It's 3 HDD's, each 2TB, in a spanned configuration....
The file system is perfectly intact, and I can copy from the disks, but it's about 3-4TB of info and I don't have that much available space to move stuff onto
It's writing the partition OK, but when trying to write the "backup boot sector" it says error, can't write. I was able to save the most important stuff, so you guys are AWESOME! THANK YOU SO MUCH FOR THIS!
When I run testdisk on the other disks, it lists only a FAT16 >32M partition, whatever that means. There's no file listing on those.
Here's the log file, I think (from the one that listed a NTFS partition). Thank you for taking a look
Fri May 24 21:02:22 2013
OS: Windows Server 2008 R2 (7600)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=80026361856
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=2000398934016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=80026361856
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=2000398934016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=79918268416
file_pread(4,1,buffer,3907040129(243201/254/63)) lseek err Invalid argument
file_pread(5,1,buffer,3907040129(243201/254/63)) lseek err Invalid argument
file_pread(6,1,buffer,156312449(9729/254/63)) lseek err Invalid argument
file_pread(7,1,buffer,3907040129(243201/254/63)) lseek err Invalid argument
Disk /dev/sda - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - WDC WD20EARS-00MVWB0, S/N:2020202057202d444d575a413041343837303434, FW:51.0AB51
Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - ST2000DM001-9YN164, S/N:202020202020202020202020315a31454d4c3348, FW:CC4B
Disk /dev/sdc - 80 GB / 74 GiB - CHS 9729 255 63, sector size=512 - ST3802110A, S/N:2020202020202020202020204c3539535651424a, FW:3.AAJ
Disk /dev/sdd - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - ST2000DL003-9VT166, S/N:2020202020202020202020205936314450353856, FW:CC3C
Disk /dev/sda - 2000 GB / 1863 GiB - WDC WD20EARS-00MVWB0
Analyse Disk /dev/sda - 2000 GB / 1863 GiB - CHS 243201 255 63
check_part_i386 1 type 42: no test
1 P W2K Dynamic/SFS 0 1 1 243201 48 31 3907027057
Ask the user for vista mode
Computes LBA from CHS for Disk /dev/sda - 2000 GB / 1863 GiB - CHS 243202 255 63
search_vista_part: 1
NTFS at 60646/205/40
filesystem size 2207782912
mftmirr_lcn 2
HPFS - NTFS 60646 205 40 198074 238 52 2207782912 [New Volume]
NTFS, 1130 GB / 1052 GiB
BAD_RS LBA=4064526178 5159999
file_pread(4,3,buffer,4064526178(253005/13/35)) lseek err Invalid argument
file_pread(4,1,buffer,4064526178(253005/13/35)) lseek err Invalid argument
FAT16 >32M 253005 13 35 320920 27 17 1091055340
This partition ends after the disk limits. (start=4064526178, size=1091055340, end=860614221, disk end=3907040130)
file_pread(4,2,buffer,3907031040(243201/110/46)) lseek err Invalid argument
file_pread(4,1,buffer,3907031040(243201/110/46)) lseek err Invalid argument
file_pread(4,7,buffer,3907031041(243201/110/47)) lseek err Invalid argument
file_pread(4,8,buffer,3907031048(243201/110/54)) lseek err Invalid argument
file_pread(4,3,buffer,3907031056(243201/110/62)) lseek err Invalid argument
file_pread(4,3,buffer,3907031103(243201/111/46)) lseek err Invalid argument
file_pread(4,8,buffer,3907031119(243201/111/62)) lseek err Invalid argument
file_pread(4,11,buffer,3907031166(243201/112/46)) lseek err Invalid argument
file_pread(4,2,buffer,3907033088(243201/143/15)) lseek err Invalid argument
The harddisk (2000 GB / 1863 GiB) seems too small! (< 2639 GB / 2458 GiB)
* HPFS - NTFS 60646 205 40 198074 238 52 2207782912 [New Volume]
1 P HPFS - NTFS 60646 205 40 198074 238 52 2207782912 [New Volume]
Don't write, no confirmation
Analyse Disk /dev/sda - 2000 GB / 1863 GiB - CHS 243202 255 63
