Ext HD is RAW, Testdisk shows files - what now - Help!!
Deleted User 3348
#1 Post by Deleted User 3348 »
Hi there,
i have searched the boards for my answer but i'm stuck so it's yet another topic i am afraid.
Simple story, a 2TB external HD decided it was going to be in RAW format.
I found this software and it has found all my files, i can even copy them on to my laptop!
But my question is this...
Can i just turn it back into an NTFS drive?
i've fiddled a bit and here are some screen grabs.
if someone could let me know what i need to do i'd be forever thankful.
I could copy the files off, format the drive and copy them back on of course.
But that would take forever and i also don't have a drive large enough to copy it all onto.
can i just switch it back?
i found one message that said;
"boot sector status OK
"backup boot sector status ok
"sectors are identical
"a valid NTFS sector must be present in order to access any data"
i guess i'm missing one of those :)
these show that files are there, what happened when i tried to repair the boot sector and when i tried repair MFT
thanks!
file list.JPG (80.84 KiB) Viewed 3119 times
repair MFT.JPG (26.55 KiB) Viewed 3119 times
Deleted User 3348
Re: Ext HD is RAW, Testdisk shows files - what now - Help!!
#2 Post by Deleted User 3348 »
I've since found this here http://www.cgsecurity.org/wiki/Advanced ... MFT_Repair which does seem to suggest i'm done for.
Repair An NTFS MFT
The MFT (Master File Table) is sometimes corrupted. If Microsoft's Checkdisk (chkdsk) failed to repair the MFT, run TestDisk. In the Advanced menu, select your NTFS partition, choose Boot, then Repair MFT. TestDisk will compare the MFT and MFT mirror (its backup). If the MFT is damaged, it will try to repair the MFT using the backup. If the MFT backup is damaged, it will use the main MFT.
If both MFT and MFTMirr are damaged and thus cannot be repaired using TestDisk, you might want to try commercial software like Zero Assumption Recovery, GetDataBack for NTFS or Restorer 2000.
Deleted User 3348
#3 Post by Deleted User 3348 »
I now have a registered version of EaseUs which has confirmed that all 5000+ folders are there and the songs intact.
So i just need to know how to turn it back into an NTFS drive.
I'm amazed there isn't just some simple mechanism to do sO
Thanks in advance to anyone reading this that might know how to fix it for me :)
