Corrupt SD card from Android phone
Mighty
#1 Post by Mighty »
It's not finding any partitions. Ran the deep scan twice. I've begun spelunking around in the other options, but nothing has jumped out at me, yet.
What's the best way to proceed from this point?
Thanks,
Drake Christensen
The log file:
Fri May 17 00:15:32 2013
TestDisk 6.14-WIP, Data Recovery Utility, April 2013
Compiler: GCC 4.7, MinGW 3.11
Compilation date: May  8 2013 08:18:08
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=32018268160
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=255953207296
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=1000202043392
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=32014073856
Disk \\.\PhysicalDrive0 - 256 GB / 238 GiB - CHS 31130 255 63, sector size=512
Disk \\.\PhysicalDrive1 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512
Disk \\.\PhysicalDrive4 - 32 GB / 29 GiB - CHS 3892 255 63, sector size=512
Drive C: - 255 GB / 238 GiB - CHS 31117 255 63, sector size=512
Drive D: - 1000 GB / 931 GiB - CHS 121600 255 63, sector size=512
Drive H: - 32 GB / 29 GiB - CHS 3892 255 63, sector size=512
Analyse Drive H: - 32 GB / 29 GiB - CHS 3892 255 63
Re: Corrupt SD card from Android phone
Did you use the 64bit-version?
TestDisk-6.14WIP-32bit is recommended.
Windows doesn't support partitioning of flashcards and usb thumbs as much.
In some cases a boot sector diagnose or partition table type None helped.
Would be something to try.
Would it be possible to repeat your diagnsoe and using the recommended verion?
If it's possible select your card as disk and not as a drive.
Run Analyse, Quick and Deeper Search.
Info will follow.
Mighty
#3 Post by Mighty »
I'm running Win7-64 Pro, so that's why I chose to download the 64-bit version of TestDisk. If the functionality is different then maybe the Download page should make that more clear.
I ran the 32-bit version and it found two partitions immediately. Actually, I guess it's two copies of the same partition info.
Currently, it's backing up the table. Actually, looks like it's backing up the entire disk? Anyway, I think I'm at a point where I can start RTFM. Thanks for pointing me at the 32-bit version.
Drake
Fri May 17 01:00:04 2013
Compilation date: 2013-05-08T08:18:00
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sde)=32018268160
Disk /dev/sda - 256 GB / 238 GiB - CHS 31130 255 63, sector size=512 - M4-CT256M4SSD2, S/N:3030303030303030323131343930383141393146, FW:010G
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC WD1002FAEX-00Z3A0, S/N:2020202057202d44435754414152313334313335, FW:05.01D05
Disk /dev/sde - 32 GB / 29 GiB - CHS 3892 255 63, sector size=512 - Myson CS8819A2-113  2, FW:1.01
Disk /dev/sde - 32 GB / 29 GiB - Myson CS8819A2-113  2
Analyse Disk /dev/sde - 32 GB / 29 GiB - CHS 3892 255 63
Geometry from i386 MBR: head=170 sector=53
test_FAT()
 1 P FAT32 LBA                0 130  3  3892 169 53   62527488
sector_size  0
cluster_size 0
reserved     0
fats         0
dir_entries  0
sectors      0
media        00
fat_length   0
secs_track   0
heads        0
hidden       0
total_sect   0
Invalid FAT boot sector
file_pread(6,2,buffer,62535680(3892/169/54)) ReadFile The drive cannot find the sector requested.
file_pread(6,1,buffer,62535680(3892/169/54)) ReadFile The drive cannot find the sector requested.
file_pread(6,15,buffer,62535681(3892/169/55)) lseek err Invalid argument
file_pread(6,3,buffer,62535696(3892/170/7)) lseek err Invalid argument
file_pread(6,3,buffer,62535743(3892/170/54)) lseek err Invalid argument
file_pread(6,8,buffer,62535759(3892/171/7)) lseek err Invalid argument
file_pread(6,11,buffer,62535806(3892/171/54)) lseek err Invalid argument
file_pread(6,2,buffer,62537728(3892/202/23)) lseek err Invalid argument
test_FAT()
sector_size  0
cluster_size 0
reserved     0
fats         0
dir_entries  0
sectors      0
media        00
fat_length   0
secs_track   0
heads        0
hidden       0
total_sect   0
