TestDisk crash in windows 7
johnswolter
#1 Post by johnswolter »
This is my second attempt to post this problem to this form. The 1st was dropped by the server. I had just registered and logged in for the first time.
TestDisk crashed immediately in Win 7 Standard Home ed. Used admin command prompt in TestDisk directory. testdisk_win results in win 7 crash window.
Download directory is off .../Documents directory which is longer than expected with standard downloads directory. Things are there for historic reasons.
Win 7 64-bit Standard Home Ed
Anti-Virus turned off
Defective USB WD 1140 2T plugged into 3.0 USB
Cheers,
John S Wolter
exobite
Re: TestDisk crash in windows 7
#2 Post by exobite »
I am having the same issue, which is a shame. This was recommended to me by 2 different IT guys.
I start the 64 bit version of testdisk and it crashes the command window it opens.
I am running it as a system admin, and have also tried running it from a windowed state.
Here is the information about the crash as well as my system hardware information below that-
Problem signature:
Problem Event Name: APPCRASH
Application Name: testdisk_win.exe
Application Version: 6.14.0.0
Application Timestamp: 513ca7a5
Fault Module Name: pdcurses.dll
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 5009dd30
Exception Code: c0000005
Exception Offset: 0000000000003675
OS Version: 6.1.7600.2.0.0.256.1
Locale ID: 1033
Additional Information 1: 9dde
Additional Information 2: 9dde8458c8768d25fb69edd51171b604
Additional Information 3: 8cda
Additional Information 4: 8cda9fc4a172c43b005ddb7671cc210d
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid= ... cid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
This is my system hardware and other info
System Information
Time of this report: 3/21/2013, 18:27:42
Machine name: JEREMY-PC
Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7600) (7600.win7_rtm.090713-1255)
Language: English (Regional Setting: English)
System Manufacturer: To Be Filled By O.E.M.
System Model: To Be Filled By O.E.M.
BIOS: BIOS Date: 01/30/10 08:06:51 Ver: 08.00.15
Processor: AMD Phenom(tm) II X4 955 Processor (4 CPUs), ~3.2GHz
Memory: 8192MB RAM
Available OS Memory: 7424MB RAM
Page File: 5326MB used, 9518MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: 96 DPI (100 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7600.16385 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Display Tab 2: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: ATI Radeon HD 5800 Series
Manufacturer: Advanced Micro Devices, Inc.
Chip type: AMD Radeon Graphics Processor (0x689E)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_689E&SUBSYS_200A1787&REV_00
Display Memory: 373 MB
Dedicated Memory: 1013 MB
Shared Memory: 3455 MB
Current Mode: 1280 x 1024 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: DELL 1704FPT
Monitor Id: DEL4004
Native Mode: 1280 x 1024(p) (60.020Hz)
Output Type: HD15
Driver Name: aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
Driver File Version: 8.17.0010.1172 (English)
Driver Version: 9.12.0.0
DDI Version: 10.1
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 12/19/2012 15:08:04, 1151488 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
Device Identifier: {D7B71EE2-2BDE-11CF-A370-0000BEC2C535}
Vendor ID: 0x1002
Device ID: 0x689E
SubSys ID: 0x200A1787
Revision ID: 0x0000
Driver Strong Name: oem74.inf:ATI.Mfg.NTamd64.6.1:ati2mtag_Evergreen:9.12.0.0:pci\ven_1002&dev_689e
Rank Of Driver: 00E62001
Video Accel: ModeMPEG2_A ModeMPEG2_C
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D9 Overlay: Not Supported
DXVA-HD: Not Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Monitor Model: WDE LCM-17v2
Monitor Id: WDE1702
Output Type: HD15
DDI Version: 10.1
WHQL Logo'd: n/a
Vendor ID: 0x1002
Device ID: 0x689E
Revision ID: 0x0000
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Realtek Digital Output (Realtek High Definition Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_105B0E35&REV_1000
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RTKVHD64.sys
Driver Version: 6.00.0001.6363 (English)
WHQL Logo'd: n/a
Date and Size: 5/3/2011 16:33:46, 2854504 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Basic
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Sound Capture Devices
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Controller (Gamepad F310)
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC21D
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x1002, 0x4397
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 7/13/2009 19:07:09, 343040 bytes
| Driver: usbd.sys, 7/13/2009 19:06:23, 7936 bytes
Gameport Devices
PS/2 Devices
+ PS/2 Keyboard
| Matching Device ID: *pnp0303
| Upper Filters: L8042Kbd
| Service: i8042prt
| Driver: L8042Kbd.sys, 6/17/2009 11:53:34, 30736 bytes
| Driver: i8042prt.sys, 7/13/2009 18:19:57, 105472 bytes
| Driver: kbdclass.sys, 7/13/2009 20:48:04, 50768 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
+ HID-compliant mouse
| Vendor/Product ID: 0x04B3, 0x310B
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouhid.sys, 7/13/2009 19:00:20, 31232 bytes
| Driver: mouclass.sys, 7/13/2009 20:48:27, 49216 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
| Driver: termdd.sys, 7/13/2009 20:45:55, 62544 bytes
| Driver: sermouse.sys, 7/13/2009 19:00:20, 26624 bytes
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 295.9 GB
Total Space: 1907.6 GB
File System: NTFS
Model: Hitachi HDS723020BLA642 ATA Device
Drive: D:
Free Space: 430.6 GB
Total Space: 1430.8 GB
File System: NTFS
Model: ST31500541AS ATA Device
Drive: F:
Free Space: 211.4 GB
File System: NTFS
Model: ST31500341AS ATA Device
Drive: G:
Free Space: 2861.3 GB
Total Space: 2861.5 GB
File System: NTFS
Model: ST3000DM001-9YN166 ATA Device
Drive: I:
Model: DTSOFT Virtual CdRom Device
Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7600.16385 (English), 7/13/2009 18:19:54, 147456 bytes
Drive: A:
Model: ATAPI DVD A DH16A6S ATA Device
System Devices
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_1022&DEV_1203&SUBSYS_00000000&REV_00\3&267A616A&0&C3
Driver: n/a
Name: Standard OpenHCD USB Host Controller
Device ID: PCI\VEN_1002&DEV_4399&SUBSYS_43991002&REV_00\3&267A616A&0&A5
Driver: C:\Windows\system32\drivers\usbohci.sys, 6.01.7600.16385 (English), 7/13/2009 19:06:30, 25600 bytes
Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7600.16385 (English), 7/13/2009 19:06:31, 324608 bytes
Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7600.16385 (English), 7/13/2009 19:07:09, 343040 bytes
Name: ATI I/O Communications Processor SMBus Controller
Device ID: PCI\VEN_1002&DEV_4385&SUBSYS_00000000&REV_41\3&267A616A&0&A0
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1202&SUBSYS_00000000&REV_00\3&267A616A&0&C2
Driver: n/a
Device ID: PCI\VEN_1002&DEV_4397&SUBSYS_43971002&REV_00\3&267A616A&0&B0
Name: ATI I/O Communications Processor PCI Bus Controller
Device ID: PCI\VEN_1002&DEV_4384&SUBSYS_00000000&REV_40\3&267A616A&0&A4
Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.01.7600.16385 (English), 7/13/2009 20:45:45, 183872 bytes
Device ID: PCI\VEN_1022&DEV_1201&SUBSYS_00000000&REV_00\3&267A616A&0&C1
Driver: n/a
Device ID: PCI\VEN_1002&DEV_4397&SUBSYS_43971002&REV_00\3&267A616A&0&98
Name: High Definition Audio Controller
Device ID: PCI\VEN_1002&DEV_4383&SUBSYS_43831002&REV_40\3&267A616A&0&A2
Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.01.7600.16385 (English), 7/13/2009 19:06:13, 122368 bytes
Name: VIA 1394 OHCI Compliant Host Controller
Device ID: PCI\VEN_1106&DEV_3044&SUBSYS_0D08105B&REV_C0\4&2B4059EA&0&38A4
Driver: C:\Windows\system32\DRIVERS\1394ohci.sys, 6.01.7600.16385 (English), 7/13/2009 19:07:13, 227840 bytes
Device ID: PCI\VEN_1022&DEV_1200&SUBSYS_00000000&REV_00\3&267A616A&0&C0
Driver: n/a
Device ID: PCI\VEN_1002&DEV_4397&SUBSYS_43971002&REV_00\3&267A616A&0&90
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_1022&DEV_9608&SUBSYS_96011022&REV_00\3&267A616A&0&48
Device ID: PCI\VEN_1002&DEV_AA50&SUBSYS_AA501787&REV_00\4&20E2AD45&0&0110
Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_1002&DEV_4396&SUBSYS_43961002&REV_00\3&267A616A&0&B2
Driver: C:\Windows\system32\drivers\usbehci.sys, 6.01.7600.16385 (English), 7/13/2009 19:06:30, 51200 bytes
Device ID: PCI\VEN_1022&DEV_9603&SUBSYS_96011022&REV_00\3&267A616A&0&10
Name: ATI Radeon HD 5800 Series
Device ID: PCI\VEN_1002&DEV_689E&SUBSYS_200A1787&REV_00\4&20E2AD45&0&0010
Driver: C:\Windows\system32\DRIVERS\atikmdag.sys, 8.01.0001.1278 (English), 12/19/2012 15:48:48, 11278336 bytes
Driver: C:\Windows\system32\DRIVERS\ati2erec.dll, 1.00.0000.0024 (English), 12/19/2012 14:30:16, 53248 bytes
Driver: C:\Windows\system32\DRIVERS\atikmpag.sys, 8.14.0001.6290 (English), 12/19/2012 14:32:54, 552960 bytes
Driver: C:\Windows\system32\atiumd64.dll, 9.14.0010.0945 (English), 12/19/2012 14:44:12, 6786560 bytes
Driver: C:\Windows\system32\atiumd6a.dll, 8.14.0010.0381 (English), 12/19/2012 14:59:44, 5087744 bytes
Driver: C:\Windows\system32\atitmm64.dll, 6.14.0011.0023 (English), 12/19/2012 14:54:38, 120320 bytes
Driver: C:\Windows\system32\atiicdxx.dat, 11/29/2012 10:40:02, 662786 bytes
Driver: C:\Windows\system32\amdpcom64.dll, 8.14.0010.0023 (English), 12/19/2012 14:33:50, 56320 bytes
Driver: C:\Windows\system32\atimpc64.dll, 8.14.0010.0023 (English), 12/19/2012 14:33:50, 56320 bytes
Driver: C:\Windows\system32\atiadlxx.dll, 6.14.0010.1124 (English), 12/19/2012 14:33:42, 619008 bytes
Driver: C:\Windows\system32\atiumd6a.cap, 12/19/2012 14:52:22, 3061872 bytes
Driver: C:\Windows\system32\atimuixx.dll, 6.14.0010.1002 (English), 12/19/2012 14:54:22, 21504 bytes
Driver: C:\Windows\system32\atiapfxx.exe, 6.14.0010.1001 (English), 12/19/2012 15:19:46, 163840 bytes
Driver: C:\Windows\system32\ativvsva.dat, 2/14/2012 21:36:36, 157144 bytes
Driver: C:\Windows\system32\ativvsvl.dat, 2/14/2012 21:36:36, 204952 bytes
Driver: C:\Windows\system32\ativvaxy_cik.dat, 9/4/2012 10:20:18, 228528 bytes
Driver: C:\Windows\system32\ativvaxy_cik_nd.dat, 9/4/2012 10:20:18, 228528 bytes
Driver: C:\Windows\system32\ativce02.dat, 9/19/2012 14:09:40, 76660 bytes
Driver: C:\Windows\system32\atiesrxx.exe, 6.14.0011.1137 (English), 12/19/2012 14:56:00, 240640 bytes
Driver: C:\Windows\system32\atieclxx.exe, 6.14.0011.1137 (English), 12/19/2012 14:56:46, 550912 bytes
Driver: C:\Windows\system32\atiedu64.dll, 6.14.0010.2514 (English), 12/19/2012 14:54:18, 59392 bytes
Driver: C:\Windows\system32\atidemgy.dll, 4.00.4736.26909 (English), 12/19/2012 14:57:00, 442368 bytes
Driver: C:\Windows\system32\atio6axx.dll, 6.14.0010.12002 (English), 12/19/2012 15:29:36, 23461376 bytes
Driver: C:\Windows\system32\aticalrt64.dll, 6.14.0010.1741 (English), 12/19/2012 15:18:04, 51200 bytes
Driver: C:\Windows\system32\aticalcl64.dll, 6.14.0010.1741 (English), 12/19/2012 15:17:54, 44544 bytes
Driver: C:\Windows\system32\aticaldd64.dll, 6.14.0010.1741 (English), 12/19/2012 15:17:40, 16082944 bytes
Driver: C:\Windows\system32\atipblag.dat, 9/12/2011 17:06:16, 3917 bytes
Driver: C:\Windows\system32\atiu9p64.dll, 8.14.0001.6290 (English), 12/19/2012 14:31:00, 104448 bytes
Driver: C:\Windows\system32\atiuxp64.dll, 8.14.0001.6290 (English), 12/19/2012 14:31:14, 130048 bytes
Driver: C:\Windows\system32\atig6pxx.dll, 8.14.0001.6290 (English), 12/19/2012 14:33:18, 17920 bytes
Driver: C:\Windows\system32\atig6txx.dll, 8.14.0001.6290 (English), 12/19/2012 14:33:10, 41984 bytes
Driver: C:\Windows\system32\atibtmon.exe, 2.00.0000.0000 (English), 5/11/2009 17:35:28, 118784 bytes
Driver: C:\Windows\system32\atiapfxx.blb, 12/19/2012 15:39:32, 327960 bytes
Driver: C:\Windows\system32\atidxx64.dll, 8.17.0010.0472 (English), 12/19/2012 14:49:00, 7370752 bytes
Driver: C:\Windows\SysWOW64\atiumdag.dll, 9.14.0010.0945 (English), 12/19/2012 15:50:14, 5630200 bytes
Driver: C:\Windows\SysWOW64\atiumdva.dll, 8.14.0010.0381 (English), 12/19/2012 14:44:28, 4162048 bytes
Driver: C:\Windows\SysWOW64\amdpcom32.dll, 8.14.0010.0023 (English), 12/19/2012 14:33:40, 56832 bytes
Driver: C:\Windows\SysWOW64\atimpc32.dll, 8.14.0010.0023 (English), 12/19/2012 14:33:40, 56832 bytes
Driver: C:\Windows\SysWOW64\atiadlxy.dll, 6.14.0010.1124 (English), 12/19/2012 14:33:32, 421888 bytes
Driver: C:\Windows\SysWOW64\atiumdva.cap, 12/19/2012 14:42:40, 3093792 bytes
Driver: C:\Windows\SysWOW64\ativvsva.dat, 2/14/2012 21:36:36, 157144 bytes
Driver: C:\Windows\SysWOW64\ativvsvl.dat, 2/14/2012 21:36:36, 204952 bytes
Driver: C:\Windows\SysWOW64\ati2edxx.dll, 6.14.0010.2514 (English), 12/19/2012 14:54:12, 43520 bytes
Driver: C:\Windows\SysWOW64\atioglxx.dll, 6.14.0010.12002 (English), 12/19/2012 15:12:44, 18982400 bytes
Driver: C:\Windows\SysWOW64\atidxx32.dll, 8.17.0010.0472 (English), 12/19/2012 15:06:00, 6681088 bytes
Driver: C:\Windows\SysWOW64\aticalrt.dll, 6.14.0010.1741 (English), 12/19/2012 15:18:02, 46080 bytes
Driver: C:\Windows\SysWOW64\aticalcl.dll, 6.14.0010.1741 (English), 12/19/2012 15:17:52, 44032 bytes
Driver: C:\Windows\SysWOW64\aticaldd.dll, 6.14.0010.1741 (English), 12/19/2012 15:13:24, 13703168 bytes
Driver: C:\Windows\SysWOW64\atipblag.dat, 9/12/2011 17:06:16, 3917 bytes
Driver: C:\Windows\SysWOW64\atiu9pag.dll, 8.14.0001.6290 (English), 12/19/2012 14:30:52, 83968 bytes
Driver: C:\Windows\SysWOW64\atiuxpag.dll, 8.14.0001.6290 (English), 12/19/2012 14:31:08, 109568 bytes
Driver: C:\Windows\SysWOW64\atigktxx.dll, 8.14.0001.6290 (English), 12/19/2012 14:33:04, 33280 bytes
Driver: C:\Windows\SysWOW64\atiglpxx.dll, 8.14.0001.6290 (English), 12/19/2012 14:33:14, 14848 bytes
Driver: C:\Windows\SysWOW64\atiapfxx.blb, 12/19/2012 15:39:32, 327960 bytes
Driver: C:\Windows\atiogl.xml, 11/15/2012 11:34:18, 42719 bytes
Driver: C:\Windows\system32\ATIODCLI.exe, 1.00.0000.0001 (English), 6/22/2009 11:34:36, 51200 bytes
Driver: C:\Windows\system32\ATIODE.exe, 1.00.0000.0001 (English), 8/27/2010 14:33:08, 332800 bytes
Driver: C:\Windows\system32\atiglpxx.dll, 8.14.0001.6290 (English), 12/19/2012 14:33:14, 14848 bytes
Driver: C:\Windows\system32\aticfx64.dll, 8.17.0010.1172 (English), 12/19/2012 15:08:04, 1151488 bytes
Driver: C:\Windows\SysWOW64\aticfx32.dll, 8.17.0010.1172 (English), 12/19/2012 15:09:52, 960512 bytes
Driver: C:\Windows\system32\coinst_9.012.dll, 1.00.0004.0008 (English), 12/19/2012 15:22:50, 70144 bytes
Device ID: PCI\VEN_1002&DEV_4396&SUBSYS_43961002&REV_00\3&267A616A&0&9A
Name: Atheros AR8131 PCI-E Gigabit Ethernet Controller (NDIS 6.20)
Device ID: PCI\VEN_1969&DEV_1063&SUBSYS_0E35105B&REV_C0\4&1DFBC464&0&0048
Driver: C:\Windows\system32\DRIVERS\L1C62x64.sys, 1.00.0002.0043 (English), 3/23/2011 10:20:56, 77936 bytes
Device ID: PCI\VEN_1022&DEV_9601&SUBSYS_96011022&REV_00\3&267A616A&0&00
Driver: n/a
Name: PCI standard ISA bridge
Device ID: PCI\VEN_1002&DEV_439D&SUBSYS_439D1002&REV_40\3&267A616A&0&A3
Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.01.7600.16385 (English), 7/13/2009 20:48:27, 15424 bytes
Device ID: PCI\VEN_1002&DEV_4396&SUBSYS_43961002&REV_00\3&267A616A&0&92
Device ID: PCI\VEN_1022&DEV_1204&SUBSYS_00000000&REV_00\3&267A616A&0&C4
Driver: n/a
Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_1002&DEV_439C&SUBSYS_439C1002&REV_40\3&267A616A&0&A1
Driver: C:\Windows\system32\DRIVERS\pciide.sys, 6.01.7600.16385 (English), 7/13/2009 20:45:45, 12352 bytes
Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.01.7600.16385 (English), 7/13/2009 20:45:46, 48720 bytes
Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.01.7600.16385 (English), 7/13/2009 20:52:21, 24128 bytes
Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.01.7600.16385 (English), 7/13/2009 20:52:21, 155728 bytes
Device ID: PCI\VEN_1002&DEV_4390&SUBSYS_43901002&REV_40\3&267A616A&0&88
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7600.16385
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7600.16385
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7600.16385
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7600.16385
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7600.16385
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
DV Muxer,0x00400000,0,0,qdv.dll,6.06.7600.16385
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7600.16385
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7600.16385
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7600.16385
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7600.16385
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7600.16385
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7600.16385
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7600.16385
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7600.16385
Microsoft TV Captions Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7600.16385
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7600.16385
CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.01.7600.16385
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7600.16385
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7600.16385
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7600.16385
ATI MPEG File Writer,0x00200000,1,0,atimpenc64.dll,12.05.0000.21219
ATI MPEG Video Decoder,0x00200000,1,2,atimpenc64.dll,12.05.0000.21219
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7600.16385
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7600.16385
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7600.16385
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7600.16385
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7600.16385
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7600.16385
DV Splitter,0x00600000,1,2,qdv.dll,6.06.7600.16385
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7600.16385
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7600.16385
ATI MPEG Audio Encoder,0x00200000,1,1,atimpenc64.dll,12.05.0000.21219
AMD MJPEG Decoder,0x00800001,1,1,atimpenc64.dll,12.05.0000.21219
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7600.16385
Video Renderer,0x00800001,1,0,quartz.dll,6.06.7600.16385
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7600.16385
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7600.16385
Video Renderer,0x00400000,1,0,quartz.dll,6.06.7600.16385
ATI MPEG Video Encoder,0x00200000,1,1,atimpenc64.dll,12.05.0000.21219
ATI MPEG Multiplexer,0x00200000,2,1,atimpenc64.dll,12.05.0000.21219
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7600.16385
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7600.16385
Sony Wave Hammer Surround,0x00200000,1,1,mchammer_x64.dll,1.00.0000.1439
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7600.16385
File writer,0x00200000,1,0,qcap.dll,6.06.7600.16385
iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7600.16385
iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7600.16385
ATI Video Scaler Filter,0x00200000,1,1,atimpenc64.dll,12.05.0000.21219
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7600.16385
Microsoft TV Subtitles Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7600.16385
Overlay Mixer2,0x00200000,1,1,,
AC3Filter,0x40000000,1,1,ac3filter64.ax,1.03.0001.0000
RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7600.16385
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7600.16385
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7600.16385
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7600.16385
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7600.16385
Null Renderer,0x00200000,1,0,qedit.dll,6.06.7600.16385
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7600.16385
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7600.16385
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7600.16385
Smart Tee,0x00200000,1,2,qcap.dll,6.06.7600.16385
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7600.16385
NetBridge,0x00200000,2,0,netbridge.dll,6.01.7600.16385
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7600.16385
Wave Parser,0x00400000,1,1,quartz.dll,6.06.7600.16385
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7600.16385
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7600.16385
File stream renderer,0x00400000,1,1,quartz.dll,6.06.7600.16385
ATI Video Rotation Filter,0x00200000,1,1,atimpenc64.dll,12.05.0000.21219
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7600.16385
AVI Mux,0x00200000,1,0,qcap.dll,6.06.7600.16385
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7600.16385
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7600.16385
File Source (URL),0x00400000,0,1,quartz.dll,6.06.7600.16385
Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.7600.16385
AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7600.16385
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7600.16385
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7600.16385
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7600.16385
Sony ExpressFX Chorus,0x00200000,1,1,sfxpfx2_x64.dll,1.00.0000.1435
Sony ExpressFX Delay,0x00200000,1,1,sfxpfx2_x64.dll,1.00.0000.1435
Sony ExpressFX Distortion,0x00200000,1,1,sfxpfx1_x64.dll,1.00.0000.1435
Sony ExpressFX Equalization,0x00200000,1,1,sfxpfx2_x64.dll,1.00.0000.1435
Sony ExpressFX Flange/Wah-Wah,0x00200000,1,1,sfxpfx1_x64.dll,1.00.0000.1435
Sony ExpressFX Amplitude Modulation,0x00200000,1,1,sfxpfx2_x64.dll,1.00.0000.1435
Sony ExpressFX Reverb,0x00200000,1,1,sfxpfx1_x64.dll,1.00.0000.1435
Sony ExpressFX Stutter,0x00200000,1,1,sfxpfx1_x64.dll,1.00.0000.1435
Sony ExpressFX Dynamics,0x00200000,1,1,sfxpfx3_x64.dll,1.00.0000.1435
Sony ExpressFX Graphic EQ,0x00200000,1,1,sfxpfx3_x64.dll,1.00.0000.1435
Sony ExpressFX Noise Gate,0x00200000,1,1,sfxpfx3_x64.dll,1.00.0000.1435
Sony ExpressFX Time Stretch,0x00200000,1,1,sfxpfx3_x64.dll,1.00.0000.1435
Sony ExpressFX Audio Restoration,0x00200000,1,1,xpvinyl_x64.dll,1.00.0000.1919
Sony Multi-Band Dynamics,0x00200000,1,1,sfppack2_x64.dll,1.00.0000.1435
Sony Track Compressor,0x00200000,1,1,sftrkfx1_x64.dll,1.00.0000.1440
Sony Dither,0x00200000,1,1,sftrkfx1_x64.dll,1.00.0000.1440
Sony Chorus,0x00200000,1,1,sfppack1_x64.dll,1.00.0000.1435
Sony Distortion,0x00200000,1,1,sfppack3_x64.dll,1.00.0000.1435
Sony Gapper/Snipper,0x00200000,1,1,sfppack3_x64.dll,1.00.0000.1435
Sony Simple Delay,0x00200000,1,1,sfppack1_x64.dll,1.00.0000.1435
Sony Reverb,0x00200000,1,1,sfppack1_x64.dll,1.00.0000.1435
Sony Multi-Tap Delay,0x00200000,1,1,sfppack1_x64.dll,1.00.0000.1435
Sony Track Noise Gate,0x00200000,1,1,sftrkfx1_x64.dll,1.00.0000.1440
Sony Graphic EQ,0x00200000,1,1,sfppack2_x64.dll,1.00.0000.1435
Sony Track EQ,0x00200000,1,1,sftrkfx1_x64.dll,1.00.0000.1440
Sony Smooth/Enhance,0x00200000,1,1,sfppack3_x64.dll,1.00.0000.1435
Sony Resonant Filter,0x00200000,1,1,sfresfilter_x64.dll,1.00.0000.1439
Sony Parametric EQ,0x00200000,1,1,sfppack2_x64.dll,1.00.0000.1435
Sony Time Stretch,0x00200000,1,1,sfppack1_x64.dll,1.00.0000.1435
Sony Noise Gate,0x00200000,1,1,sfppack2_x64.dll,1.00.0000.1435
Sony Paragraphic EQ,0x00200000,1,1,sfppack2_x64.dll,1.00.0000.1435
Sony Vibrato,0x00200000,1,1,sfppack3_x64.dll,1.00.0000.1435
Sony Pan,0x00200000,1,1,sffrgpnv_x64.dll,1.00.0000.1439
Sony Pitch Shift,0x00200000,1,1,sfppack1_x64.dll,1.00.0000.1435
Sony Volume,0x00200000,1,1,sffrgpnv_x64.dll,1.00.0000.1439
Sony Flange/Wah-wah,0x00200000,1,1,sfppack3_x64.dll,1.00.0000.1435
Sony Graphic Dynamics,0x00200000,1,1,sfppack2_x64.dll,1.00.0000.1435
Sony Amplitude Modulation,0x00200000,1,1,sfppack3_x64.dll,1.00.0000.1435
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7600.16385
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7600.16385
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7600.16385
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7600.16385
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7600.16385
CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7600.16385
CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7600.16385
AC3,0x00200000,1,1,quartz.dll,6.06.7600.16385
DTS,0x00200000,1,1,quartz.dll,6.06.7600.16385
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7600.16385
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7600.16385
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7600.16385
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7600.16385
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7600.16385
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7600.16385
WDM Streaming Capture Devices:
,0x00000000,0,0,,
Realtek HD Audio CD input,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
,0x00000000,0,0,,
Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
WDM Streaming Rendering Devices:
Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
Realtek HDA SPDIF Out,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7600.16385
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7600.16385
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7600.16385
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7600.16385
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7600.16385
PTFilter,0x00200000,0,0,EncDec.dll,6.06.7600.16385
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7600.16385
WDM Streaming Communication Transforms:
Audio Renderers:
Realtek Digital Output (Realtek,0x00200000,1,0,quartz.dll,6.06.7600.16385
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7600.16385
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7600.16385
DirectSound: Realtek Digital Output (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7600.16385
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
exobite
#3 Post by exobite »
After researching (which I should have done) I found that the 32 bit worked on my 64 bit system.
