Help needed to recover my files
gordonuk
#1 Post by gordonuk »
Hi everyone,
I need some help recovering some files I have on my external iomega hard drive. It was working fine for many months but then I started experiencing problems with it where it would not be recognised by computer and the file format changed to RAW from NFTS. I have since learned that the problem probably occured because i simply unplugged my external hard drive from the USB port without safely removing it first.
Anyway I need to recover my files on this external hard drive and would be grateful for any assistance as I am a complete newbie with this technical stuff.
What I would like is step by step instructions so that I can find my files on this corrupted external hard drive so that I can copy it onto a new external hard drive.
How would I go about this? Whats the simplest method? Step by step instructions would be useful.
Just a quick point when I have done a quick scan and deeper scan of this external hard drive it did not find any partitions.
Many thanks in advance.
Re: Help needed to recover my files
I'd need a screen shot from TestDisk / Analyse or you can copy and paste the content of the testdisk.log in your post.
You'll find the testdisk.log in your testdisk folder.
gordonuk
#3 Post by gordonuk »
Hi Fiona,
Sorry for the delay in responding.
I have found the test log but it says it needs to be unzipped and I do not know how to do this. It also says that windows does not recognize the file type.
I am using Windows Vista.
Many thanks.
#4 Post by Fiona »
Normally you'll find it in your testdisk folder?
It's a txt-file and shouldn't be zipped only for uploading purposes.
That's why I' have no idea why it should be unzipped?
Did you unzip testdisk after downloading it?
gordonuk
#5 Post by gordonuk »
Hi Fiona,
Yes i unzipped the Test Disk software after downloading it and now i have to unzip the log file.
Many thanks.
#6 Post by Fiona »
Would it be possible to upload your testdisk.log, so I can check it?
Immediately after your response, I downloaded testdisk 6.14WIP and tested it.
In my case, it wasn't zipped.
I used the windows version 6.14WIP.
Please let me know, your OS and testdisk version!
gordonuk
#7 Post by gordonuk »
Hi Fiona,
I tried to post my log file several times this week but i kept getting an error message:
Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 14117158 bytes) in /var/www/html/sites/cgforum/public_html/phpBB3/includes/abm/functions.php on line 1247
I am not sure if this post will be successfully be added but i am using the same Test Disk as you 6.14-WIP and i am also using Windows Vista.
I will also try to upload my Desk Disk log if this post is added successfully.
Many thanks.
gordonuk
#8 Post by gordonuk »
Hi Fiona,
When I try uploading the Test Disk log as part of this post it is always unsuccessful. And I have tried this a dozen times. Either the browser (Firefox) crashes or in internet explorer it simply does not upload.
Is there a limit to the file size you can upload to this forum? Because the Test Disk log is quite big because the external hard drive is 1000gb.
Many thanks.
