How long should I expect a recovery scan would "normally" take on an 80 GB SATA drive?
I'm running PhotoRec 6.12 on a WinXP SP3 box. It has two permanent SATA drives and a SATA DVD-ROM installed. I've connected a 3rd SATA drive (2.5" 80 GB laptop drive) for data recovery. It has lots of bad sectors and other filesystem problems.
PhotoRec has been running for almost five days now, and it is only ~16% complete. (see attached screenshot)
I've noticed that explorer.exe has become extremely sluggish on this system, as though something is consuming all system resources. But TaskManager does not show any high CPU usage by PhotoRec or any other process. I've also noticed that the HDD activity light is constantly lit, though.
Is this scan proceeding abnormally slowly? Is there anything I should do to speed it up?
Length of PhotoRec recovery scan?
- Screenshot of PhotoRec progress. 113 hrs elapsed, 590 hrs to go?
- Clipboard01.png (12.21 KiB) Viewed 9398 times
Re: Length of PhotoRec recovery scan?
When a disk contains bad sectors, it's better to clone the harddisk first using ddrescue as described in http://www.cgsecurity.org/wiki/Damaged_Hard_Disk and work on the clone.
I'm having a similar sort of thing. I'm running photorec right now on an image.dd and its done 19 hrs with 38 more to go and it keeps going up little by little. i am saving the recovered files to the same hdd that the image.dd is on, do you think it keeps finding and duplicating the same files? I can't imagine that it would do that but possibly...though judging by data use right now who knows.
