Recover .log file extensions
Uz8yuOmh
#1 Post by Uz8yuOmh »
Hello All,
I am attempting to retrieve some .log files using PhotoRec. Has any here performed such a task?
I looked at http://www.cgsecurity.org/wiki/File_For ... y_PhotoRec and noted the .log file extension were not listed.
Thanks!
CDRW
Re: Recover .log file extensions
#2 Post by CDRW »
A *.log file is just a plain text (*.txt )file with a .log extension. So a search for plain text should find log files. Photorec doesn't actually look at the file extensions, it looks for the signature.
Uz8yuOmh
#3 Post by Uz8yuOmh »
I will also add the this is on a QNX filesystem.
Uz8yuOmh
#4 Post by Uz8yuOmh »
I ended up using Prodiscover to create a .vmdk file of a DD, load the .vmdk in VMware Workstation (with some configuration changes) then copy the QNX file from the QNX partition to the C: on the DOS partition.
