Good evening.
I’m trying to save using TestDisk (16.4), my lost data from a damaged external HD.
But my knowledge is not enough for me to understand what am I actually doing, so I’m afraid to worse the situation.
Here are the steps I’ve done up to now, and the point in which I have stopped myself. Will anybody tell me whether I’m doing the right choices, and how I can go on?
I’m using windows7. The external disk is a Packard Bell Carbon.
Thanks in advance for any answer.
Greetings from Italy.
0) I created a new log file [Enter]
1) I selected the broken device [Proceed]
2) I selected [Intel] as partition table type
3) I chose the command [Analyse]
4) On the next page I selected [Quick Search]
5) At the end of the search it seemed I obtained nothing [enter]
6) Therefore on the next page I selected [Deeper Search] to look for more partitions
7) Even the deeper search hasn't found anything, so I chose to load backup [L]
8) I selected the first backup and then [Load]
9) Now I'm asked to select a partition. But here I stop because I don't know how to go on.
Which disk does it refer to? Which one do I need to select?
Have I done all right so far? And what shall I do now?
I loaded all the print screens here:
http://digilander.libero.it/canetibo/
Thanks again
Maurizio
Need some help to recover lost partition.
Re: Need some help to recover lost partition.
I join the log, maybe it helps.
Sat Mar 23 10:49:38 2013
Compilation date: 2012-10-19T00:17:18
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=1500299395072
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=4142054400
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=1500299395072
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=4142054400
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=247575085056
filewin32_getfilesize(\\.\D:) GetFileSize err Funzione non corretta.
filewin32_setfilepointer(\\.\D:) SetFilePointer err Funzione non corretta.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=2147483648
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=1500298346496
filewin32_getfilesize(\\.\G:) GetFileSize err Funzione non corretta.
filewin32_setfilepointer(\\.\G:) SetFilePointer err Funzione non corretta.
Disk /dev/sda - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - TOSHIBA MK2561GSYN, S/N:2020202020202020202033203831545845325432, FW:MH000C
Disk /dev/sdb - 1500 GB / 1397 GiB - CHS 182401 255 63, sector size=512 - WD Ext HDD 1021, S/N:WMAVU2876354, FW:2002
Disk /dev/sdc - 4142 MB / 3950 MiB - CHS 503 255 63, sector size=512 - Packard Bell Carbon, FW:0000
Disk /dev/sdc - 4142 MB / 3950 MiB - Packard Bell Carbon
Analyse Disk /dev/sdc - 4142 MB / 3950 MiB - CHS 503 255 63
Partition: Read error
file_pread(6,16,buffer,32(0/0/33)) ReadFile Errore nei dati (controllo di ridondanza ciclico).
(...) [cut more than 100.000 similar lines]
file_pread(6,3,buffer,7972927(496/74/26)) ReadFile Errore nei dati (controllo di ridondanza ciclico).
