I need some help with a problem I have been trying to solve for a couple of days without success.
I have a 4GB flash drive which is not accessible anymore since it looks unformatted (RAW).
Everytime I try to open it I get the "Disk is not formatted - Do you want to format it?" message.
My OS is Windows XP SP3.
Several years have been passed since I formatted it and I can't even recall if it was FAT or NTFS (but I think FAT probably).
In the Windows Disk Manager the drive is there but no filesystem detected.
I tried TestDisk without success but I am no expert and maybe it could work if properly set.
Is there a way to recover the data inside the drive or are they lost?
Any help will be appreciated.
Thank You.
USB flash drive looks RAW
Re: USB flash drive looks RAW
Would it be possible to upload a screen from TestDisk / Analyse to judge your current partition table?
Alternatively, you can copy and paste the content of your testdisk.log.
You'll find it in your testdisk folder.
This information helps to determine a boot sector diagnose.
Info will follow.
Info will follow.
Hi Fiona and thanks for replying.
I hope this is what you asked for, anyway here it is (quick + deep analysis):
Drive H: - 3998 MB / 3813 MiB - CHS 7809856 1 1, sector size=512
Analyse Drive H: - 3998 MB / 3813 MiB - CHS 7809856 1 1
Ask the user for vista mode
search_vista_part: 0
BAD_RS LBA=48582282 997
FAT12 48582282 194565873 145983592
This partition ends after the disk limits. (start=48582282, size=145983592, end=194565873, disk end=7809856)
BAD_RS LBA=2624028647 975
FAT16 <32M 2624028647 3541437553 917408907
This partition ends after the disk limits. (start=2624028647, size=917408907, end=3541437553, disk end=7809856)
BAD_RS LBA=1323300785 432
FAT32 1323300785 3052228983 1728928199
This partition ends after the disk limits. (start=1323300785, size=1728928199, end=3052228983, disk end=7809856)
BAD_RS LBA=1641673248 237
FAT32 LBA 1641673248 3607330813 1965657566
This partition ends after the disk limits. (start=1641673248, size=1965657566, end=3607330813, disk end=7809856)
BAD_RS LBA=3122086662 1057
FAT32 3122086662 4669507813 1547421152
This partition ends after the disk limits. (start=3122086662, size=1547421152, end=374540517, disk end=7809856)
BAD_RS LBA=3315842482 632
FAT12 3315842482 6526464449 3210621968
This partition ends after the disk limits. (start=3315842482, size=3210621968, end=2231497153, disk end=7809856)
BAD_RS LBA=1367092518 941
FAT32 1367092518 5318800771 3951708254
This partition ends after the disk limits. (start=1367092518, size=3951708254, end=1023833475, disk end=7809856)
BAD_RS LBA=3931007910 83
FAT32 3931007910 8180649928 4249642019
This partition ends after the disk limits. (start=3931007910, size=4249642019, end=3885682632, disk end=7809856)
file_win32_pread(328,11,buffer,7809846(7809846/0/1)) read err: read after end of file
file_win32_pread(328,6,buffer,7809852(7809852/0/1)) read err: read after end of file
file_win32_pread(328,11,buffer,7809848(7809848/0/1)) read err: read after end of file
file_win32_pread(328,8,buffer,7809852(7809852/0/1)) read err: read after end of file
file_win32_pread(328,11,buffer,7809851(7809851/0/1)) read err: read after end of file
file_win32_pread(328,8,buffer,7809849(7809849/0/1)) read err: read after end of file
file_win32_pread(328,3,buffer,7809855(7809855/0/1)) read err: read after end of file
file_win32_pread(328,8,buffer,7809853(7809853/0/1)) read err: read after end of file
file_win32_pread(328,8,buffer,7809851(7809851/0/1)) read err: read after end of file
file_win32_pread(328,5,buffer,7809855(7809855/0/1)) read err: read after end of file
file_win32_pread(328,8,buffer,7809854(7809854/0/1)) read err: read after end of file
file_win32_pread(328,8,buffer,7809855(7809855/0/1)) read err: read after end of file
The harddisk (3998 MB / 3813 MiB) seems too small! (< 4188 GB / 3900 GiB)
file_win32_pread(328,8,buffer,7809850(7809850/0/1)) read err: read after end of file
file_win32_pread(328,7,buffer,7809855(7809855/0/1)) read err: read after end of file
file_win32_pread(328,6,buffer,7809853(7809853/0/1)) read err: read after end of file
Store new MBR code
In TestDisk, if the Disk selection appears, would it be possible to select your USB thumb instead of your drive?
Disk and Drive is different!
Please let me know.
Please let me know.
I am not sure I understood your question.
This is what I see in TestDisk:
The third entry (Drive H) is an encrypted partition within the flash drive. The data should be in this partition but for some reason the partition looks gone and the system keeps asking me if I want to format the drive (H) since it is seen as unformatted.
The first entry is my HDD, the second one is the physical USB flash drive.Disk /dev/sda - 500 GB / 465 GiB
Disk /dev/sdb - 4003 MB / 3817 MiB
Sry I didn't know that you have an encrypted drive.
What kind of software did you use?
Please note, as long as your drive is encrypted, either TestDisk nor windows will recognize it as a valid file system.
Has it been possible to decrypt your drive?
If you used TrueCrypt, simpson 474 might be able to help?
My fault.
I didn't mention it since once the device is mounted it looks (better, looked) like a normal (unencrypted) drive so I thought it was irrelevant.
I used TrueCrypt.
simpson 474? What (or who) is it?
That's exactly why I used TestDisk on H: drive and not on the physical USB drive. Once mounted, H: should be perfectly detectable as a FAT partition (as far as I understand).Fiona wrote:Please note, as long as your drive is encrypted, either TestDisk nor windows will recognize it as a valid file system.
I used TrueCrypt.
Still waiting here.
