(Edit: Sorry this is same as my other post, I thought I didn't successfully submit it)
Set top box corrupted my external hdd. Im trying to use this tool and can't figure out what to do next. Im checking the examples but the result is not similar to examples. Please help. I'll post the log below after analyse. Thanks;
Sun May  5 15:57:32 2013
TestDisk 6.14-WIP, Data Recovery Utility, April 2013
OS: Windows XP SP3
Compilation date: 2013-04-28T20:31:57
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=80015491584
Disk /dev/sda - 80 GB / 74 GiB - CHS 9729 255 63, sector size=512 - TOSHIBA MK8037GSX, FW:DL250J
Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - Seagate Desktop, FW:0130
Disk /dev/sdb - 2000 GB / 1863 GiB - Seagate Desktop
Geometry from i386 MBR: head=129 sector=16
BAD_RS LBA=3300950114 5654935
check_part_i386 2 type 62: no test
BAD_RS LBA=32877 4294967295
check_part_i386 3 type 41: no test
BAD_RS LBA=1924694050 4294967295
check_part_i386 4 type 6E: no test
 2 P Sys=62               205474 163 36 205509  82 28     557165
Bad relative sector.
 3 P PPC PReP Boot            2  11 55     2  11 54          0
 4 P Sys=6E               119806 169 14 279020 151 47 2557771810
						Help: Space conflict between 2 partitions Topic is solved
Re: Help: Space conflict between 2 partitions
solved it now. Analyse. Then change type from "*" to "P" by clicking left. Press enter. Then "Write". Then "You have to reboot for change to take effect". Reboot. Now my HDD is working.
Thanks TestDisk!
						Thanks TestDisk!
