Check_FAT Cannot read FAT boot sector
HPLMiami
#1 Post by HPLMiami »
Dear Christophe, Fiona, other knowledgeable users of TestDisk:
I beg for your help on this matter. I had a problem with an external hard drive I have pretty much EVERYTHING and now I am loosing my mind.
Here are the details:
External hard drive: ADATA Nobility NH92 (500 GB)
I was using it attached to an old IBM Thinkpad R31 (USB 1.0, probably) running XPSP3. I finished copying the files I needed and tried to remove it properly, using the little icon at the right hand bottom. It complained that the drive was still busy and it could not relinquish it. I did what I usually do on similar circumstances: I proceeded to turn of the computer, again, properly, using Start, Power Down.
Since then I cannot access the contents of the hard drive.
I have tried in different PCs and even a Mac to no avail. All I can see is as RAW on the PCs.
I am using the very latest version of TestDisk. I have tried booting from the suggested LInux bootable drive and then by itself, running on a Windows 8 PC. The attached print screens and logs are from this last try.
What am I doing wrong? Thanks in advance for all your help.
TestDisk Print Screens
Print screen
Print screen
Last print screen
Last print screen
Here is the log:
Fri Mar 29 22:07:11 2013
TestDisk 6.14-WIP, Data Recovery Utility, March 2013
Compilation date: 2013-03-27T18:51:31
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=977834868736
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=20783824896
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=500105217024
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC WD10EZEX-60ZF5A0, S/N:WD-WCC1S1025873, FW:80.00A80
Disk /dev/sdc - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - A-DATA NH92, S/N:NH010122300E
Disk /dev/sdc - 500 GB / 465 GiB - A-DATA NH92
Analyse Disk /dev/sdc - 500 GB / 465 GiB - CHS 60801 255 63
test_FAT()
1 * FAT32 LBA 0 1 1 60800 254 63 976768002
sector_size 0
cluster_size 0
reserved 10762
fats 0
dir_entries 0
sectors 16128
media 00
fat_length 512
secs_track 0
heads 0
hidden 1627389952
total_sect 0
Invalid FAT boot sector
Backup partition structure
partition_save
BAD_RS LBA=514759050 10504906
file_pread(5,3,buffer,514759050(299391/157/41)) lseek err Invalid argument
file_pread(5,1,buffer,514759050(299391/157/41)) lseek err Invalid argument
FAT12 299391 157 41 436954 61 24 2209943531
This partition ends after the disk limits. (start=514759050, size=2209943531, end=2724702580, disk end=976773168)
file_pread(5,1,buffer,976773183(60801/81/16)) lseek err Invalid argument
file_pread(5,8,buffer,976773199(60801/81/32)) lseek err Invalid argument
file_pread(5,11,buffer,976773246(60801/82/16)) lseek err Invalid argument
file_pread(5,2,buffer,976775168(60801/112/48)) lseek err Invalid argument
file_pread(5,14,buffer,976775170(60801/112/50)) lseek err Invalid argument
file_pread(5,3,buffer,976775184(60801/113/1)) lseek err Invalid argument
file_pread(5,3,buffer,976775231(60801/113/48)) lseek err Invalid argument
file_pread(5,8,buffer,976775247(60801/114/1)) lseek err Invalid argument
file_pread(5,11,buffer,976775294(60801/114/48)) lseek err Invalid argument
file_pread(5,2,buffer,976777216(60801/145/17)) lseek err Invalid argument
The harddisk (500 GB / 465 GiB) seems too small! (< 3594 GB / 3347 GiB)
Re: Check_FAT Cannot read FAT boot sector
Your partition is still in your poartition table.
Although it's not directly Intel standard, because it uses the last cylinder of your disk.
Despite that, you can run a boot sector diagnose first.
Confirm at Boot.
HPLMiami
#3 Post by HPLMiami »
Dear Fiona,
Thank you so much for your prompt reply. Here are the print screens and logs of the results. I answered N at the last print screen that says Answer Y(es), N(o), Q(uit) or A(bort interactive mode). N or A if not sure.
First Print Screen:
Second Print Screen:
Last Print Screen:
Here is the contents of the log file:
Sun Mar 31 16:18:06 2013
test_FAT()
sector_size 0
cluster_size 0
reserved 10762
fats 0
dir_entries 0
sectors 16128
media 00
fat_length 512
secs_track 0
heads 0
hidden 1627389952
total_sect 0
fat32_boot_sector
FAT32 at 0/1/1
Info: size boot_sector 976768002, partition 976768002
FAT1 : 32-119237
FAT2 : 119238-238443
start_rootdir : 238444 root cluster : 2
Data : 238444-976767979
sectors : 976768002
cluster_size : 64
no_of_cluster : 15258274 (2 - 15258275)
fat_length 119206 calculated 119206
FAT differs, FAT sectors=0-16/119206
Bad
OK
First sectors (Boot code and partition information) are not identical.
Second sectors (cluster information) are not identical.
Third sectors (Second part of boot code) are not identical.
copy backup boot sector over boot sector
fat32_boot_sector
FAT32 at 0/1/1
FAT1 : 32-119237
sectors : 976768002
cluster_size : 64
FAT32 at 0/1/1
FAT1 : 32-119237
sectors : 976768002
cluster_size : 64
OK
OK
Sectors are identical.
HPLMiami
#4 Post by HPLMiami »
Fiona,
Even though I did press N, it continued to run. Here is how the screen looks like right now. It shows 36% progress in the search. I will not touch it and let it run until tomorrow.
HPLMiami
#5 Post by HPLMiami »
Fiona,
Here are three print screens of what happened throughout the night, plus the log.
Again, I thank you in advance for the help.
Print Screens:
Log (P.S. I cannot copy and past the log. It seems too big for this board application. I cannot attach it as a ".log" or a ".txt" file. How can I pass along the whole log, please? I am pasting some parts of it):
Top of the log:
test_FAT()
sector_size 0
cluster_size 0
reserved 10762
fats 0
dir_entries 0
sectors 16128
media 00
fat_length 512
secs_track 0
heads 0
hidden 1627389952
total_sect 0
fat32_boot_sector
FAT32 at 0/1/1
FAT1 : 32-119237
sectors : 976768002
cluster_size : 64
Bad
OK
fat32_boot_sector
FAT32 at 0/1/1
FAT1 : 32-119237
sectors : 976768002
cluster_size : 64
FAT32 at 0/1/1
FAT1 : 32-119237
sectors : 976768002
cluster_size : 64
OK
OK
rebuild_FAT_BS p_fat12 0, p_fat16 0, p_fat32 1
fat_find_type(max_offset=7631064, p_fat12=0, p_fat16=0, p_fat32=1, debug=1, dump_ind=0)
FAT32 at 32(0/1/33), nbr=101819
FAT32 at 67527(4/52/55), nbr=1
FAT32 at 67818(4/57/31), nbr=1
FAT32 at 67819(4/57/32), nbr=1
FAT32 at 68117(4/62/15), nbr=1
Middle of the log (shows unreadable characters):
3789677025 27-Nov-1955 16:46 ￟￟£££￟￟￟.£££
48555234 -r-xr-xr-x 0 0 3840206052 27-May-1957 16:54 £££¬¬¬¬¬.¬££
82109668 -rwxr-xr-x 0 0 3840337638 31-May-1958 17:26 ¦¬¬¬¦¦¦¦.¦¦¦
132638438 -r-xr-xr-x 0 0 3873892070 2-Dec-1958 17:34 ¦¦₩₩₩₩₩₩.₩₩₩
82240742 -rwxr-xr-x 0 0 3806520548 31-May-1959 17:10 ₩₩₩￧￧￧₩₩.₩¦¦
82109154 -rwxr-xr-x 0 0 3806520034 27-May-1957 16:54 ¬¬¬¬¬¬¬¦.¦¦¦
31580898 -r-xr-xr-x 0 0 3789677026 27-Nov-1955 16:46 ¬¬¬¬¬£££.¬¬¬
48423650 -r-xr-xr-x 0 0 3840205538 27-May-1957 16:54 ￟￟￟£££¬¬.¬££
82109154 -rwxr-xr-x 0 0 3840337638 27-May-1957 16:54 ¦¬¬¬¬¬¬£.££¦
115795686 -rwxr-xr-x 0 0 3873892070 31-May-1959 17:26 ¦¦₩₩₩₩₩₩.¦¦¦
115861222 -r-xr-xr-x 0 0 3840206566 31-May-1959 17:26 ￧￧￧￧￧￧₩₩.₩￧￧
48424164 -rwxr-xr-x 0 0 3806651620 27-May-1958 16:54 ¦₩₩₩₩₩₩¦.¦¦¬
48423650 -rwxr-xr-x 0 0 3806520034 27-May-1957 16:54 ¬¬££££££.¬¬¬
232775647 -r-xr-xr-x 0 0 3755991007 26-Dec-1954 16:18 £££¬¬¬¬¬.¬££
266461665 -r-xr-xr-x 0 0 3806519777 27-Nov-1955 16:34 ￟￟￟£££££.£££
48423650 -r-xr-xr-x 0 0 3789742818 27-May-1957 16:54 ¬¬¬¬££££.£££
82109668 -rwxr-xr-x 0 0 3873892068 31-May-1959 17:26 £££££¦¦¦.₩₩₩
115795686 -rwxr-xr-x 0 0 3873892070 31-May-1959 17:26 ₩₩₩₩₩₩₩₩.₩₩₩
82109154 -rwxr-xr-x 0 0 3840206052 29-May-1957 17:10 ₩₩₩₩¦¦¦₩.₩₩₩
31580898 -rwxr-xr-x 0 0 3789677026 27-May-1957 16:54 ¦¦¦¦¦¦¦¦.¦¦¦
31580641 -rwxr-xr-x 0 0 3755991521 27-Nov-1955 16:46 ￟￟￟£££¬¬.¬¬¬
266461665 -r-xr-xr-x 0 0 3806519777 27-Nov-1955 16:34 ￟￟￟￟￟￟￟￟.￟££
Bottom of the log (I recognize some of the DSCN****.JPG names):
0 0 3439047375 23-Dec-1947 11:34 �ᅡᆲᅪᄎ￐.효
206437559 -r-xr-xr-x 0 0 3472602065 23-Dec-1948 11:54 �ᅢᆳ￐후.ᅡ�ᅮ
88996786 -r-xr-xr-x 0 0 3489379023 21-Dec-1946 22:14 �ᅦ무ᅡᅱ.ᅤᅱ
88996685 -r-xr-xr-x 0 0 3472602830 5-Dec-2028 04:43 �￈ᄡᅰᅤᅰ.ᅤᅰ
Potential root_cluster 14885924
0 -rwxr-xr-x 0 0 0 31-Dec-1979 19:00 £
Potential root_cluster 14954081
7592170 -rwxr-xr-x 0 0 939666 28-Feb-2009 09:39 DSCN1460.JPG
7592199 -rwxr-xr-x 0 0 921258 28-Feb-2009 09:39 DSCN1461.JPG
7592228 -rwxr-xr-x 0 0 1059760 28-Feb-2009 09:39 DSCN1462.JPG
7592261 -rwxr-xr-x 0 0 1084310 28-Feb-2009 09:39 DSCN1463.JPG
7592295 -rwxr-xr-x 0 0 1025783 28-Feb-2009 09:39 DSCN1464.JPG
7592327 -rwxr-xr-x 0 0 1017329 28-Feb-2009 09:40 DSCN1465.JPG
7592359 -rwxr-xr-x 0 0 1036992 28-Feb-2009 09:40 DSCN1466.JPG
7592391 -rwxr-xr-x 0 0 1005415 28-Feb-2009 09:40 DSCN1467.JPG
7592422 -rwxr-xr-x 0 0 1053223 28-Feb-2009 09:44 DSCN1468.JPG
7592455 -rwxr-xr-x 0 0 961867 28-Feb-2009 09:44 DSCN1469.JPG
7592485 -rwxr-xr-x 0 0 978020 28-Feb-2009 11:52 DSCN1470.JPG
7592515 -rwxr-xr-x 0 0 1001793 28-Feb-2009 11:52 DSCN1471.JPG
7592546 -rwxr-xr-x 0 0 978899 28-Feb-2009 12:19 DSCN1472.JPG
7592576 -rwxr-xr-x 0 0 960279 28-Feb-2009 12:51 DSCN1473.JPG
7592606 -rwxr-xr-x 0 0 956571 28-Feb-2009 12:51 DSCN1474.JPG
7592636 -rwxr-xr-x 0 0 938020 28-Feb-2009 12:51 DSCN1475.JPG
7592665 -rwxr-xr-x 0 0 1000005 28-Feb-2009 12:55 DSCN1476.JPG
7592696 -rwxr-xr-x 0 0 987147 28-Feb-2009 12:56 DSCN1477.JPG
7592727 -rwxr-xr-x 0 0 995846 28-Feb-2009 12:56 DSCN1478.JPG
7592758 -rwxr-xr-x 0 0 975395 28-Feb-2009 12:57 DSCN1479.JPG
7592788 -rwxr-xr-x 0 0 948747 28-Feb-2009 12:59 DSCN1480.JPG
7592817 -rwxr-xr-x 0 0 911981 28-Feb-2009 13:00 DSCN1481.JPG
7592845 -rwxr-xr-x 0 0 1022054 28-Feb-2009 13:01 DSCN1482.JPG
7592877 -rwxr-xr-x 0 0 985294 28-Feb-2009 13:02 DSCN1483.JPG
7592908 -rwxr-xr-x 0 0 1078478 28-Feb-2009 13:32 DSCN1484.JPG
7592941 -rwxr-xr-x 0 0 1101974 28-Feb-2009 13:36 DSCN1485.JPG
7592975 -rwxr-xr-x 0 0 1086329 28-Feb-2009 13:54 DSCN1486.JPG
7593009 -rwxr-xr-x 0 0 1083909 1-Mar-2009 02:38 DSCN1487.JPG
7593043 -rwxr-xr-x 0 0 1092866 1-Mar-2009 02:38 DSCN1488.JPG
7593077 -rwxr-xr-x 0 0 903603 1-Mar-2009 02:38 DSCN1489.JPG
7593105 -rwxr-xr-x 0 0 1089765 1-Mar-2009 02:49 DSCN1490.JPG
7593139 -rwxr-xr-x 0 0 1047224 1-Mar-2009 02:50 DSCN1491.JPG
7593171 -rwxr-xr-x 0 0 1100430 1-Mar-2009 02:50 DSCN1492.JPG
7593205 -rwxr-xr-x 0 0 1000583 1-Mar-2009 02:50 DSCN1493.JPG
7593236 -rwxr-xr-x 0 0 1010242 1-Mar-2009 02:50 DSCN1494.JPG
7593267 -rwxr-xr-x 0 0 969049 1-Mar-2009 02:51 DSCN1495.JPG
7593297 -rwxr-xr-x 0 0 950561 1-Mar-2009 02:51 DSCN1496.JPG
7593327 -rwxr-xr-x 0 0 977175 1-Mar-2009 02:51 DSCN1497.JPG
7593357 -rwxr-xr-x 0 0 1082361 1-Mar-2009 02:51 DSCN1498.JPG
7593391 -rwxr-xr-x 0 0 1141745 1-Mar-2009 02:51 DSCN1499.JPG
7593426 -rwxr-xr-x 0 0 1112723 1-Mar-2009 02:57 DSCN1500.JPG
7593460 -rwxr-xr-x 0 0 1050542 1-Mar-2009 02:57 DSCN1501.JPG
7593493 -rwxr-xr-x 0 0 972065 1-Mar-2009 03:36 DSCN1502.JPG
7593523 -rwxr-xr-x 0 0 967552 1-Mar-2009 03:36 DSCN1503.JPG
7593553 -rwxr-xr-x 0 0 901923 1-Mar-2009 03:37 DSCN1504.JPG
7593581 -rwxr-xr-x 0 0 960344 1-Mar-2009 03:37 DSCN1505.JPG
7593611 -rwxr-xr-x 0 0 1037055 1-Mar-2009 03:42 DSCN1506.JPG
7593643 -rwxr-xr-x 0 0 953244 1-Mar-2009 03:43 DSCN1507.JPG
7593673 -rwxr-xr-x 0 0 915728 1-Mar-2009 03:44 DSCN1508.JPG
7593701 -rwxr-xr-x 0 0 1028023 1-Mar-2009 03:44 DSCN1509.JPG
7593733 -rwxr-xr-x 0 0 989996 1-Mar-2009 03:44 DSCN1510.JPG
7593764 -rwxr-xr-x 0 0 1028442 1-Mar-2009 03:44 DSCN1511.JPG
7593796 -rwxr-xr-x 0 0 1029486 1-Mar-2009 03:44 DSCN1512.JPG
7593828 -rwxr-xr-x 0 0 906872 1-Mar-2009 03:45 DSCN1513.JPG
7593856 -rwxr-xr-x 0 0 897138 1-Mar-2009 03:45 DSCN1514.JPG
7593884 -rwxr-xr-x 0 0 1029100 1-Mar-2009 03:45 DSCN1515.JPG
7593916 -rwxr-xr-x 0 0 989164 1-Mar-2009 03:47 DSCN1516.JPG
7593947 -rwxr-xr-x 0 0 970352 1-Mar-2009 03:47 DSCN1517.JPG
7593977 -rwxr-xr-x 0 0 930358 1-Mar-2009 03:47 DSCN1518.JPG
7594006 -rwxr-xr-x 0 0 921606 1-Mar-2009 07:28 DSCN1519.JPG
7594035 -rwxr-xr-x 0 0 949972 1-Mar-2009 07:28 DSCN1520.JPG
7594064 -rwxr-xr-x 0 0 975169 1-Mar-2009 08:04 DSCN1521.JPG
7594094 -rwxr-xr-x 0 0 934065 1-Mar-2009 08:04 DSCN1522.JPG
7594123 -rwxr-xr-x 0 0 1007844 1-Mar-2009 08:05 DSCN1523.JPG
7594154 -rwxr-xr-x 0 0 980034 1-Mar-2009 08:05 DSCN1524.JPG
7594184 -rwxr-xr-x 0 0 999556 1-Mar-2009 08:08 DSCN1525.JPG
7594215 -rwxr-xr-x 0 0 968050 1-Mar-2009 08:09 DSCN1526.JPG
7594245 -rwxr-xr-x 0 0 1000552 1-Mar-2009 08:09 DSCN1527.JPG
7594276 -rwxr-xr-x 0 0 1037810 1-Mar-2009 08:12 DSCN1528.JPG
7594308 -rwxr-xr-x 0 0 1034926 1-Mar-2009 08:12 DSCN1529.JPG
7594340 -rwxr-xr-x 0 0 960310 1-Mar-2009 08:12 DSCN1530.JPG
7594370 -rwxr-xr-x 0 0 915966 1-Mar-2009 08:13 DSCN1531.JPG
7594398 -rwxr-xr-x 0 0 1029339 1-Mar-2009 08:16 DSCN1532.JPG
7594430 -rwxr-xr-x 0 0 1042634 1-Mar-2009 08:16 DSCN1533.JPG
7594462 -rwxr-xr-x 0 0 1014643 1-Mar-2009 08:42 DSCN1534.JPG
7594493 -rwxr-xr-x 0 0 1077047 1-Mar-2009 08:43 DSCN1535.JPG
7594526 -rwxr-xr-x 0 0 947005 1-Mar-2009 09:47 DSCN1536.JPG
7594555 -rwxr-xr-x 0 0 986843 1-Mar-2009 09:47 DSCN1537.JPG
7594586 -rwxr-xr-x 0 0 1019938 1-Mar-2009 09:48 DSCN1538.JPG
7594618 -rwxr-xr-x 0 0 1003508 1-Mar-2009 09:48 DSCN1539.JPG
7594649 -rwxr-xr-x 0 0 1035117 1-Mar-2009 09:49 DSCN1540.JPG
7594681 -rwxr-xr-x 0 0 1016024 1-Mar-2009 09:50 DSCN1541.JPG
7594713 -rwxr-xr-x 0 0 925398 1-Mar-2009 09:58 DSCN1542.JPG
7594742 -rwxr-xr-x 0 0 971162 1-Mar-2009 09:59 DSCN1543.JPG
7594772 -rwxr-xr-x 0 0 974997 1-Mar-2009 10:05 DSCN1544.JPG
7594802 -rwxr-xr-x 0 0 1010723 1-Mar-2009 10:08 DSCN1545.JPG
7594833 -rwxr-xr-x 0 0 971633 1-Mar-2009 10:09 DSCN1546.JPG
7594863 -rwxr-xr-x 0 0 1050666 1-Mar-2009 10:09 DSCN1547.JPG
7594896 -rwxr-xr-x 0 0 953882 1-Mar-2009 10:10 DSCN1548.JPG
7594926 -rwxr-xr-x 0 0 1005841 1-Mar-2009 10:10 DSCN1549.JPG
7594957 -rwxr-xr-x 0 0 940276 1-Mar-2009 10:11 DSCN1550.JPG
7594986 -rwxr-xr-x 0 0 933093 1-Mar-2009 10:15 DSCN1551.JPG
7595015 -rwxr-xr-x 0 0 980197 1-Mar-2009 10:15 DSCN1552.JPG
7595045 -rwxr-xr-x 0 0 1006465 1-Mar-2009 10:15 DSCN1553.JPG
7595076 -rwxr-xr-x 0 0 981351 1-Mar-2009 10:16 DSCN1554.JPG
7595106 -rwxr-xr-x 0 0 979750 1-Mar-2009 10:16 DSCN1555.JPG
7595136 -rwxr-xr-x 0 0 962770 1-Mar-2009 10:17 DSCN1556.JPG
7595166 -rwxr-xr-x 0 0 1004713 1-Mar-2009 10:17 DSCN1557.JPG
7595197 -rwxr-xr-x 0 0 1009031 1-Mar-2009 10:18 DSCN1558.JPG
7595228 -rwxr-xr-x 0 0 981338 1-Mar-2009 10:18 DSCN1559.JPG
7595258 -rwxr-xr-x 0 0 993827 1-Mar-2009 10:19 DSCN1560.JPG
7595289 -rwxr-xr-x 0 0 951586 1-Mar-2009 10:19 DSCN1561.JPG
7595319 -rwxr-xr-x 0 0 994181 1-Mar-2009 10:35 DSCN1562.JPG
7595350 -rwxr-xr-x 0 0 1044936 1-Mar-2009 10:36 DSCN1563.JPG
7595382 -rwxr-xr-x 0 0 962166 1-Mar-2009 10:36 DSCN1564.JPG
7595412 -rwxr-xr-x 0 0 921800 1-Mar-2009 10:45 DSCN1565.JPG
7595441 -rwxr-xr-x 0 0 940421 1-Mar-2009 10:45 DSCN1566.JPG
7595470 -rwxr-xr-x 0 0 932842 1-Mar-2009 10:49 DSCN1567.JPG
7595499 -rwxr-xr-x 0 0 924404 1-Mar-2009 10:49 DSCN1568.JPG
7595528 -rwxr-xr-x 0 0 848748 1-Mar-2009 10:50 DSCN1569.JPG
7576195 -rwxr-xr-x 0 0 60764 8-Mar-2009 19:02 DSCN2358.JPG
7576197 -rwxr-xr-x 0 0 67577 8-Mar-2009 19:02 DSCN2359.JPG
7576200 -rwxr-xr-x 0 0 76570 8-Mar-2009 19:02 DSCN2360.JPG
7576203 -rwxr-xr-x 0 0 67587 8-Mar-2009 19:02 DSCN2361.JPG
7576206 -rwxr-xr-x 0 0 65509 8-Mar-2009 19:02 DSCN2362.JPG
7576208 -rwxr-xr-x 0 0 77239 8-Mar-2009 19:02 DSCN2363.JPG
7576211 -rwxr-xr-x 0 0 72246 8-Mar-2009 19:02 DSCN2364.JPG
7576214 -rwxr-xr-x 0 0 97741 8-Mar-2009 19:02 DSCN2365.JPG
7576217 -rwxr-xr-x 0 0 98101 8-Mar-2009 19:02 DSCN2366.JPG
7576220 -rwxr-xr-x 0 0 73288 8-Mar-2009 19:02 DSCN2367.JPG
7576223 -rwxr-xr-x 0 0 63456 8-Mar-2009 19:02 DSCN2368.JPG
7576225 -rwxr-xr-x 0 0 62744 8-Mar-2009 19:02 DSCN2369.JPG
7576227 -rwxr-xr-x 0 0 82123 8-Mar-2009 19:03 DSCN2370.JPG
7576230 -rwxr-xr-x 0 0 72829 8-Mar-2009 19:03 DSCN2371.JPG
7576233 -rwxr-xr-x 0 0 65144 8-Mar-2009 19:03 DSCN2372.JPG
7576235 -rwxr-xr-x 0 0 69677 8-Mar-2009 19:03 DSCN2373.JPG
7576238 -rwxr-xr-x 0 0 68383 8-Mar-2009 19:03 DSCN2374.JPG
7576241 -rwxr-xr-x 0 0 68298 8-Mar-2009 19:03 DSCN2375.JPG
7576244 -rwxr-xr-x 0 0 64881 8-Mar-2009 19:03 DSCN2376.JPG
7576246 -rwxr-xr-x 0 0 66536 8-Mar-2009 19:03 DSCN2377.JPG
7576249 -rwxr-xr-x 0 0 69972 8-Mar-2009 19:03 DSCN2378.JPG
7576252 -rwxr-xr-x 0 0 68373 8-Mar-2009 19:03 DSCN2379.JPG
7576255 -rwxr-xr-x 0 0 66577 8-Mar-2009 19:03 DSCN2380.JPG
7576258 -rwxr-xr-x 0 0 69409 8-Mar-2009 19:03 DSCN2381.JPG
7576261 -rwxr-xr-x 0 0 64823 8-Mar-2009 19:03 DSCN2382.JPG
7576263 -rwxr-xr-x 0 0 61386 8-Mar-2009 19:03 DSCN2383.JPG
7576265 -rwxr-xr-x 0 0 71200 8-Mar-2009 19:03 DSCN2384.JPG
7576268 -rwxr-xr-x 0 0 105430 8-Mar-2009 19:03 DSCN2385.JPG
7576272 -rwxr-xr-x 0 0 95933 8-Mar-2009 19:03 DSCN2386.JPG
7576275 -rwxr-xr-x 0 0 106728 8-Mar-2009 19:03 DSCN2387.JPG
7576279 -rwxr-xr-x 0 0 96814 8-Mar-2009 19:03 DSCN2388.JPG
7576282 -rwxr-xr-x 0 0 92637 8-Mar-2009 19:03 DSCN2389.JPG
7576285 -rwxr-xr-x 0 0 98162 8-Mar-2009 19:03 DSCN2390.JPG
7576288 -rwxr-xr-x 0 0 97041 8-Mar-2009 19:03 DSCN2391.JPG
7576291 -rwxr-xr-x 0 0 98786 8-Mar-2009 19:03 DSCN2392.JPG
7576295 -rwxr-xr-x 0 0 106998 8-Mar-2009 19:03 DSCN2393.JPG
7576299 -rwxr-xr-x 0 0 87985 8-Mar-2009 19:03 DSCN2394.JPG
7576302 -rwxr-xr-x 0 0 102752 8-Mar-2009 19:03 DSCN2395.JPG
7576306 -rwxr-xr-x 0 0 88197 8-Mar-2009 19:03 DSCN2396.JPG
7576309 -rwxr-xr-x 0 0 91481 8-Mar-2009 19:03 DSCN2397.JPG
7576312 -rwxr-xr-x 0 0 84103 8-Mar-2009 19:03 DSCN2398.JPG
7576315 -rwxr-xr-x 0 0 82015 8-Mar-2009 19:03 DSCN2399.JPG
7576318 -rwxr-xr-x 0 0 85005 8-Mar-2009 19:03 DSCN2400.JPG
7576321 -rwxr-xr-x 0 0 99739 8-Mar-2009 19:03 DSCN2401.JPG
7576325 -rwxr-xr-x 0 0 90510 8-Mar-2009 19:03 DSCN2402.JPG
7576328 -rwxr-xr-x 0 0 106799 8-Mar-2009 19:03 DSCN2403.JPG
7576332 -rwxr-xr-x 0 0 102747 8-Mar-2009 19:03 DSCN2404.JPG
7576336 -rwxr-xr-x 0 0 86104 8-Mar-2009 19:03 DSCN2405.JPG
7576339 -rwxr-xr-x 0 0 18430130 8-Mar-2009 16:10 DSCN2406.MOV
Search root cluster failed
3 drwxr-xr-x 0 0 0 9-Aug-2010 20:10 DIR00001
4 drwxr-xr-x 0 0 0 9-Aug-2010 20:10 DIR00002
6 drwxr-xr-x 0 0 0 31-Dec-1979 19:00 DIR00003
12290 drwxr-xr-x 0 0 0 16-Sep-2012 17:06 DIR00004
25688 drwxr-xr-x 0 0 0 16-Sep-2012 17:06 DIR00005
25820 drwxr-xr-x 0 0 0 20-Sep-2012 19:55 DIR00006
7282956 drwxr-xr-x 0 0 0 10-Aug-2010 03:22 DIR00007
7285649 drwxr-xr-x 0 0 0 10-Aug-2010 03:22 DIR00008
7286718 drwxr-xr-x 0 0 0 10-Aug-2010 03:23 DIR00009
7335965 drwxr-xr-x 0 0 0 10-Aug-2010 03:23 DIR00010
7536792 dr-xr-xr-x 0 0 0 5-Nov-2012 11:42 DIR00011
8062875 drwxr-xr-x 0 0 0 27-Aug-2011 09:23 DIR00012
8597282 drwxr-xr-x 0 0 0 2-May-2012 18:26 DIR00013
8728570 drwxr-xr-x 0 0 0 8-May-2012 16:57 DIR00014
11514030 drwxr-xr-x 0 0 0 5-Nov-2012 11:31 DIR00015
11514105 drwxr-xr-x 0 0 0 14-Oct-2012 14:03 DIR00016
12464327 drwxr-xr-x 0 0 0 24-Dec-2012 12:34 DIR00017
12464455 drwxr-xr-x 0 0 0 24-Dec-2012 12:17 DIR00018
12517378 drwxr-xr-x 0 0 0 24-Mar-2013 16:03 DIR00019
New / Current boot sector
FAT32
sector_size 512 512
cluster_size 64 64
reserved 32 32
fats 2 2
dir_entries 0 0
sectors 0 0
media F8 F8
fat_length 0 0
secs_track 63 63
heads 255 255
hidden 63 63
total_sect 976768002 976768002
fat32_length 119206 119206
flags 0000 0000
version 0.0 0.0
root_cluster 0 2
info_sector 1 1
backup_boot 6 6
free_count uninitialised 15258273
next_free uninitialised 3
Warning: Extrapolated boot sector have incorrect values.
dir_partition inode=0
FAT32: Can't list files, bad root cluster.
Don't write new boot!
fat32_boot_sector
FAT32 at 0/1/1
FAT1 : 32-119237
sectors : 976768002
cluster_size : 64
FAT32 at 0/1/1
FAT1 : 32-119237
sectors : 976768002
cluster_size : 64
OK
OK
HPLMiami
#6 Post by HPLMiami »
Hello Fiona, hello Christophe,
Any ideas on what should I do? I am still stuck on this.
Please help! :shock:
