEKT-22F3T0, S/N:2020202057202d44585738453830465033343832, FW:11.01A11
Disk /dev/sdb - 320 GB / 298 GiB - CHS 38913 255 63, sector size=512 - WDC WD3200BEKT-00F3T0, S/N:2020202057202d445857394d38304c5333303930, FW:11.01A11
Disk /dev/sdc - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - FANTOM ST2000DL003-9VT1, S/N:5YD16SH3, FW:2.10
Disk /dev/sdd - 3000 GB / 2794 GiB - CHS 45600 255 63, sector size=4096 - Toshiba External USB 3.0, S/N:3176C413, FW:0201
Disk \\.\PhysicalDrive3 - 3000 GB / 2794 GiB - CHS 45600 255 63, sector size=4096 - Toshiba External USB 3.0, S/N:3176C413, FW:0201
Drive T: - 3000 GB / 2794 GiB - CHS 45600 255 63, sector size=4096 - Toshiba External USB 3.0, S/N:3176C413, FW:0201
Disk /dev/sdd - 3000 GB / 2794 GiB - Toshiba External USB 3.0
Analyse Disk /dev/sdd - 3000 GB / 2794 GiB - CHS 45600 255 63
Invalid NTFS or EXFAT boot
 1 * HPFS - NTFS              0   1  1 45600  41 63  732566583
NTFS at 0/4/5
filesystem size           732566016
sectors_per_cluster       1
mftmirr_lcn               2
clusters_per_mft_record   1
     HPFS - NTFS              0   4  5 45600  36  4  732566016 [TOSHIBA EXT]
file_pread(7,1,buffer,732566650(45600/42/5)) lseek err Invalid argument
file_pread(7,1,buffer,732566784(45600/44/13)) lseek err Invalid argument
file_pread(7,1,buffer,732566656(45600/42/11)) lseek err Invalid argument
file_pread(7,1,buffer,732566672(45600/42/27)) lseek err Invalid argument
file_pread(7,1,buffer,732566688(45600/42/43)) lseek err Invalid argument
file_pread(7,1,buffer,732566704(45600/42/59)) lseek err Invalid argument
file_pread(7,1,buffer,732566720(45600/43/12)) lseek err Invalid argument
file_pread(7,1,buffer,732566736(45600/43/28)) lseek err Invalid argument
file_pread(7,1,buffer,732566752(45600/43/44)) lseek err Invalid argument
file_pread(7,1,buffer,732566768(45600/43/60)) lseek err Invalid argument
file_pread(7,1,buffer,732566785(45600/44/14)) lseek err Invalid argument
file_pread(7,1,buffer,732566786(45600/44/15)) lseek err Invalid argument
file_pread(7,2,buffer,732566791(45600/44/20)) lseek err Invalid argument
file_pread(7,2,buffer,732566793(45600/44/22)) lseek err Invalid argument
file_pread(7,3,buffer,732566799(45600/44/28)) lseek err Invalid argument
file_pread(7,1,buffer,732567040(45600/48/17)) lseek err Invalid argument
   * HPFS - NTFS              0   4  5 45600  36  4  732566016 [TOSHIBA EXT]
dir_partition inode=5
       5 dr-xr-xr-x     0      0         0 14-Mar-2013 20:49 .
       5 dr-xr-xr-x     0      0         0 14-Mar-2013 20:49 ..
      83 dr-xr-xr-x     0      0         0 12-Mar-2013 00:10 C Drive Downloads
   12504 -r--r--r--     0      0       294 10-Mar-2013 14:41 !!CAUTION!!_DO_NOT_MODIFY_YOUR_BACKUP_FILES.txt
      50 dr-xr-xr-x     0      0         0 10-Mar-2013 12:11 $RECYCLE.BIN
      35 dr-xr-xr-x     0      0         0 19-Jan-2013 07:37 autorun
      70 -r--r--r--     0      0       124 29-Aug-2011 04:08 autorun.bak
      71 -r--r--r--     0      0       135  1-Sep-2010 01:29 autorun.inf
   77216 dr-xr-xr-x     0      0         0 14-Mar-2013 19:06 boot
      40 -r--r--r--     0      0      9324  2-Jul-2012 06:58 Declaration of Conformity.pdf
   77160 dr-xr-xr-x     0      0         0 13-Mar-2013 23:16 Downloads
      53 dr-xr-xr-x     0      0         0 11-Mar-2013 20:48 Fantom Drive
   77219 -r--r--r--     0      0    217769 14-Jun-2011 15:54 grldr
   77215 dr-xr-xr-x     0      0         0 14-Mar-2013 19:06 Images(Brett-PC)
   77220 -r--r--r--     0      0       161 14-Mar-2013 19:06 menu.lst
     123 dr-xr-xr-x     0      0         0 10-Mar-2013 14:41 My Files(Brett-PC)
      41 dr-xr-xr-x     0      0         0 19-Jan-2013 07:37 NTI
      44 dr-xr-xr-x     0      0         0 19-Jan-2013 07:37 OpenSourceSoftwareInfo
   12109 dr-xr-xr-x     0      0         0 10-Mar-2013 14:40 restore
      47 -r--r--r--     0      0  15602770 24-May-2012 00:11 Setup.exe
   77181 dr-xr-xr-x     0      0         0 12-Mar-2013 19:04 System Volume Information
      48 -r--r--r--     0      0     75833 23-Apr-2012 13:39 Warranty.pdf
 1 * HPFS - NTFS              0   4  5 45600  36  4  732566016 [TOSHIBA EXT]
NTFS at 0/4/5
mftmirr_lcn               2
NTFS at 0/4/5
mftmirr_lcn               2
ntfs_boot_sector
filesystem size           1
sectors_per_cluster       0
mft_lcn                   0
mftmirr_lcn               0
clusters_per_mft_record   0
clusters_per_index_record 0
Status: Bad
Status: Bad
Sectors are identical.
Re: 3 terabyte (3tb) filesystem RAW, boot sectors both "bad"
Either your boot sector or your file system is damaged.
You can use tetsdisk and the menu "Advanced / Boot to diagnose it.
Please upload another screen shot or copy and paste the content of your testdisk.log.
At the menu List you can list and copy/backup your files first.
At the bottom of the screen shot, you'll find all the commands.
Checking that two dots and pressing enter, you'll come up on directory until you get to your disk selection.
You can select another intact disk as destiny/target where you can to copy your data to.
To navigate into a folder you can use your arrow key on your keyboard.
After backup (recommended) you can write/repair your boot sector using rebuild BS.
Did Rebuild BS help?
If your file system is damaged, boot sector repair is not recommended.
SkinsFan346
#3 Post by SkinsFan346 »
Fiona,
Thank you for the reply.
The "Rebuild BS" via MFT search is still on-going (taken a couple of days...should be finished in the next 8 hours or so...numerous sectors).
When I click "Analyze" and hit "P" to view files on drive, positive results come up, which I believe my initial log shows:
I am hopeful this indicates that if the boot sector can be "rebuilt", then the O/S might be able to recognize the drive once again?
If I am able to "view" files via the "P" keystroke, does that support the notion that the "filesystem" may be intact?
Looking at my log, how does it "read" to you? Are you able to gather anything of significance from it?
It is a new drive, recently purchased it (3/10/13) and just completed the process of transferring data from a 2 tb drive when the inadvertent format occurred.
Also, should I be concerned about the number of "heads" in the partition that testdisk is showing?
It is reporting 41, but should it not be 255?
I will upload results (screens) of the "RebuildBS" when it is finished. Hopefully, I am able to "list" files upon completion of this step.
Loading the information onto another disk might be tricky due to its size (3tb...do not have excess capacity on another drive). Obviously, I am shooting for a new boot sector, which might enable the O/S to recognize the HDD.
Thank you for your assistance Fiona, really appreciate it.
Brett
