Encountered a read error while running the Analyse and Quick Search on my corrupted External Hard Drive.
Logs pasted below.
Please help ASAP.
Sat Apr 6 15:02:13 2013 Command line: TestDisk TestDisk 6.13, Data Recovery Utility, November 2011 Christophe GRENIER http://www.cgsecurity.org OS: Windows 7 (7601) SP1 Compiler: GCC 4.3, Cygwin 1007.7 Compilation date: 2011-11-15T08:36:54 ext2fs lib: 1.41.8, ntfs lib: 10:0:0, reiserfs lib: 0.3.1-rc8, ewf lib: 20100226 disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=180045766656 disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=500107861504 disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=180045766656 disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=500107861504 disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=180043644928 disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=727711744 disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=500105249280 file_pread(4,1,buffer,351662849(21889/254/63)) lseek err Invalid argument file_pread(5,1,buffer,976784129(60801/254/63)) lseek err Invalid argument Hard disk list Disk /dev/sda - 180 GB / 167 GiB - CHS 21889 255 63, sector size=512 - INTEL SS DSC2BW180A3L, S/N:VCVC424230YN81E0NG, FW:LE1i Disk /dev/sdb - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - Seagate FreeAgent GoFlex, S/N:NA0DGJ7Z, FW:0148 Drive D: - 727 MB / 694 MiB - CHS 173 64 32, sector size=2048 - HL-DT-ST DVDRAM GT50N, S/N:1MC62A5204 2, FW:LT20 Partition table type (auto): Intel Disk /dev/sdb - 500 GB / 465 GiB - Seagate FreeAgent GoFlex Partition table type: Intel Analyse Disk /dev/sdb - 500 GB / 465 GiB - CHS 60801 255 63 Geometry from i386 MBR: head=1 sector=63 NTFS at 0/1/1 get_geometry_from_list_part_aux head=255 nbr=1 get_geometry_from_list_part_aux head=8 nbr=2 get_geometry_from_list_part_aux head=16 nbr=2 get_geometry_from_list_part_aux head=32 nbr=2 get_geometry_from_list_part_aux head=64 nbr=2 get_geometry_from_list_part_aux head=128 nbr=2 get_geometry_from_list_part_aux head=240 nbr=1 get_geometry_from_list_part_aux head=255 nbr=1 Current partition structure: 1 P HPFS - NTFS 0 1 1 60801 0 63 976768065 [FreeAgent GoFlex Drive] No partition is bootable Ask the user for vista mode Computes LBA from CHS for Disk /dev/sdb - 500 GB / 465 GiB - CHS 60802 255 63 Allow partial last cylinder : Yes search_vista_part: 1 search_part() Disk /dev/sdb - 500 GB / 465 GiB - CHS 60802 255 63 NTFS at 0/1/1 filesystem size 976768065 sectors_per_cluster 8 mft_lcn 786432 mftmirr_lcn 61048004 clusters_per_mft_record -10 clusters_per_index_record 1 HPFS - NTFS 0 1 1 60801 0 63 976768065 [FreeAgent GoFlex Drive] NTFS, 500 GB / 465 GiB file_pread(5,3,buffer,976773183(60801/81/16)) lseek err Invalid argument file_pread(5,1,buffer,976773183(60801/81/16)) lseek err Invalid argument file_pread(5,8,buffer,976773199(60801/81/32)) lseek err Invalid argument file_pread(5,11,buffer,976773246(60801/82/16)) lseek err Invalid argument file_pread(5,2,buffer,976775168(60801/112/48)) lseek err Invalid argument file_pread(5,7,buffer,976773184(60801/81/17)) lseek err Invalid argument file_pread(5,8,buffer,976773311(60801/83/18)) lseek err Invalid argument file_pread(5,8,buffer,976773439(60801/85/20)) lseek err Invalid argument file_pread(5,8,buffer,976773567(60801/87/22)) lseek err Invalid argument file_pread(5,8,buffer,976773695(60801/89/24)) lseek err Invalid argument file_pread(5,8,buffer,976773823(60801/91/26)) lseek err Invalid argument file_pread(5,8,buffer,976773951(60801/93/28)) lseek err Invalid argument file_pread(5,8,buffer,976774079(60801/95/30)) lseek err Invalid argument file_pread(5,8,buffer,976774207(60801/97/32)) lseek err Invalid argument file_pread(5,8,buffer,976774335(60801/99/34)) lseek err Invalid argument file_pread(5,8,buffer,976774463(60801/101/36)) lseek err Invalid argument file_pread(5,8,buffer,976774591(60801/103/38)) lseek err Invalid argument file_pread(5,8,buffer,976774719(60801/105/40)) lseek err Invalid argument file_pread(5,8,buffer,976774847(60801/107/42)) lseek err Invalid argument file_pread(5,8,buffer,976774975(60801/109/44)) lseek err Invalid argument file_pread(5,8,buffer,976775103(60801/111/46)) lseek err Invalid argument file_pread(5,8,buffer,976775168(60801/112/48)) lseek err Invalid argument
						Trying to recover Seagate 500 GB
Re: Trying to recover Seagate 500 GB
Your log file is almost not readable.
Would it be possible to use another word processor like wordpad to open it?
It makes it better readable.
Then you can copy and paste the content.
Thank you
Thank you
				sushant172
Here you go Fiona.
NTFS at 0/1/1
NTFS at 0/1/1
file_pread(5,8,buffer,976775176(60801/112/56)) lseek err Invalid argument
file_pread(5,3,buffer,976775184(60801/113/1)) lseek err Invalid argument
file_pread(5,3,buffer,976775231(60801/113/48)) lseek err Invalid argument
file_pread(5,8,buffer,976775247(60801/114/1)) lseek err Invalid argument
file_pread(5,11,buffer,976775294(60801/114/48)) lseek err Invalid argument
file_pread(5,2,buffer,976777216(60801/145/17)) lseek err Invalid argument
Warning: the current number of heads per cylinder is 255 but the correct value may be 128.
* HPFS - NTFS 0 1 1 60801 254 63 976784067 [FreeAgent GoFlex Drive]
1 * HPFS - NTFS 0 1 1 60801 254 63 976784067 [FreeAgent GoFlex Drive]
NTFS at 0/1/1
file_pread(5,16,buffer,284751435(17724/244/4)) read err: Invalid argument
file_pread(5,1,buffer,284751435(17724/244/4)) read err: Invalid argument
file_pread(5,2,buffer,284751498(17724/245/4)) read err: Invalid argument
file_pread(5,1,buffer,284751871(17724/250/62)) read err: Invalid argument
file_pread(5,3,buffer,284751888(17724/251/16)) read err: Invalid argument
file_pread(5,3,buffer,284751935(17724/251/63)) read err: Invalid argument
file_pread(5,8,buffer,284751951(17724/252/16)) read err: Invalid argument
file_pread(5,11,buffer,284751998(17724/252/63)) read err: Invalid argument
file_pread(5,2,buffer,284753920(17725/28/32)) read err: Invalid argument
file_pread(5,1,buffer,284752124(17724/254/63)) read err: Invalid argument
file_pread(5,1,buffer,284752125(17725/0/1)) read err: Invalid argument
file_pread(5,7,buffer,284752126(17725/0/2)) read err: Invalid argument
file_pread(5,8,buffer,284752133(17725/0/9)) read err: Invalid argument
file_pread(5,3,buffer,284752141(17725/0/17)) read err: Invalid argument
file_pread(5,3,buffer,284752188(17725/1/1)) read err: Invalid argument
file_pread(5,8,buffer,284752204(17725/1/17)) read err: Invalid argument
file_pread(5,11,buffer,284752251(17725/2/1)) read err: Invalid argument
file_pread(5,2,buffer,284754173(17725/32/33)) read err: Invalid argument
file_pread(5,5,buffer,284752191(17725/1/4)) read err: Invalid argument
file_pread(5,8,buffer,284752196(17725/1/9)) read err: Invalid argument
file_pread(5,8,buffer,284752267(17725/2/17)) read err: Invalid argument
file_pread(5,11,buffer,284752314(17725/3/1)) read err: Invalid argument
file_pread(5,2,buffer,284754236(17725/33/33)) read err: Invalid argument
file_pread(5,2,buffer,284753084(17725/15/15)) read err: Invalid argument
file_pread(5,2,buffer,284753147(17725/16/15)) read err: Invalid argument
file_pread(5,2,buffer,284753210(17725/17/15)) read err: Invalid argument
file_pread(5,1,buffer,284753919(17725/28/31)) read err: Invalid argument
file_pread(5,1,buffer,284753920(17725/28/32)) read err: Invalid argument
file_pread(5,7,buffer,284753921(17725/28/33)) read err: Invalid argument
file_pread(5,8,buffer,284753928(17725/28/40)) read err: Invalid argument
file_pread(5,3,buffer,284753936(17725/28/48)) read err: Invalid argument
file_pread(5,3,buffer,284753983(17725/29/32)) read err: Invalid argument
file_pread(5,8,buffer,284753999(17725/29/48)) read err: Invalid argument
file_pread(5,11,buffer,284754046(17725/30/32)) read err: Invalid argument
file_pread(5,2,buffer,284755968(17725/61/1)) read err: Invalid argument
file_pread(5,2,buffer,284755953(17725/60/49)) read err: Invalid argument
file_pread(5,1,buffer,284755967(17725/60/63)) read err: Invalid argument
file_pread(5,6,buffer,284755970(17725/61/3)) read err: Invalid argument
file_pread(5,8,buffer,284755976(17725/61/9)) read err: Invalid argument
file_pread(5,3,buffer,284755984(17725/61/17)) read err: Invalid argument
file_pread(5,3,buffer,284756031(17725/62/1)) read err: Invalid argument
file_pread(5,8,buffer,284756047(17725/62/17)) read err: Invalid argument
file_pread(5,11,buffer,284756094(17725/63/1)) read err: Invalid argument
file_pread(5,2,buffer,284758016(17725/93/33)) read err: Invalid argument
file_pread(5,2,buffer,284756016(17725/61/49)) read err: Invalid argument
file_pread(5,2,buffer,284756079(17725/62/49)) read err: Invalid argument
file_pread(5,1,buffer,284758015(17725/93/32)) read err: Invalid argument
file_pread(5,6,buffer,284758018(17725/93/35)) read err: Invalid argument
file_pread(5,8,buffer,284758024(17725/93/41)) read err: Invalid argument
file_pread(5,3,buffer,284758032(17725/93/49)) read err: Invalid argument
file_pread(5,3,buffer,284758079(17725/94/33)) read err: Invalid argument
file_pread(5,8,buffer,284758095(17725/94/49)) read err: Invalid argument
file_pread(5,11,buffer,284758142(17725/95/33)) read err: Invalid argument
file_pread(5,2,buffer,284760064(17725/126/2)) read err: Invalid argument
file_pread(5,1,buffer,284760063(17725/126/1)) read err: Invalid argument
file_pread(5,6,buffer,284760066(17725/126/4)) read err: Invalid argument
file_pread(5,8,buffer,284760072(17725/126/10)) read err: Invalid argument
file_pread(5,3,buffer,284760080(17725/126/18)) read err: Invalid argument
file_pread(5,3,buffer,284760127(17725/127/2)) read err: Invalid argument
file_pread(5,8,buffer,284760143(17725/127/18)) read err: Invalid argument
file_pread(5,11,buffer,284760190(17725/128/2)) read err: Invalid argument
file_pread(5,2,buffer,284762112(17725/158/34)) read err: Invalid argument
file_pread(5,1,buffer,284762111(17725/158/33)) read err: Invalid argument
file_pread(5,6,buffer,284762114(17725/158/36)) read err: Invalid argument
file_pread(5,8,buffer,284762120(17725/158/42)) read err: Invalid argument
file_pread(5,3,buffer,284762128(17725/158/50)) read err: Invalid argument
NTFS at 0/1/1
NTFS at 0/1/1
NTFS at 0/1/1
Looks like that your partition table is right.
It contains your partition and label is displayed also.
Please check your file system through a boot sector diagnose.
Confirm at partition table type "Intel" with enter also
Confirm at Boot.
Please upload a screen shot.
If you see the menu list, please check it and hit enter.
Do you see your files and folders or an error message?
If the menu "List" is not available, check "Rebuild BS" and hit Enter.
Infos will follow.
Confirm at Boot.
Infos will follow.
				sushant172
Hi Fiona,
I see the menu "List" and I also see the files and directories in the disk. Please let me know what next.
Thanks.
Thanks.
Would it be possible to upload a screen from TestDisk / Advanced / Boot?
I already asked for, to determine either your file system is damaged or boot sector is corrupt.
Did you already run "Rebuild BS"?
In any case it's recommended to copy/backup ypur data firtst.
If you list your files, at the bottom of the screen you'll see all the commands.
Marking that 2 dots and pressing enter, you'll get one directory up until you get to your disk selection.
Marking a folder and pressing the right arrow key on your keyboard, you can enter a folder.
After backing up your data, we can have a look to repair your boot sector or file system.
