Can I rely on order of copying files? Topic is solved
aensidhe
#1 Post by aensidhe »
I started copying process from bad partition to new HDD and accidentally select "System Volume Information" folder. Can I be sure that TestDisk at least tried (and may be succeeded) to copy folders that starts are predecessors of "SVI" in alphabetical order?
aensidhe
Re: Can I rely on order of copying files?
#2 Post by aensidhe »
I think I can answer this question myself.
You can rely on order of files and folders which you can see in TestDisk "list file on partition".
At least my experiments showed that.
