I have had a WD 500GB USB disk for some time as a backup. It has two partitions as m:\ and n:\ (WDC WD50 00AAKB-00H8A0).
Just today I noticed that the first partition had gone and my Win7 asked if I wanted to format.
I tried Test Disk and this is my log file. I hope it is the correct one.
Can you help please?
Thanks
oz
Mon Apr 22 14:58:34 2013
Compilation date: 2012-05-21T08:46:51
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=500107862016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sde)=2000398931968
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdf)=2000398933504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=500107862016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=2000398931968
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive5)=2000398933504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=500000882688
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=104857600
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=252536946688
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=2000397883392
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=80570482688
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=209715200000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\J:)=125829120000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\K:)=83883982848
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\L:)=247462887424
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\M:)=262147866624
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\N:)=2000397883392
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ST500DM002-1BD142, S/N:202020202020202020202020325a43415657564c, FW:KC44
Disk /dev/sdb - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ST500DM002-1BC142, S/N:202020202020202020202020325a454132305446, FW:JC4B
Disk /dev/sdc - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ST500DM002-1BC142, S/N:202020202020202020202020325a454144324141, FW:JC4B
Disk /dev/sdd - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - WDC WD50 00AAKB-00H8A0, S/N:W -D, FW:0000
Disk /dev/sde - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - Seagate External, S/N:2GHD3919, FW:SG16
Disk /dev/sdf - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - Seagate Expansion Desk, S/N:NA4LFZBV, FW:070B
Disk /dev/sdd - 500 GB / 465 GiB - WDC WD50 00AAKB-00H8A0
Analyse Disk /dev/sdd - 500 GB / 465 GiB - CHS 60801 255 63
NTFS at 0/1/1
file_pread(7,4092,buffer,6291523(391/160/29)) ReadFile Data error (cyclic redundancy check).
NTFS: Can't read MFT
1 * HPFS - NTFS 0 1 1 31870 254 63 512007552
Ask the user for vista mode
search_vista_part: 0
NTFS at 0/1/1
filesystem size 512007552
mftmirr_lcn 32000471
NTFS, blocksize=4096, 262 GB / 244 GiB
NTFS at 31871/0/1
filesystem size 464760450
mftmirr_lcn 29047528
HPFS - NTFS 31871 0 1 60800 254 63 464760450 [USB-PHOTOS-221]
NTFS, blocksize=4096, 237 GB / 221 GiB
file_pread(7,8,buffer,976773183(60801/81/16)) lseek err Invalid argument
file_pread(7,1,buffer,976773183(60801/81/16)) lseek err Invalid argument
file_pread(7,8,buffer,976773311(60801/83/18)) lseek err Invalid argument
file_pread(7,8,buffer,976773439(60801/85/20)) lseek err Invalid argument
file_pread(7,8,buffer,976773567(60801/87/22)) lseek err Invalid argument
file_pread(7,8,buffer,976773695(60801/89/24)) lseek err Invalid argument
file_pread(7,8,buffer,976773823(60801/91/26)) lseek err Invalid argument
file_pread(7,8,buffer,976773951(60801/93/28)) lseek err Invalid argument
file_pread(7,8,buffer,976774079(60801/95/30)) lseek err Invalid argument
file_pread(7,8,buffer,976774207(60801/97/32)) lseek err Invalid argument
file_pread(7,8,buffer,976774335(60801/99/34)) lseek err Invalid argument
file_pread(7,8,buffer,976774463(60801/101/36)) lseek err Invalid argument
file_pread(7,8,buffer,976774591(60801/103/38)) lseek err Invalid argument
file_pread(7,8,buffer,976774719(60801/105/40)) lseek err Invalid argument
file_pread(7,8,buffer,976774847(60801/107/42)) lseek err Invalid argument
file_pread(7,8,buffer,976774975(60801/109/44)) lseek err Invalid argument
file_pread(7,8,buffer,976775103(60801/111/46)) lseek err Invalid argument
file_pread(7,8,buffer,976775231(60801/113/48)) lseek err Invalid argument
file_pread(7,8,buffer,976775359(60801/115/50)) lseek err Invalid argument
file_pread(7,8,buffer,976775487(60801/117/52)) lseek err Invalid argument
file_pread(7,8,buffer,976775615(60801/119/54)) lseek err Invalid argument
file_pread(7,8,buffer,976775743(60801/121/56)) lseek err Invalid argument
file_pread(7,8,buffer,976775871(60801/123/58)) lseek err Invalid argument
file_pread(7,8,buffer,976775999(60801/125/60)) lseek err Invalid argument
file_pread(7,8,buffer,976776127(60801/127/62)) lseek err Invalid argument
file_pread(7,8,buffer,976776255(60801/130/1)) lseek err Invalid argument
file_pread(7,8,buffer,976776383(60801/132/3)) lseek err Invalid argument
file_pread(7,8,buffer,976776511(60801/134/5)) lseek err Invalid argument
P HPFS - NTFS 31871 0 1 60800 254 63 464760450 [USB-PHOTOS-221]
2 P HPFS - NTFS 31871 0 1 60800 254 63 464760450 [USB-PHOTOS-221]
Failed to open inode $MFTMirr: Input/Output error.
Failed to load $MFTMirr: Input/Output error.
Don't write, no confirmation
NTFS at 0/1/1
file_pread(7,4096,buffer,6291519(391/160/25)) ReadFile Data error (cyclic redundancy check).
file_pread(7,1,buffer,6291522(391/160/28)) ReadFile Data error (cyclic redundancy check).
Not an exFAT boot sector.
NTFS at 0/1/1
Filesystem problem
Re: Filesystem problem
Any help here please?
Do I have the correct information here?
Thanks
oz
Thanks
oz
