Hello all,
I am new to using TestDisk so let me apologise if my question comes across as somewhat naive.
TestDisk initially warned that my disk geometry was wrong. I changed the geometry, did a deeper search, and TestDisk came up with 4 partitions; first one fat other three NTFS, all marked as D and overlapping. I can change partition 2 from D to * without any problems but when I go from D to something else on partitions three and four I get Structure: Bad in red.
The only partition I am interested in keeping is the partition 2. Found many of my more important files on it and copied them to my C: drive.
Is it safe to mark partition 2 with a *, leave the other three as D and proceed?
What exactly does the D option delete? Does the fact that I was able to copy files over to my C: drive mean the disk geometry I provided is correct?
Is there a way to make certain that the geometry is correct?
Just want to make certain that I am not asking the software to delete a portion of partition 2 given that partition 3 overlaps partition 2 and is marked with D or about to do something which will further corrupt the disk.
Thanks Amp7
Tue Apr 23 12:10:08 2013
TestDisk 6.14-WIP, Data Recovery Utility, April 2013
OS: Windows XP SP3
Compilation date: 2013-04-14T19:46:54
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=81964302336
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=81964302336
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=80015491584
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=548790272
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=47591437824
Disk /dev/sda - 80 GB / 74 GiB - CHS 10337 240 63, sector size=512 - WDC WD800JB-00JJA0, S/N:4457572d4143394d373333303039203420202020, FW:05.01C05
Disk /dev/sdb - 81 GB / 76 GiB - CHS 2354213 4 17, sector size=512 - Maxtor 6 Y080L0, FW:YAR4
Drive D: - 548 MB / 523 MiB - CHS 130 64 32, sector size=2048 - HL-DT-ST CD-RW GCE-8520B, FW:1.00
Disk /dev/sdb - 81 GB / 76 GiB - Maxtor 6 Y080L0
Analyse Disk /dev/sdb - 81 GB / 76 GiB - CHS 2354213 4 17
BAD_RS LBA=63 17
Invalid NTFS or EXFAT boot
1 * HPFS - NTFS 0 3 13 1366942 1 17 92952027
FAT12 at 0/3/13
FAT1 : 1-8
FAT2 : 9-16
start_rootdir : 17
Data : 49-20736
sectors : 20739
cluster_size : 8
no_of_cluster : 2586 (2 - 2587)
fat_length 8 calculated 8
FAT differs, FAT sectors=0-8/8
FAT12 at 0/3/13
FAT12 0 3 13 305 3 11 20739 [NO NAME]
Warning: the current number of heads per cylinder is 4 but the correct value may be 255.
L FAT12 0 3 13 305 3 11 20739 [NO NAME]
add_ext_part_i386: max
add_ext_part_i386: min
1 E extended 0 1 1 305 3 17 20791
5 L FAT12 0 3 13 305 3 11 20739 [NO NAME]
write_all_log_i386: CHS: 0/1/1,lba=17
New geometry
Disk /dev/sdb - 81 GB / 76 GiB - CHS 9964 255 63 sector_size=512
Analyse Disk /dev/sdb - 81 GB / 76 GiB - CHS 9964 255 63
1 * HPFS - NTFS 0 1 1 5785 254 63 92952027
FAT12 at 0/1/1
FAT1 : 1-8
FAT2 : 9-16
start_rootdir : 17
Data : 49-20736
sectors : 20739
cluster_size : 8
heads/cylinder 4 (FAT) != 255 (HD)
sect/track 17 (FAT) != 63 (HD)
FAT12 at 0/1/1
FAT12 0 1 1 1 75 12 20739 [NO NAME]
* FAT12 0 1 1 1 254 63 32067 [NO NAME]
FAT12, blocksize=4096, 16 MB / 15 MiB
1 * FAT12 0 1 1 1 254 63 32067 [NO NAME]
FAT12 at 0/1/1
FAT1 : 1-8
FAT2 : 9-16
start_rootdir : 17
Data : 49-20736
sectors : 20739
cluster_size : 8
FAT12 at 0/1/1
NTFS at 5786/254/63
filesystem size 92968092
mftmirr_lcn 3931904
HPFS - NTFS 0 1 1 5786 254 63 92968092
NTFS found using backup sector, blocksize=4096, 47 GB / 44 GiB
NTFS at 5787/0/1
filesystem size 67103505
mftmirr_lcn 4193969
HPFS - NTFS 5787 0 1 9963 254 63 67103505 [New Volume]
NTFS, blocksize=4096, 34 GB / 31 GiB
NTFS at 9962/254/63
filesystem size 97144992
mftmirr_lcn 6071561
HPFS - NTFS 3916 1 1 9962 254 63 97144992
NTFS found using backup sector, blocksize=4096, 49 GB / 46 GiB
NTFS at 9963/254/63
mftmirr_lcn 4193969
NTFS found using backup sector, blocksize=4096, 34 GB / 31 GiB
file_pread(5,2,buffer,160088064(9965/5/25)) lseek err Invalid argument
file_pread(5,1,buffer,160088064(9965/5/25)) lseek err Invalid argument
file_pread(5,2,buffer,160086972(9964/243/4)) lseek err Invalid argument
file_pread(5,2,buffer,160087035(9964/244/4)) lseek err Invalid argument
file_pread(5,2,buffer,160087098(9964/245/4)) lseek err Invalid argument
file_pread(5,1,buffer,160087724(9964/254/63)) lseek err Invalid argument
file_pread(5,1,buffer,160087725(9965/0/1)) lseek err Invalid argument
get_geometry_from_list_part_aux head=255 nbr=7
1 * HPFS - NTFS 0 1 1 5786 254 63 92968092
Need clarification on commands, disk geometry
Re: Need clarification on commands, disk geometry
TestDisk and 255 Heads looks correct.
After Deeper Search testdisk found some NTFS partitions.
Did you mark your found NTFS-partitions and did you press p to have a try to list your files?
If your files are displayed on any partitions, please let me know on which ones?
Hi Fiona,
Yes, the files were on partition 2. I was able to copy the more important files to my C: drive.
I flagged partition 2 with an *, left the other three partitions with a D, and did the write.
Then TestDisk asked me to recreate my boot record from backup and I did this as well.
Now I can access the drive when it's designated as a slave but I cannot boot from it.
Comes back with "A disk read error occurred. Press CTRL-ALT-DEL to restart". So now I am onto
trying to solve this one.
I assume the problem is some kind of mismatch between what the BIOS expects and the boot record
is providing but just guessing at this point.
If you can point me in the right direction, I would very much appreciate it.
Thanks amp7
Thanks amp7
