mac osx 10.8.3, toshiba 1tb external drive (its been nothing but trouble)
Sun Apr 28 14:23:45 2013
TestDisk 6.14-WIP, Data Recovery Utility, April 2013
OS: Darwin, kernel 12.3.0 (Darwin Kernel Version 12.3.0: Sun Jan 6 22:37:10 PST 2013; root:xnu-2050.2
Compiler: GCC 4.0
Compilation date: 2013-04-22T08:35:56
ext2fs lib: 1.41.8, ntfs lib: libntfs-3g, reiserfs lib: 0.3.1-rc8, ewf lib: 20120504
Disk /dev/disk0 - 500 GB / 465 GiB - 976773168 sectors (RO), sector size=512
Disk /dev/disk1 - 2000 GB / 1863 GiB - 3907029167 sectors (RO), sector size=512
Disk /dev/disk2 - 1000 GB / 931 GiB - 1953525168 sectors, sector size=512
Disk /dev/rdisk0 - 500 GB / 465 GiB - 976773168 sectors (RO), sector size=512
Disk /dev/rdisk1 - 2000 GB / 1863 GiB - 3907029167 sectors (RO), sector size=512
Disk /dev/rdisk2 - 1000 GB / 931 GiB - 1953525168 sectors, sector size=512
Partition table type: EFI GPT
Analyse Disk /dev/rdisk2 - 1000 GB / 931 GiB - 1953525168 sectors
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=1953536511 (expected 1953525167)
hdr_lba_start=34
hdr_lba_end=1953536478
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
1 P EFI System 40 409639 409600
2 P Mac HFS 409640 1953262983 1952853344
FAT32 at 40/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
sect/track 32 (FAT) != 1 (HD)
FAT32 at 40/0/1
EFI System 40 409639 409600 [EFI]
part_size 1952853344
HFS+ blocksize=4096, 999 GB / 931 GiB
P EFI System 40 409639 409600 [EFI]
1 P EFI System 40 409639 409600 [EFI]
FAT32 at 40/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
FAT32 at 40/0/1
FAT32 at 46/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
FAT32 at 46/0/1
EFI System 46 409645 409600 [EFI]
New geometry
Disk /dev/rdisk2 - 1000 GB / 931 GiB - CHS 3815479 16 32 sector_size=512
Analyse Disk /dev/rdisk2 - 1000 GB / 931 GiB - CHS 3815479 16 32
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=1953536511 (expected 1953525247)
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
FAT32 at 0/1/9
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
FAT32 at 0/1/9
HFS+ magic value at 800/1/9
NTFS at 3815474/13/16
heads/cylinder 255 (NTFS) != 16 (HD)
sect/track 63 (NTFS) != 32 (HD)
filesystem size 1953521072
mftmirr_lcn 16
NTFS: Can't read MFT
MS Data 1953523119 3907044190 1953521072
This partition ends after the disk limits. (start=1953523119, size=1953521072, end=3907044190, disk end=1953525248)
The harddisk (1000 GB / 931 GiB) seems too small! (< 2000 GB / 1863 GiB)
2 P Mac HFS 409640 1953262983 1952853344The things i am wondering about are:
disk2 and rdisk2? wich one should i select?
check_FAT: Unusual media descriptor (0xf0!=0xf8) -- what does this mean?
I got this error:
changing heads to 16 and sectors to 32 using the geometry menu seemed to be correct.
i get an error when i try to write and i cannot list my files.
any advice appreciated
