I was hoping someone from here would be able to help me restore my data or/and partition structure.
I was searching the forums and I couldn't find the solution to my problem. I'm also new with testdisk. Here is the story: my raspberry pi stopped working and I took sd card out and found with gparted that it's corrupted. I then ran fsck -a /dev/sde2 (second partition - ext4 is the problematical) and the output I got was:
fsck from util-linux 2.22.2
fsck.ext2: Bad magic number in super-block while trying to open /dev/sde2
/dev/sde2:
The superblock could not be read or does not describe a correct ext2
filesystem.  If the device is valid and it really contains an ext2
filesystem (and not swap or ufs or something else), then the superblock
is corrupt, and you might try running e2fsck with an alternate superblock:
    e2fsck -b 8193 <device>
Then I tried with testdisk. Here is how I tried to get my data back and repair partition structure:
Started testdisk -> create new log -> selected /dev/sde (my sd card) -> enter on Intel parition -> analyse -> quick search -> continue -> continue
I think I have multiple problems here due to the following messages:
- check_FAT: Unusual number of reserved sectors 4 (FAT), should be 1
- The harddisk (3965 MB / 3782 MiB) seems too small! (< 4798 MB / 4576 MiB)
- The following partitions can't be recovered
- Warning: the current number of heads per cylinder is 122 but the correct value may be 255.
About the following partition can't be recovered. There should only be one Linux (ext4) partition but testdisk shows two partitions. Probably because I accidentally try to analyze boot sector and did a mistake due to my ignorance and not ask first and act later
 hope I didn't mess things even more because of this mistake.
 hope I didn't mess things even more because of this mistake.Screenshots:
after analyse
after quick search
after continue - second partition
after continue -> continue
after enter
after deep search
I would me most grateful if someone takes 2minutes of her/his life and explains to me what is going on and how can I restore my second partition. Note that first partition (fat) is working and I can mount it normally.
Again I'd be much appricieted if someone who is more knowladgable in this area could help me out.
Log:
Tue Apr  2 14:04:12 2013
OS: Linux, kernel 3.7.10-1-ARCH (#1 SMP PREEMPT Thu Feb 28 09:50:17 CET 2013) x86_64
Compiler: GCC 4.7
Compilation date: 2013-01-29T15:43:06
ext2fs lib: 1.42.7, ntfs lib: libntfs-3g, reiserfs lib: 0.3.0.5, ewf lib: none
/dev/sda: size       234441648 sectors
/dev/sda: user_max   234441648 sectors
/dev/sda: native_max 234441648 sectors
Disk /dev/sda - 120 GB / 111 GiB - CHS 14593 255 63, sector size=512 - INTEL SSDSA2CW120G3, S/N:BTPR1363032Y120LGN, FW:4PC10362
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WD 10EAVS External, FW:1.05
Disk /dev/sde - 3965 MB / 3781 MiB - CHS 1023 122 62, sector size=512 - Generic- SD/MMC, FW:1.00
Disk /dev/sde - 3965 MB / 3781 MiB - Generic- SD/MMC
Analyse Disk /dev/sde - 3965 MB / 3781 MiB - CHS 1023 122 62
Geometry from i386 MBR: head=64 sector=32
BAD_RS LBA=2048 3968
FAT16 at 0/33/3
check_FAT: Unusual number of reserved sectors 4 (FAT), should be 1.
Info: size boot_sector 184320, partition 184320
FAT1 : 4-183
FAT2 : 184-363
start_rootdir : 364
Data : 400-184319
sectors : 184320
cluster_size : 4
no_of_cluster : 45980 (2 - 45981)
fat_length 180 calculated 180
BAD_RS LBA=186368 688324
 1 * FAT32 LBA                0  33  3    24  77 58     184320
Bad relative sector.
 2 P Linux                   24  77 59  1023 105 30    7558144
Computes LBA from CHS for Disk /dev/sde - 3965 MB / 3782 MiB - CHS 1024 122 62
search_vista_part: 1
FAT16 at 0/33/3
FAT1 : 4-183
FAT2 : 184-363
start_rootdir : 364
Data : 400-184319
sectors : 184320
cluster_size : 4
FAT16 at 0/33/3
     FAT16 >32M               0  33  3    24  77 58     184320
     FAT16, 94 MB / 90 MiB
recover_EXT2: s_block_group_nr=0/28, s_mnt_count=9/4294967295, s_blocks_per_group=32768, s_inodes_per_group=7776
recover_EXT2: s_blocks_count 944768
recover_EXT2: part_size 7558144
     Linux                  234  24 57  1233  52 28    7558144
     EXT4 Large file Sparse superblock Recover, 3869 MB / 3690 MiB
This partition ends after the disk limits. (start=1771520, size=7558144, end=9329663, disk end=7745536)
     Linux                  239 108 37  1239  14  8    7558144
This partition ends after the disk limits. (start=1814528, size=7558144, end=9372671, disk end=7745536)
   * FAT16 >32M               0  33  3    24  77 58     184320
 1 * FAT16 >32M               0  33  3    24  77 58     184320
FAT16 at 0/33/3
FAT1 : 4-183
FAT2 : 184-363
start_rootdir : 364
Data : 400-184319
sectors : 184320
cluster_size : 4
FAT16 at 0/33/3
