Files (.rw2) recovered but then automatically deleted Topic is solved
comaxime
#1 Post by comaxime »
Hello all,
I am aksing for your help regarding the following problem.
Each time a .rw2 file seems to be recovered (appears in 'recup_dir' folder), within a few seconds it is deleted and disappear from the folder.
In fact all of my .rw2 files appear and disppear continuously (while .jpg files are kept).
The thing is, I sometimes have a few seconds before the files are deleted, and when I open them I can see that the pictures are correctly displayed/recovered (so no reason to discard those files?).
Have you ever faced that issue?
Any idea how I could keep my .rw2 files, and prevent them from being deleted by PhotoRec? :-/
Thanks.
Re: Files (.rw2) recovered but then automatically deleted
try using the latest 6.14-WIP version and if the problem persists, please send me some unmodified rw2 file taken with your camera.
comaxime
#3 Post by comaxime »
Indeed, I was using the 6.13 version, and with the 6.14 one that I just tried, I do not have this problem anymore.
Thanks a lot!
