The harddisk seems to small - Partion cannot be recovered?!
AU77
#1 Post by AU77 »
My PC is unable to read an external HD which worked fine until last year. After searching the Internet many sources agreed TestDisk was the best solution out there so I hope you can assist me.
After running the Testdisk diagnostic I've come across the following message:
<<The harddisk <250 GB/ 232 Gib> seems to small! <<500GB / 465 Gib>>
The following partition can't be recovered.
At this point I am not entirely sure what should I do as my goal is to preserve the information stored in the disk.
Below a reading from the log:
Thu Mar 28 01:39:49 2013
TestDisk 6.14-WIP, Data Recovery Utility, March 2013
OS: Windows XP SP2
Compilation date: 2013-03-27T18:51:31
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=250000000000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=250059350016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=250000000000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=250059350016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=137378626560
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=502536192
Disk /dev/sda - 250 GB / 232 GiB - CHS 30394 255 63, sector size=512 - WDC WD2500JS-75NCB3, FW:10.02E04
Disk /dev/sdb - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - Maxtor OneTouch, FW:0125
Drive E: - 502 MB / 479 MiB - CHS 119 64 32, sector size=2048 - TSSTcorp DVD+-RW TS-H553A, FW:DE04
Disk /dev/sdb - 250 GB / 232 GiB - Maxtor OneTouch
New options :
 Dump : No
 Align partition: Yes
 Expert mode : No
Analyse Disk /dev/sdb - 250 GB / 232 GiB - CHS 30401 255 63
Thanks in advanced for any guidance you can provide,
AU
