partition not visible
formby1
#1 Post by formby1 »
This is my first post although I have read quite a few and I am hoping some one could give some advice.
My daughters wd elements 2tB external disk has suffered a broken usb connector.It was damaged when the cable was knocked side ways. after checking the connection internally the usb could not be repaired so I removed the pcb and bought another enclosure ( dynamode) and connected using sata connector and eternal power source through usb to my laptop which has testdisk on it. After connecting and running testdisk it would seem to show more than one disk.( excluding the laptop disk)
/dev/sdb - 2000 GB / 1863 GiB - CHS 30400 255 63, sector size=4096 - WDC WD20 EARX-32PASB0, S/N:152D20337A0C
Disk \\.\PhysicalDrive1 - 2000 GB / 1863 GiB - CHS 30400 255 63, sector size=4096 - WDC WD20 EARX-32PASB0, S/N:152D20337A0C
Drive E: - 2000 GB / 1863 GiB - CHS 30400 255 63, sector size=4096 - WDC WD20 EARX-32PASB0, S/N:152D20337A0C
I have tried to go thru testdisk step by step including a deeper scan but i still cannot get the drive to be recognised. I have managed to list all the files ( so I know at the moment I can at least save the most important files)I have included the log file upto analysing the HDD. any help from the info contained would be much appreciated thanks in advance
LOGFILE
Wed Mar 27 19:31:01 2013
TestDisk 6.14-WIP, Data Recovery Utility, March 2013
OS: Windows Vista (6002) SP2
Compilation date: 2013-03-25T17:15:35
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=119398162944
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=115639210496
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=2000395698176
Disk /dev/sda - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - WDC WD25 00BEVS-22UST, S/N:W -DXW3E80FE0634, FW:01.0
Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 30400 255 63, sector size=4096 - WDC WD20 EARX-32PASB0, S/N:152D20337A0C
Disk /dev/sdb - 2000 GB / 1863 GiB - WDC WD20 EARX-32PASB0
Analyse Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 30400 255 63
NTFS at 0/4/5
Info: size boot_sector 3907022848, partition 488377856
1 * HPFS - NTFS 0 4 5 30400 33 33 488377856 [kayleigh WD Drive]
NTFS at 0/4/5
filesystem size 3907022848
mftmirr_lcn 244188927
file_pread(5,1,buffer,488378880(30400/45/46)) lseek err Invalid argument
file_pread(5,1,buffer,488378656(30400/42/11)) lseek err Invalid argument
file_pread(5,1,buffer,488378672(30400/42/27)) lseek err Invalid argument
file_pread(5,1,buffer,488378688(30400/42/43)) lseek err Invalid argument
file_pread(5,1,buffer,488378704(30400/42/59)) lseek err Invalid argument
file_pread(5,1,buffer,488378720(30400/43/12)) lseek err Invalid argument
file_pread(5,1,buffer,488378736(30400/43/28)) lseek err Invalid argument
file_pread(5,1,buffer,488378752(30400/43/44)) lseek err Invalid argument
file_pread(5,1,buffer,488378768(30400/43/60)) lseek err Invalid argument
file_pread(5,1,buffer,488378784(30400/44/13)) lseek err Invalid argument
file_pread(5,1,buffer,488378800(30400/44/29)) lseek err Invalid argument
file_pread(5,1,buffer,488378816(30400/44/45)) lseek err Invalid argument
file_pread(5,1,buffer,488378832(30400/44/61)) lseek err Invalid argument
file_pread(5,1,buffer,488378848(30400/45/14)) lseek err Invalid argument
file_pread(5,1,buffer,488378864(30400/45/30)) lseek err Invalid argument
file_pread(5,1,buffer,488378881(30400/45/47)) lseek err Invalid argument
file_pread(5,1,buffer,488378882(30400/45/48)) lseek err Invalid argument
file_pread(5,2,buffer,488378887(30400/45/53)) lseek err Invalid argument
file_pread(5,2,buffer,488378889(30400/45/55)) lseek err Invalid argument
file_pread(5,3,buffer,488378895(30400/45/61)) lseek err Invalid argument
file_pread(5,1,buffer,488379136(30400/49/50)) lseek err Invalid argument
Disk \\.\PhysicalDrive1 - 2000 GB / 1863 GiB - WDC WD20 EARX-32PASB0
Analyse Disk \\.\PhysicalDrive1 - 2000 GB / 1863 GiB - CHS 30400 255 63
NTFS at 0/4/5
NTFS at 0/4/5
Drive E: - 2000 GB / 1863 GiB - WDC WD20 EARX-32PASB0
Analyse Drive E: - 2000 GB / 1863 GiB - CHS 30400 255 63
Geometry from i386 MBR: head=117 sector=51
BAD_RS LBA=6579571 5870008
check_part_i386 1 type 70: no test
BAD_RS LBA=1953251627 4634015
check_part_i386 2 type 43: no test
BAD_RS LBA=225735265 4634074
check_part_i386 3 type 72: no test
1 * DiskSecure MB 409 142 41 119790 20 38 1917848077
Bad relative sector.
2 * Sys=43 121584 74 6 234785 103 28 1818575915
3 * Sys=72 14051 94 29 14051 94 38 10
